http://www.dpreview.com/news/0601/06011801zeisslensesnikon.asp
Вполне себе пафосно :)
Оно, конечно, [:|||||||:], но мне понравилось
Всего 9 сообщ.
Показаны 1 - 9
Re: Оно, конечно, [:|||||||:], но мне понравилось
от: Misty
А куда деваццо, если контакс сдулся? Вот и имеем то, что имеем. Скоро и под кенон наверно будут делать...
Re: Re: Оно, конечно, [:|||||||:], но мне понравилось
от: Царь Егорот: Misty
О как.
А я даже не знал, что он болел (с)
Re: Re: Re: Оно, конечно, [:|||||||:], но мне понравилось
стопами косины идут!
прикольный пинок канонистам, наверное... не на каждой камере можно цейс носить (сони-панас не в счёт :) ).
от: КузьмичЪ
http://www.zeiss.com/c12567a8003b58b9/Contents-Frame/5abd5bc6297eb165c12570f900407e35
CLN: Canon users would love to be able to use Zeiss lenses, too!
Müller: …and they keep telling us day-in day-out. So along with the ZF line, we are also introducing "ZS" lenses. Carl Zeiss ZS lenses come with the same optics as the ZF line; only the mount is different. ZS has the M-42 screw mount, the one that used to be called the "Universal SLR mount." We don't think the M-42 screw mount is going to take the market by storm, but it has a unique advantage: there are M-42 adapters available for any SLR bayonet mounts, including Canon EOS and FD. So you can adapt a ZS lens onto any 35 mm SLRs (and many other applications as well) if you crave the optical characteristics of this lens line and are willing to get along without the
от: КузьмичЪ
да косиновский фатерлянтер на еос делают, да и переходники ж есть и с 42 резьбы и с аи
The production is done at the Cosina factory in Japan under the watchful eye of Carl Zeiss employees in charge of quality assurance. The actual quality control will be performed on measuring machines designed and made by Carl Zeiss in Oberkochen just as it has been on all Japanese-made Zeiss lenses.
от:Schnappi das Kleine Krokodil
The production is done at the Cosina factory in Japan under the watchful eye of Carl Zeiss employees in charge of quality assurance. The actual quality control will be performed on measuring machines designed and made by Carl Zeiss in Oberkochen just as it has been on all Japanese-made Zeiss lenses.Подробнее
Гм. Звучит не оч. убедительно. Чисто психологически. Киосеровский Цейс я использовал, он вполне даже хороший. Но вот Козина..
