В exif 5D Mark II 248 параметров для жипега и 254 для рава.
ExifTool Version Number : 8.25
File Name : IMG_0210.JPG
Directory : .
File Size : 4.4 MB
File Modification Date/Time : 2010:09:06 10:38:36+04:00
File Permissions : rwxr-xr-x
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : Canon
Camera Model Name : Canon EOS 5D Mark II
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Modify Date : 2010:09:06 10:38:35
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/800
F Number : 2.0
Exposure Program : Shutter speed priority AE
ISO : 500
Exif Version : 0221
Date/Time Original : 2010:09:06 10:38:35
Create Date : 2010:09:06 10:38:35
Components Configuration : Y, Cb, Cr, -
Shutter Speed Value : 1/790
Aperture Value : 2.0
Flash : Off, Did not fire
Focal Length : 58.0 mm
Macro Mode : Normal
Self Timer : Off
Quality : Fine
Canon Flash Mode : Off
Continuous Drive : Continuous
Focus Mode : Manual Focus (3)
Record Mode : CR2+JPEG
Canon Image Size : Large
Easy Mode : Still Image
Digital Zoom : None
Contrast : +1
Saturation : -1
Camera ISO : Auto
Metering Mode : Center-weighted average
Focus Range : Not Known
Canon Exposure Mode : Easy
Lens Type : Canon EF 28-80mm f/3.5-5.6
Long Focal : 58 mm
Short Focal : 58 mm
Focal Units : 1/mm
Max Aperture : 2
Min Aperture : 2
Flash Activity : 0
Flash Bits : (none)
Zoom Source Width : 0
Zoom Target Width : 0
Manual Flash Output : n/a
Color Tone : +1
SRAW Quality : n/a
Auto ISO : 100
Base ISO : 476
Measured EV : 9.38
Target Aperture : 2
Target Exposure Time : 1/813
Exposure Compensation : 0
White Balance : Auto
Slow Shutter : None
Shot Number In Continuous Burst : 0
Optical Zoom Code : n/a
Camera Temperature : 47 C
Flash Guide Number : 0
Flash Exposure Compensation : 0
Auto Exposure Bracketing : Off
AEB Bracket Value : 0
Control Mode : Camera Local Control
Measured EV 2 : 9.25
Bulb Duration : 0
Camera Type : EOS High-end
ND Filter : Unknown (-1)
Canon Image Type : Canon EOS 5D Mark II
Canon Firmware Version : Firmware Version 2.0.7
Owner Name :
Camera Body No. :
Flash Metering Mode : Off
Camera Orientation : Horizontal (normal)
Focus Distance Upper : 0 m
Focus Distance Lower : 0 m
Firmware Version : 2.0.7
File Index : 210
Directory Index : 100
Canon Model ID : EOS 5D Mark II
Thumbnail Image Valid Area : 0 159 7 112
Serial Number Format : Format 2
AF Area Mode : Off (Manual Focus)
Num AF Points : 9
Valid AF Points : 9
Canon Image Width : 5616
Canon Image Height : 3744
AF Image Width : 5616
AF Image Height : 3744
AF Area Widths : 84 84 101 84 84 84 101 84 123
AF Area Heights : 101 101 74 101 101 101 74 101 131
AF Area X Positions : -1173 -561 0 561 1173 561 0 -561 0
AF Area Y Positions : 0 280 501 280 0 -280 -501 -280 0
AF Points In Focus : (none)
AF Points Selected : 8
Original Decision Data Offset : 0
Bracket Mode : Off
Bracket Value : 0
Bracket Shot Number : 0
Raw Jpg Size : Large
Long Exposure Noise Reduction 2 : Off
WB Bracket Mode : Off
WB Bracket Value AB : 0
WB Bracket Value GM : 0
Live View Shooting : On
Flash Exposure Lock : Off
Lens Model : 58-58mm
Internal Serial Number :
Dust Removal Data : (Binary data 1024 bytes, use -b option to extract)
Exposure Level Increments : 1/3 Stop
ISO Speed Increments : 1/3 Stop
ISO Expansion : On
AEB Auto Cancel : On
AEB Sequence : -,0,+
Safety Shift : Disable
Flash Sync Speed Av : Auto
Long Exposure Noise Reduction : Off
High ISO Noise Reduction : Standard
Highlight Tone Priority : Disable
Auto Lighting Optimizer : Disable
Lens Drive No AF : Focus search on
Lens AF Stop Button : AF stop
AF Point Selection Method : Normal
Superimposed Display : On
AF Assist Beam : Emits
Mirror Lockup : Disable
AF Point Area Expansion : Enable
AF Microadjustment : Adjust by lens; 2; 0; 0; 0
Shutter Button AF On Button : Metering + AF start
AF On AE Lock Button Switch : Disable
Set Button When Shooting : Normal (disabled)
Dial Direction Tv Av : Normal
Focusing Screen : Eg-A
Add Original Decision Data : Off
Assign Func Button : LCD brightness
Tone Curve : Standard
Sharpness : 4
Sharpness Frequency : n/a
Sensor Red Level : 0
Sensor Blue Level : 0
White Balance Red : 0
White Balance Blue : 0
Color Temperature : 5200
Picture Style : User Def. 1
Digital Gain : 0
WB Shift AB : -5
WB Shift GM : 0
Measured RGGB : 950 1024 1024 268
VRD Offset : 0
Sensor Width : 5792
Sensor Height : 3804
Sensor Left Border : 168
Sensor Top Border : 56
Sensor Right Border : 5783
Sensor Bottom Border : 3799
Black Mask Left Border : 0
Black Mask Top Border : 0
Black Mask Right Border : 0
Black Mask Bottom Border : 0
Color Data Version : 6 (50D/5DmkII)
WB RGGB Levels As Shot : 1872 1024 1024 2310
Color Temp As Shot : 3775
WB RGGB Levels Auto : 2013 1024 1024 2101
Color Temp Auto : 4158
WB RGGB Levels Measured : 2011 1024 1023 2099
Color Temp Measured : 4158
WB RGGB Levels Daylight : 2265 1024 1024 1725
Color Temp Daylight : 5200
WB RGGB Levels Shade : 2621 1024 1024 1425
Color Temp Shade : 7000
WB RGGB Levels Cloudy : 2444 1024 1024 1553
Color Temp Cloudy : 6000
WB RGGB Levels Tungsten : 1682 1078 1078 2855
Color Temp Tungsten : 3200
WB RGGB Levels Fluorescent : 1931 1024 1024 2521
Color Temp Fluorescent : 3674
WB RGGB Levels Kelvin : 2265 1024 1024 1725
Color Temp Kelvin : 5211
WB RGGB Levels Flash : 2461 1024 1024 1538
Color Temp Flash : 6108
Raw Measured RGGB : 81943 84740 85190 23228
AF Micro Adj Active : Unknown (2)
AF Micro Adj Value : 0
Peripheral Lighting : Off
Peripheral Lighting Value : 0
Original Image Width : 5616
Original Image Height : 3744
Peripheral Lighting Setting : Off
User Comment :
Sub Sec Time : 41
Sub Sec Time Original : 41
Sub Sec Time Digitized : 41
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 5616
Exif Image Height : 3744
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Focal Plane X Resolution : 3849.211789
Focal Plane Y Resolution : 3908.141962
Focal Plane Resolution Unit : inches
Custom Rendered : Normal
Exposure Mode : Auto
Scene Capture Type : Standard
GPS Version ID : 2.2.0.0
Compression : JPEG (old-style)
Thumbnail Offset : 10572
Thumbnail Length : 10362
Image Width : 5616
Image Height : 3744
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 2.0
Drive Mode : Continuous Shooting
File Number : 100-0210
Image Size : 5616x3744
Lens : 58.0 mm
Lens ID : Canon EF 28-80mm f/3.5-5.6
Scale Factor To 35 mm Equivalent: 1.0
Shooting Mode : Still Image
Shutter Speed : 1/800
Create Date : 2010:09:06 10:38:35.41
Date/Time Original : 2010:09:06 10:38:35.41
Modify Date : 2010:09:06 10:38:35.41
Thumbnail Image : (Binary data 10362 bytes, use -b option to extract)
WB RGGB Levels : 1872 1024 1024 2310
Blue Balance : 2.255859
Circle Of Confusion : 0.031 mm
Field Of View : 35.3 deg
Focal Length : 58.0 mm (35 mm equivalent: 56.6 mm)
Hyperfocal Distance : 54.63 m
Lens : 58.0 mm (35 mm equivalent: 56.6 mm)
Light Value : 9.3
Red Balance : 1.828125
