Два месяца назад купил 5D Mark 2. Встроенное ПО 1.1.0 Надо ли теперь обновить прошивку на эту 1.2.4:
http://web.canon.jp/imaging/eosd/firm-e/eos5dmk2/firmware.html
Обновление для canon 5D Mark 2
Всего 103 сообщ.
Re[sveigo]:
от: sveigo
обновите. почему нет? занимает 5 минут.
Firmware Version 1.1.0 includes the following improvements and fixes:
Includes a function to enable the manual exposure setting when shooting movies.
*When shooting movies in manual (M) mode, the shutter speed *1, the lens aperture value *2, and the ISO speed *3 can be freely set to allow a greater flexibility.
Notes:
*1 Shutter speed range: 1/30 sec. to 1/4000 sec.
*2 Lens aperture range: maximum to minimum aperture value of the lens used
*3 ISO speed range:
Auto: ISO 100 to 6400 set automatically
Manual: ISO 100 to 6400, H1
Disables the function of the depth-of-field preview button when images are played back or when the menu screen is displayed on the LCD panel.
*There are indications that images being reviewed or the menu screen may suddenly disappear from the LCD panel. As this phenomenon may be caused by accidentally pressing the depth-of-field preview button, this firmware update disables the function of the depth of field preview to address this issue.
Fixes a phenomenon where the peripheral illumination of images cannot be properly corrected, even if the images were captured with the lens Peripheral Illumination Correction function set to Enable.
*Firmware Version 1.1.0 fixes a phenomenon where peripheral illumination may not be properly corrected due the type of lens used and shooting conditions.
Fixes the algorithms of the Auto Lighting Optimizer function when Custom Function C.Fn II-3 Highlight tone priority is enabled.
Fixes incorrect indications on the Arabic, Romanian, Spanish, and Ukrainian menu screens.
Changes the battery information displayed on the camera when using the optional Battery Grip BG-E6.
*If only one LP-E6 battery pack is installed in the Battery Grip BG-E6, the battery information for the empty battery slot shows the error message, Cannot communicate with battery. However, with this firmware update, this error message no longer appears, even if only one LP-E6 battery pack is installed.Подробнее
Re[Пёс]:
Заряжаю аккумулятор, после чего сделаю обновление. Действительно есть такая рекомендация на официальном сайте - Firmware Version 1.2.4 is for cameras with firmware up to version 1.1.0
Re[sveigo]:
Для тех кто не знает как обновить ПО. Сначала форматируем флешку в своем фотике. Отключаем аппарат и вынимаем. Скачиваем обновление с официального сайта http://web.canon.jp/imaging/eosd/firm-e/eos5dmk2/firmware.html Раскрываем скачанный файл 5d200124.fir и перносим на флешку, вставленную в кардридер. После этого вставляем флешку в фотоаппарат, включаем, находим в меню нужную позицию и обновляем! Картинки на официальном сайте. Аккумулятор должен быть полностью заряжен, во время обновления кнопки не нажимаем!
Re[sveigo]:
Я обновился с заводской 1.1.0 на 1.2.4 в свое время. Естественно разницы никакой, что собственно и написанно в описании прошивки. ;)
Re[sveigo]:
После обновления выключаем камеру и вытаскиваем аккумулятор на 2 секунды.
Re[sveigo]:
После того, как аккумулятор вставляем на место, не мешает отформатировать карту памяти. На всякий случай. Делаем пробный снимок, смотрим. Если все ОК, тогда считанем, что перепрошивка прошла удачно. Всем удачных снимков!
Re[sveigo]:
А язык русский будет присутствовать? И стоит ли прошивать если и старая прошивка работает хорошо?!
Re[Sergey67rus]:
Да фиг знает. У некоторых после перепрошивки матрица СФ стала и появился интернет в камере. А так если вы не пользуетесь тем девайсом что в прошивке указан - можно и не перепрошивать.
Re[sveigo]:
Вчера пытался перепрошить камеру - получилось раза с 10 только. Форматировал карту в фотике, затем записывал через картридер файл прошивки на карту, вновь вставлял в аппарат, а камера прошивки не видела. После 10 раза (тупо - проделывания одних и тех же действий), камера все-таки увидела прошивку и все получилось. Ни кто с такой ерундой не сталкивался?
Re[Lefon]:
А может Вы только на десятый раз файл распаковали? ;)
Re[Анд_рей]:
от: Анд_рей
Очень смешно!
Re[Lefon]:
от: Lefon
Очень смешно!
Ну как вариант ;)
У меня залилась "по шнуру" с первого раза.
Re[sveigo]:
По ходу:
А когда должна выйти новая версия прошивки?
Читал уже очень давно, что ожидается версия, в которой видео будет поддерживать 25 кадров. По памяти это должно было быть вначале года (возможно ошибаюсь). Сейчас не могу найти этой темы. Уточните, кто помнит.
Re[Вадим111]:
от:Вадим111
По ходу:
Читал уже очень давно, что ожидается версия, в которой видео будет поддерживать 25 кадров. По памяти это должно было быть вначале года (возможно ошибаюсь). Сейчас не могу найти этой темы. Уточните, кто помнит.Подробнее
Вроде как до весны отложили (апрель-май, где такие сроки проскакивали)...
Re[sveigo]:
Вообще в любой технике новая проша, лучше чем предыдущая.
1.2.4. поставил сразу, полет нормальный :D
Re[Дмитрий 02]:
от: Дмитрий 02
Полет обещают еще лучше
[quot]The new firmware for the 5D Mark II will arrive the week of March 17, 2010. This seems to be close to the NAB show.
The information briefly appeared on the Canon UK web site, it’s now gone at the URL I was given.
Features
Live Histogram for Video
Sound Level Control
24p/25p
No word on 60fps yet.
I’ve also heard there may be sound level meters, count this feature as a CR2 rumor.
More info on the subject to come.[/quot]
http://www.canonrumors.com/2010/02/5d-mark-ii-firmware-release/
Re[sveigo]:
AF в видео нормального наверное не дождёмся...
Re[Klon001]:
AF в видео - это зло
Re[sveigo]:
del (повтор написал)
