Все работает вроде нормально
обновление и инструкция тут
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_sid=_Z6K3BBh&p_lva=&p_faqid=13231&p_created=1104788863&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NSZwX3Byb2RfbHZsMT0xOSZwX3Byb2RfbHZsMj01NiZwX2NhdF9sdmwxPTIzJnBfcGFnZT0x&p_li=
Обновил прошивку на D70 с 1.0.2 до 1.0.3
Всего 3 сообщ.
Показаны 1 - 3
Re: Обновил прошивку на D70 с 1.0.2 до 1.0.3
Англицкий не знаю. Что изменилось?
Re: Re: Обновил прошивку на D70 с 1.0.2 до 1.0.3
от: ДДА
поправили цвета для шопа при работе с жпегом
Nikon D70 Firmware
This data is protected by a Nikon Corporation License Agreement. Be sure to read the following License Agreement before proceeding with the download. By proceeding with the download, you indicate your agreement to the terms of this License agreement.
This service provides software for upgrading D70 Firmware B to version 1.03.
If the firmware installed in your camera is already the version noted above, this upgrade is not necessary.
Firmware B version 1.03 is compatible with all existing versions of Firmware A
However, it is recommended to use Firmware B version 1.03 in combination with the latest Firmware A.
Changes to Firmware B version 1.03
When the mode dial was set to an exposure mode (P, S, A, or M) and II selected for the Color mode setting in the Custom item of the Optimize image menu, and then an option other than Custom (such as Portrait) selected from the Optimize image menu, JPEG images captured after this procedure were recognized as having the Adobe RGB color space when opened in applications with a color-management function such as Adobe Photoshop. This problem has been corrected.
Instructions:
For instructions to download, expand or install this update please see:Macintosh http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=13230
Windows
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=13231
PrecautionDo not use a Microdrive to upgrade firmware.
