http://bibblelabs.com/BibbleProSetup42.zip (23,37Mb)
New:
Added Full support for Nikon D2X including correct white balance.
Added support for Canon G6, Pro1, S60, S70 and Rebel XT 350D
Added support for the Minolta Maxxum 7D.
Added support for Pentax *ist DS
Added support for Olympus Evolt, C8080
Added Tethered shooting support for 20D, 1DM2 , 1DSM2 and D2X
Added menu items and hot keys for Temp/Tint Ctrl-F/G (Shift)
Added "(x of y items)" to the window title (for browsers)
Added option to histogram to show histogram for cropped area.
Added Ability to add an output profile, and tag/proof to it (Ie Printers)
Added Option to display composition lines while cropping with related preferences.
Added a button to rotate/crop tool for creating new crop sizes.
Added extension to "save settings" dialogs if none selected.
Added hotkeys to toggle full screen/preview image size
Added file type filtering when sending folders to work queues or print queues. This honors the current browser file filter. Batch filter is still done per the batch's configuration.
Added a list of recent browser and files to the File menu.
Added a list of open windows to the Window menu.
Added ability to modify current curve point with arrow keys.
Added Midtone/Gamma slider to curves.
Added/revisited Window menu functions.
Added ability to sort the browser by EXIF information (with a slight loading delay).
Added an option to the browser context menu for queuing/removing selected images from a work queue.
Added a button to thumb controls for queuing/removing the thumb from a work queue.
Added a "disk full" warning message when batching and saving images.
Added support for Raw+Jpeg files. When enabled all of the file and renaming operations work on the pair of files.
Added a tool button to pause/resume browser preview generation.
Added several browser optimizations and associated controls.
Added Crash reporting tool to send crash dump and relevant data to Bibble labs if a problem occurs.
Added a prompt to select what to do with work queue images that are not currently available (offline or deleted). They can be removed from the queue or not.
Added Mouse wheel for browser thumbs.
Enhanced:
Change tone curves extremities for less clamping.
Changed mouse wheel while over slider to be small increment (SHIFT = large increment, CTRL = reverse context for serge)
Changed local settings filename to include original extension. dsc_0001.nef.bib
Changed thumbnail selection behavior on Windows.
Changed batches to flush settings before copying files via Copy Output. This way the latest version of the .bib file is copied.
Changed default name for "save settings" dialogs to current filename.
Changed behavior of White Balance options to remember the last Custom WB you used.
Changed windows thread priorities for better response in foreground, and less CPU hogging when in background.
Change Made to adjustments to prevent clipped highlights and loss of color components in saturated colors.
Re-enable sharpening for jpegs.
Sped up processing of images with custom WB, improved control responsiveness.
Sped up browser response when applying settings to multiple thumbs.
Fixed:
Fixed 8 bit import to Photoshop via plugin
Fixed problem with noise sliders on Macintosh (Funny colors)
Fixed problem with browser preview bar stalling.
Fixed crash in photoshop plugin.
Fixed problem with Yellow Highlight recovery regions.
Fixed Problem with .crw date/times with no .thm
Fixed problem with .crw autorotation
Fixed lack of speedy thumbnails for Oly E1 in browser.
Fixed negative numbers in RGB status display.
Fixed memory leak relating to settings windows.
Fixed problem causing Photoshop plug-in to always use standard Bibble folder location.
Fixed inability to export to external editor in 8 bit from the file menu.
Fixed a number of problems relating the Photoshop plug in.
Fixed problem with Olympus images looking odd initially with adjusted WB.
Fixed Crash when custom color profile was missing.
Fixed D1/x/h/100 Highlight recovery constants.
Fixed "Bibble Disappears Crash" with exif jpegs with Tiff/Oldjpeg thumbs
Fixed Permanent cats for jpegs from supported mfgrs, but unsupported camera.
Fixed Unicode directory names in browser.
Fixed a crash when editing rename formats in preferences.
Fixed a problem where a first image was selected but not highlighted.
Fixed a problem where an image remained open but disconnected when it was the last de-selected item in the browser.
Fixed problem causing black or dark bands in CRW Files.
Fixed a crash when double-clicking thumbnails.
Fixed problem when renaming to Unicode filenames.
Fixed a problem that prevented crop sizes from appearing when first running the program.
Fixed a problem the prevented crop sizes from appearing after reinstalling or recreating the bibble-user directory.
Fixed problem causing overwrite warning to not work sometimes.
Fixed problem causing Minolta thumbnails to not extract.
Fixed problem preventing Minolta A2 WB presets from not working (Green?)
Fixed tab-order in preferences panels.
Fixed a problem where some exif rename tags where blank.
Fixed a bug where custom sized batch images were the wrong size when originating from a portrait image.
Fixed extracting of Pentax Thumbnails.
Fixed a myriad of problem relating to Copy/Paste of WB settings.
Fixed problem with black point of *ist image with long exposure or Noise reduction
Новый Bibble Pro 4.2
Всего 4 сообщ.
Показаны 1 - 4
Re: Новый Bibble Pro 4.2
О, спасибо! Сам следил за обновлениями, но всетаки пропустил :)
Дописал попозже:
К кого-нибудь была такая проблема, что любое открытое изображение получается как бы свернуто в полоску и никак его вернуть в нормальный вид нельзя, сначала дома такая штука случилась, потом на работе, ничего не понимаю. Вот с новой версией та же проблема. :(
Оказалось Bibble не дружит с некоторыми темами Windows.
Поменял оформление на дрегое (тоже не родное) теперь все показывает нормально!
Тут это обсуждалось:
http://support.bibblelabs.com/webboard/viewtopic.php?t=2421
Дописал попозже:
извените за глупый вопрос: что за продукт это "bible", где его исползуют ?
Re: Re: Новый Bibble Pro 4.2
от: Robis
извените за глупый вопрос: что за продукт это "bible", где его исползуют ?![]()
RAW конвертор. Но это для взрослых! :D
