http://web.canon.jp/Imaging/BeBit-e.html
EOS-1D Mark II N Firmware Update Version 1.0.4
What's new?
This firmware update (version 1.0.4) includes the following improvements:
Fixes the phenomenon where the images are monochrome.
Fixes the phenomenon where the images are overexposed when using Focusing Screen Ec-S.
EOS 5D Firmware Update Version 1.0.5
Firmware specification changes
This firmware update incorporates the following improvements:
Fixes the phenomenon where the shutter cannot be released when using the EOS 5D + EF85mm F1.2L + Speedlite580EX. (*)
*: For EOS 5D units that contain 1 in the fifth digit of the body number (e.g., XXXX1XXXXX), the correction will not be reflected even if the firmware is updated to Version 1.0.5.
If you have an affected product that you would like to have fixed, please contact the nearest Canon Service Center.
This firmware update applies to cameras with firmware versions up to 1.0.4 installed. If your camera's firmware is already version 1.0.5, it is not necessary to perform this update.
EOS 30D Firmware Update
We learned that some products have problems displaying Simplified Chinese or Traditional Chinese on the LCD monitor when the display language is set to these languages.
This problem can be corrected by overwriting the character data stored in the camera. So we request that users experiencing this problem overwrite the firmware referring to the following information.
Note:
The Version of this firmware is 1.0.4.
This announcement concerns all the products that have this problem regardless of the firmware version.
We request that all users experiencing this problem overwrite the firmware, even if the camera's firmware is already 1.0.4.
The functions of the camera will not be changed by overwriting the firmware Version 1.0.4 with this Version 1.0.4.
