от:iTuner
Для начала про HSS
Это не функция TTL, это системная функция накамерного света, синхросигнал подается до открытия шторки, только и всего
просто накамерные вспышки получают этот сигнал не в аналоговом виде а в цифровых таймингах а у Canon еще и вторая шторка так же кодируется.Подробнее
Давайте посмотрим как сделано HSS у Profoto.
Для начала B2:
Once our exposure settings goes above a shutter speed of 1/200 second, a flash with High-Speed Sync (HSS) is required.
Many photographers will use an HSS enabled speedlight for this. But doing so, they often battle with inconsistent exposures, limited power and slow recycle times.
There are reasons for this. In HSS Mode, the flash must fire a great number of times during the short shutter window in order to expose the film or chip evenly across the frame. This means that the flash must be able to deliver a powerful burst of light with a very short duration, and repeat that over and over again, all within 1/500 of a second or faster. A typical speedlight doesn’t have the horse power to make this happen. If it does, it slows the recycle times down to a crawl. Add a bit of distance and a softbox to the equation, and a speedlight just crashes and burns.
https://profoto.com/us/profoto-stories/whats-different-when-youre-shooting-with-high-speed-sync
B2 - стробит. Может быть у B1 сделано иначе?
Profoto’s new solution for the B1 Off-Camera Flash has all of the benefits and none of the limitations. The B1 itself is about ten times as powerful as the average speedlight and fast enough to keep up with your camera. With the new Profoto HSS upgrade installed, you switch to HSS Mode with a simple button-press. You will then be able to shoot at shutter as fast as 1/8000 of a second.
But it does not stop there. Profoto HSS is a unique, patent-pending technology, providing an extremely fast series of flash pulses. What this means in practice is that you get an extremely consistent exposure with no measurable variation over the image.
https://profoto.com/us/profoto-stories/profoto-hss.-it-is-here.-start-using-it-today
Получается и B1 тоже стробит.
И как быть с:
от: iTuner
HSS таким образом решена почти у всех
Получается как минимум у Profoto сделано иначе.
У Foris заявлен отдельный режим:
Switchable to long flash durations up to 1/210 s (1/80 s at t 0,1).
Кстати данные разнятся, в одном месте заявлено так, в другом:
Switchable to long flash durations up to 1/400 s (1/120 s @ t 0.1)
Понятно, что описания ещё сырые. Я посмотрел мануал и вот что там написано:
Flash durations
1/10,000–1/1,000 s (t0.5) STD mode
1/50,000–1/1,800 s (t0.5) FREEZE mode
1/400–1/240 s (t0.5) FP mode 1/120 (t0,1)
Собственно надо ждать финальных версий и реальных тестов живых устройств.
А насчёт TTL и HSS на сайте пишут так:
TTL flash control for Canon, Nikon & Sony system cameras via optional Hensel Io TTL transceiver (incl. TTL-lock & HSS)
А вот, что пишут в мауале про режимы работы
The FREEZE mode
The FP mode
The TTL mode
The STD mode
Разъяснений различий между режимами - нет. Ждём-с.
Единственное что можно сказать, у того же Profoto 2 режима - Color и Freeze. А здесь 4. Я не говорю, хорошо это или плохо. Я пока не до конца понимаю различия между этими 4 режимами.
Так что реализация у Hensel и Profoto чуток разная (а может и не чуток). Я определённо могу сказать, что Вы ошибаетесь. Foris сделан не как все.
А хорошо это или нет - рано судить.
от: iTuner
Обратите внимание, трансмиттеры системные, пока только для Canon и Nikon, вот они и декодируют этот сигнал и поджигают вспышку до открытия шторки
Пока не понятно. В мануале нет никаких указаний на ограничения функциональности при использовании обычной синхронизации.
от: iTuner
И все относительно мощные вспышки с HSS используют длинный импульс для работы в этом режиме и у Брона и у Элина и у Джинбей и у Баффа именно так работает HSS
И где у Баффа Е640 HSS? Покажите, пожалуйста, искал не нашёл:
https://www.paulcbuff.com/manuals/Flashunits/e640.pdf
Вообще, по моему, Link первый у Paul C. Buff у кого заявлено HSS.
от:iTuner
По поводу батареек в этом монстре:
Да кому надо такую вспышку на батарейке? к ней еще оснастку надо соответствующую ее весу и бригаду осветителей-культуристов :) Ну, допустим сколько то найдется желающих, но очень ограниченное количество.Подробнее
Опят смотрим на Link, которым Вы восхищались:
https://club.foto.ru/forum/view_topic.php?topic_id=678082&page=15#listStart
Мощность 800 Дж (это полступени разницы с Foris), вес 3,8 кг.
Для справки, вес софт-бокса 90х120 - 1,2 кг.
Hensel Grand 120 (не самый большой) - 2,8 кг.
А Profoto Giant Reflector 300 так вообще 18 кг.
Собственно что 800 Дж, что 1000 Дж для того и нужны, чтоб большие насадки использовать. И используют их не только в студии. Это вообще современный тренд - снимать где угодно.
Для меня очевидно, что Link и Foris - прямые конкуренты. Просто Вам нравится марка Paul C. Buff и Вы пытаетесь топить за неё.
Я же таких пристрастий не имею, и считаю что оба аппарата интересные.
"На бумаге" Foris помощнее, импульс покороче.
Кстати диапазон регулирования у Link в HSS заявлен всего 3 ступени. что-то я сомневаюсь, что HSS у Link сделан также, как у Foris.
https://www.paulcbuff.com/Flash-Units/LINK-Flash-Unit.html
от: iTuner
Я же писал про студию, где нужна такая мощность.
Уже разобрались. Современная тенденция - снимаем везде. Это объективный факт. Посмотрите современные журналы - 4/5 постановочных снимков сняты не в фотостудиях, а на локациях. И большинство с поставленным светом.
И опять, почему 800 Дж Link имеет смысл, а 1000 Дж Foris - нет?
от: iTuner
По поводу заморозки:
На киловатте она как обычна вспышка 1/1,800 s t.5, t.1 будет в районе 1/1000c t.1? не короче/
1/1000 (0.1) - это достаточно для большинства практических применений. 1/3000 - для подавляющего большинства. Так что возможно с половинной мощности будет морозить всё. Ну кроме кончиков крыльев колибри.
Хотя, повторюсь, надо ждать живых экземпляров и реальных замеров.
от: iTuner
самый короткий импульс на 4 ваттах... где у нее еще вменяемая длительность фиг знает
другие быстрые вспышки будут не сильно отставать по стопам, но будут стоить дешевле в разы
1/50000 на минимальной мощности - это рекламный ход. Все мммм люди с годоксами рассказывают про короткие импульсы. Только у них на минимуме света совсем не будет.
А Foris на 1/2, на 1/4 даст и света прилично и импульс очень короткий.
Ну и опять напомню Вам про рекламируемый Вами Link - у него импульс заметно длиннее на всех мощностях.
от: iTuner
Такое впечатление что они решили заморочиться, только вот забыли про здравый смысл - где рынок для таких приборов?
Примерно там же где у Link.
от: iTuner
У Брона и Профото они не заберут клиентов и тем более от китайцев не смогут кого то переманить.
Жизнь покажет. Multublitz и Bowens уже ушли с рынка. Посмотрим, кто ещё отвалится.
Утверждать, что это не будет Hensel я не буду. Но и с заупокойной подожду.
ps Извиняюсь за большой пост.
