итак, есть вероятность (не высока но есть) что к НГ Никон представит беззеркалку полный кадр. строго говоря, не совсем БЗ а точнее совсем не БЗ но идея понятна :)
ожидаемые спецификации:
* Nikon FM2 like design
* 16,2MP 36x23,9 full frame sensor (same as in the D4)
* SD memory card
* 2016-pixel RGB image sensor
* 9-cell framing grid display
* 3D color matrix metering II
* Native ISO range: 100-12800 (incl. ISO 50 and ISO 108,200)
* 5.5 fps for up to 100 shots
* 3.2" LCD screen
* Battery:EN-EL14
* Dimensions: 143,5 x 110 x 66,5mm
* Weight: 765g
* It will come with a new AF-S Nikkor 50mm f/1.8G lens (again, not clear what mount the new lens will have)
* Standard F-mount
* Pentaprism viewfinder (meaning the camera will not be mirrorless)
* The camera will meter even with non-AI lenses down to full aperture
* The camera will ship with a new special edition Nikkor 50mm f/1.8G lens to match the look/design of the body
* The camera will have physical controls and excellent build quality (which explains the 765g weight)
* Expeed 3 processor
* Nikon calls it a "hybrid" camera - not sure what exactly they mean with that
* The announcement most likely will take place in the next 1-3 weeks
ист
интрига закручивается!
