Nikon SB-300
Nikon Speedlight SB-300
nEw! - Доступна для пред-заказа по Америке
Характеристики:
i-TTL Flash Exposure Control
Ведущее число: 59' (18м) при ISO 100
Покрытие для 27-200mm камер с FX-сенсором (полнокадровых)
Время перезарядки - 3.5 сек (Ni-MH)
Время перезарядки - 4 сек (Alkaline)
120° Tilting Head - поворот головы
Работает на 2х AAA батарейках
Re[don Quijote de la Mancha]:
The Nikon SB-300 AF Speedlight is a lightweight on-camera flash, designed for use with Nikon cameras with i-TTL support. It has a guide number of 59' at ISO 100 and is compatible with DX and FX sensors with coverage from 27mm-200mm on a FX-format camera.
Attaching the SB-300 to your camera will provide you with many more possibilities than a pop-up flash. It supports Nikon's i-TTL technology which allows for more accurate metering for a proper exposure and white balance setting. Additionally, cameras with support for Nikon's Creative Lighting System can utilize the fill-flash function to get rid of unwanted shadows on your subject.
The 120° tilting head is vital to what makes this unit more useful than a pop-up flash. Being able to tilt the head allows for bouncing light off a ceiling or wall for soft, even light on your subject.
Designed to be compact, it works well on smaller cameras. And with a weight of only 3.4 ounces, it will not add much to your camera kit. The use of two AAA batteries contributes to this by not requiring the use of AA batteries used in larger flashes. It also comes with the Nikon SS-DC1 Soft Case for storage.
Zoom flash head provides wide-angle coverage from 18mm in DX-format cameras or 27mm in FX-format
Recycling time of 4 seconds with alkaline batteries, or only 3.5 seconds with Ni-MH batteries
At least 70 flashes with alkaline batteries, or 110 flashes with Ni-MH batteries
Flash-ready light will alert you when flash is ready to fire
Foot lock lever for secure mounting to the camera
Ссылки на обзоры:
Ссылки на обзоры: [РЕЗЕРВИРОВАННО]
Доп.информация:
Доп.информация: [РЕЗЕРВИРОВАННО]
[УДАЛЕНО]
Re[Михаил Романовский]:
от: Михаил Романовский
[УДАЛЕНО]
http://www.ixbt.com/news/hard/index.shtml?17/06/11
