www.dpreview.com :
200mm, f/2.8
200mm, f/4
www.slrgear.com
Nikon 70-200mm f/2.8G AF-S ED VR II:
"The lens produces exceptionally sharp images at ƒ/2.8, from 70mm through to 200mm. At this aperture its ''best'' performance comes at 70mm, with just over 1 blur unit in the center and 1.5 blur units in the corners; the center becomes marginally less sharp as the lens is zoomed in to 200mm, but whether this is noteworthy is doubtful - even at 200mm, we're seeing just 1.5 blur units across the frame. Of the lenses we've tested across all manufacturers, none have achieved this performance at ƒ/2.8."
Canon EF 70-200mm f/2.8L IS II USM:
"Wide open at ƒ/2.8, the lens shows its best performance at 70mm, with a generous sweet spot of 1-1.5 blur units in the center of the frame, degrading slightly to some corner softness; around 2 blur units. From 100mm and up we note increasing corner softness and a lessening of that sharp sweet spot until it's just over 1.5 blur units in the center and 2 in the corners at 200mm."
примеры с D700:
DSC_1137_1200 by -OlAf-, on Flickr
DSC_0157_1200 by -OlAf-, on Flickr
DSC_0923_1200 by -OlAf-, on Flickr
DSC_0129_1200 by -OlAf-, on Flickr
