Nikkor AIS 28/2
Всего 2 сообщ.
Показаны 1 - 2
Nikkor AIS 28/2
Кто что знает, расскажите пожалуйста. Собираюсь покупать.
Re: Nikkor AIS 28/2
от: Богачев Игорь Николаевич
Лично я склонен верить Рорслетту (правда тут речь о AI):
The high-speed 28 Nikkor is unusual in having its close-range correction (CRC) executed with the front elements, not with the rear as the case is with other wide-angles. It offers outstandingly sharp images and these are produced at all aperture settings from f/2 to f/8 with just a trace of corner softness at the wider settings. Field curvature is modest in terms of wide-angle lenses. Peak performance occurs between f/4 and f/5.6. When stopped down beyond f/11, sharpness suffers however. This lens is unusually resistant to flare and ghosting and eminently suitable for shooting directly into the sun. Never catching the buyers' fancy, this is an uncommon lens which is indicative of the perils of free enterprise.
I recently managed to get my 28/2 outfitted with a matrix CPU chip, which made it compatible to all my newer Nikons including the D1X/D1H. Recommend as a small and inexpensive alternative to the 28/1.4.
On a digital camera, some colour fringing occasionally can be observed. D2X shows this quite clearly. Hence I rated the 28/2 a little lower for this camera, but of course if you are not bothered with CA, don't listen to me here. If troublesome, the CA issue can be mitigated by digital post-processing. See Brian Caldwell's site for tutorial and further details.
