Nikkor ai 28mm f/3.5
Всего 4 сообщ.
Показаны 1 - 4
подскажите пожалуйста, как он по картинке? есть возможность обзавестись.. стоит ли?
Re[fu2re]:
никто не знае? (
Re[fu2re]:
Вот что пишет Бьорн Рорслетт:
Источник: http://www.naturfotograf.com/index2.html
A venerable old-timer launched as early as 1960 for the Nikon F, the 28/3.5 stayed long in the product line. Several optical versions exist. Most models cope extremely well with against-the-light shooting, showing a small degree of flare and ghosting. Central image sharpness is generally good wide open and excellent by f/5.6-f/8, but corners suffer light fall-off and are less sharp. The last version got an enlarged rear element to mitigate this problem.
The 28/3.5 performs excellently on the newer D2X and D200 digital bodies, giving very sharp and crisp images with just ever so slight trace of CA. Shooting into directly into the sun with this lens is a breeze. This lens is one I nearly always carry with me on field trips.
With the newer breed of FX cameras, the tendency for the 28/3.5 to show field curvature and loss of sharpness towards the corners becomes much more pronounced. Accordingly I have downrated this lens slightly for FX use. Still you can get very good imagery provided the lens is stopped well down and you don't expect it to deliver flat-field performance.Подробнее
Re[EugeneB]:
а так, по личным ощущениям?
