Lightroom 5.5
Lightroom 5.5
http://www.adobe.com/support/downloads/thankyou.jsp?ftpID=5792&fileID=5819
• Support for syncing star ratings and custom sort order to Lightroom mobile and Lightroom web.
• Fixes for bugs introduced in earlier versions of Lightroom 5.
• Camera support for additional new lenses and cameras.
Release Notes
New Camera Support in Lightroom 5.5
Canon PowerShot G1 X Mark II
Fujifilm FinePix S1
Nikon 1 J4
Nikon 1 S2
Nikon 1 V3
Olympus OM-D E-M10
Panasonic DMC-GH4
Pentax 645Z
Samsung NX3000
Sony DSC-RX100 III
Sony A7S (ILCE-7S)
Sony Alpha SLT-A77 II (ILCA-77M2)
New Lens Profile Support in Lightroom 5.5
Mount Name
Canon Sigma 50m F1.4 DG HSM A014
Canon Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014
Canon Tamron 16-300mm F3.5-6.3 Dill VC PZD MACRO B0163
Fujifilm Fujifilm Tele Conversion Lens TCL-X100
Nikon Nikon 1 NIKKOR VR 10-30mm f3.5-5.6 PD-ZOOM
Nikon Nikon AF-S DX NIKKOR 18-300mm f/3.5-6.3G ED VR
Nikon Sigma 50mm F1.4 DG HSM A014
Nikon Sigma 18-200 F3.5-6.3 DC MACRO OS HSM C014
Nikon Tamron 16-300mm F3.5-6.3 Dill VC PZD MACRO B016N
Nikon Tamron SP 150-600mm F5-6.3 Di VC USD A011N
Pentax Sigma 30mm F.14 DC HSM A013
Sigma Sigma 50mm F1.4 DG HSM A014
Sigma Sigma 18-200mm F3.5-6.3 DC MACRO OS HSM C014
Sony Alpha Sigma 30mm F1.4 DC HSM A013
Sony Alpha Sony Alpha 28-75mm F2.8 SAM
Bugs Corrected in Lightroom5.5
Improved responsiveness in Develop module while Lightroom mobile sync is occurring.
Custom Develop module default settings were not syncing correctly to Lightroom mobile.
Initial rendition in Develop would sometimes appear posterized.
Undo function failed and applied a preset instead.
Scaling looked inaccurate when scaling to 200% in Windows.
Manual slideshows sometimes did not advance to the next slide as expected.
Aspect ratio changed when modifying the crop rectangle and when rotating the crop
Image flips between portrait and landscape after switching orientation while shooting tethered with Leica S cameras.
Fixed issue with Fujifilm X-T1 raw images appearing too bright at high ISO settings when using Dynamic Range 200% and 400%. Unfortunately, this fix may affect the appearance of existing images captured with this combination of settings. It is recommended that you (1) purge the Camera Raw cache via the Preferences dialog, and (2) review images shot at ISO settings higher than 1600 for unexpected brightness changes.
Fixed image quality issue (noisy result) when applying spot healing to floating-point (HDR) images.
Fixed issue with reading lossless compressed Nikon raw files (NEF files) from the camera models listed below. Previously, some images could be read but would appear as random noise, whereas attempting to open others would result in an error dialog. You will need to purge your Camera Raw cache via the Preferences dialog.
Nikon D1
Nikon D1H
Nikon D1X
Nikon D2H
Nikon D2Hs
Nikon D2X
Nikon D2Xs
Nikon D100
Nikon D200
Re[foto-boss]:
Как сюда попал Olympus OM-D E-M10?
С его равами точно также работал и 5.4.
Re[foto-boss]:
от: foto-boss
чукча не читатель ? в release notes из 5.4 ( http://blogs.adobe.com/lightroomjournal/2014/04/1277.html )
[quot]
Olympus OM-­D E-­M10 *
* denotes preliminary support[/quot]
Re[deejjjaaaa]:
В том и дело, что разницы ни какой, как неправильно работали профили камеры в лр, не совпадая с родными, так и осталось без изменений.
Re[foto-boss]:
по мне так ps cc 2014 вещь! еще больше оптимизирован и еще быстрее запускается и работает предыдущего ps cc, сам вчера установил и радуюсь 8) а Lightroom 5.5 так себе чуть глючной стало, заметил тупость когда фото увеличиваешь на 100% пока 5 фото так не пройдешь с увеличением работает с замедлением
Re[foto-boss]:
от: foto-boss
так смысл не в разнице для вас лично на глаз, а в разнице с точки зрения производителя... например в аналогичном случае для Olympus E-M1 помeняли dcp профили (вначале, на этапе preliminary support, это были просто копии профилей от E-M5)... А совпадения с тем как работает в плане цвета oem конвертер ожидать странно, в каких-то случаях для каких-то камер совпадение больше, для каких-то меньше.
Re[deejjjaaaa]:
от:deejjjaaaa
Тогда Вы не понимаете просто, что такое профили с конкретными названиями производителя, и что нет ни какого смысла делать профили к конкретной камере с названиями производителя и другим цветом. Тогда и называть по-своему раз они не рабочие и не совпадают. Там явная ошибка с красным каналом.
