http://www.adobe.com/downloads/updates/
Появились обновления, но там только добавлены новые камеры и настроена печать в МакЛеопарде. Похоже больше ничего не изменилось.
Lightroom 1.4 и Camera Raw 4.4 вышли
Всего 12 сообщ.
Показаны 1 - 12
Re[EHS]:
лучше б интерфейс улучшили.. по сравнению с апертурой 2, лайтрум - унылое г..
Ре[ЕHС]:
А почитать реадме сложно?
UPDATE FOR LIGHTROOM 1.4:
Lightroom 1.4 includes corrections for the following issues:
• Compatibility with legacy printer drivers on OS X 10.5 (Leopard) has been updated.
• Previous camera profiles identified in the Calibrate panel of the Develop module may
have displayed poor results at extreme ends of the temperature and tint ranges. A new
camera profile identified as Camera Raw 4.4 is now available and will be applied by
default to all images without existing Camera Raw or Lightroom settings. The creation of
new default profiles will also include the updated Camera Raw 4.4 profile. Images edited
in Camera Raw or Lightroom with earlier profiles will retain the earlier profile value and
visual appearance.
• In previous grayscale conversions the Color Noise setting was disabled and this could
result in an image with excessive noise when grayscale channel mixing is applied. Both
the tool and effect have been enabled in Lightroom 1.4 providing the ability to reduce
noise in grayscale conversions. In order to return to the prior visual appearance, Color
Noise reduction can be set to zero.
Lightroom 1.4 includes the following known issues:
• In the print module, deselecting the Identity Plate option when the option to render on
every image is already applied will result in no change and the Identity Plate will be
applied to every image. To remove the Identity plates, deselect the option to render the
Identity Plates on every image then deselect the Identity Plate option.
http://www.adobe.com/special/photoshop/Lightroom_14_ReadMe.pdf
Ну а в целом конечно Апертура 2 рулит. Я уже не верю что адобе сделает стабильную версию, которая не будет глючить под винду. А под маком там апертура рулит...
visual appearance.
Re[Mikhail Nikolaenko]:
а что у нее со стабильностью? по мне так нормально вроде, а вот интерфейс, где со всех сторон разные панельки место занимают, особенно огромная верхняя с всего 5 кнопками - это ужас.
Re[PronVit]:
Так высыпается временами. При импорте иногда замирает на всегда. Иногда перестает прорисовывать превьюшки. Фоток у меня в лайтруме тысяч под 10 рав + жпг. Но пробовал и с нуля, да на ноуте, где железо 100% не глючное. Те же яйцы... В форумах тоже находил схожие проблемы.
Re[PronVit]:
А вы не пробовали нажимать разные клавиши вверху клавиатуры F + номер - помогает избавиться от лишних панелей :D Кроме того, если вам не нравится Лайтрум, пользуйтесь Апертурой или NX тоже отличные проги.
Я не вижу смысла сыпать буквами Г..., если вам прога не нравится ;) Как говорил Жванецкий "запах он чем хорош, отойди и не нюхай" :D
В свое время никто не верил, что Адоби сделает Кварк в полиграфии, а глядишь... сейчас мало кто Кварком пользуется, по крайней мере, гораздо меньше, хотя были царем горы :)
Думаю они готовят ответ Чемберлена во второй версии. Это как в велосипедном спорте, когда стоят на месте и кто первый не выдержал и поехал, тот и проиграл :)
Хочется очень верить. :D
от:Mikhail Nikolaenko
Lightroom 1.4 includes the following known issues:Подробнее
ну наконец-то!!!
Re[mesik]:
от:mesik
Я не вижу смысла сыпать буквами Г..., если вам прога не нравится ;) Как говорил Жванецкий "запах он чем хорош, отойди и не нюхай" :DПодробнее
во-первых, переключение на другой модуль это ctrl+alt+1,2,3... - если б было просто f1,f2,f3 было бы уже не так плохо.
во-вторых, не хочу клавиатурой. все остальные действия выполняются мышкой, поэтому клава при этом бывает далеко и тянуться к ней для переключения модулей как-то лениво. к тому же все равно эта панелька выезжает при случайном попадании мышкой в верх экрана - раздражает.
так я ж не говорю, что плохая прога. хорошая. даже идеологически лучше апертуры. но интерфейс неудобен.
апертурой пользовался бы, да не все компы дома - маки. nx моему сапопу совсем не кстати.
Re[PronVit]:
1) Когда я говорил про F-кнопки я имел ввиду спрятать/показать соответствующую панель, которая вам мешает
2) Ну можно попробовать например G нажимать и D вместо тех комбинаций прокоторые вы говорили :), остальными модулями я редко пользуюсь, так что не трудно и три клавижи нажать :)
3) Удобство интерфейса преимущественно привычка к данному конкрентному интерфейсу.
4) Не спорю, у любой проги есть свои преимущества и недостатки... Но это касется не только программ :D
Re[mesik]:
Кстати чтобы быть объективным - Адоби отмочили с последним апдейтом :) - подробнее Можно конечно и поосторожнее
Но как человек долгое время работавший рядом с разработчиками программ, понимаю чо и это неизбежные лажи :)
Re[mesik]:
Да уж отмочили. Хорошо что я не обновился :)
Оно оказывается правит дату снимка в оригинальных РАВ файлах если считает ее неверной, а этот апдейт считает все даты неверными и пишет туда какой-то хлам.
[quot]
EXIF Time Stamp Error: There is an error in the EXIF time stamp update technology that causes Lightroom to believe that the files are out of sync with the correct time stamp as displayed in Lightroom. Any ensuing metadata update will attempt to incorrectly modify the EXIF time stamp in the original raw file itself. This is the only metadata field that Lightroom will write to an original proprietary raw file. This error will not impact the integrity of your image data. The Camera Raw plug-in also will incorrectly change the EXIF time stamp in files converted by the plug-in. The information written to the XMP sidecar files or XMP metadata in the converted files will remain correct.
DNG Conversion Error(Windows Only): With the latest version of the Lightroom 1.4 and Camera Raw 4.4 applications, Adobe has included technology to verify that the image data in a DNG file is unchanged from when it was originally converted to DNG. Unfortunately, when converting to DNG using Lightroom 1.4 on Windows, the application will write an incorrect verification tag to describe the image data. When Lightroom attempts to work with those files in the Develop module, the application reads that incorrect tag, believes that there is something wrong with the raw data and will present an error. Rest assured, there is nothing wrong with the integrity of your image data or metadata. For those that have already converted their files to DNG using Lightroom 1.4(Windows only) we recommend using the DNG 4.3.1 converter to convert the DNG files you’ve created with Lightroom 1.4.
Olympus Conversion Error: There is an error in converting Olympus JPEG files to other formats in Lightroom 1.4 and the Camera Raw 4.4 plug-in. [/quot]
[quot]
