Leica Q Typ 116 - автофокусная FF беззеркалка c несменным объективом 28mm f1.7
Всего 2449 сообщ. | Показаны 1781 - 1800
Re[matvej-a]:
Leica Q2
Re[digitalforce]:
Re[KOНCТАНTИН]:
Leica Q2
Re[matvej-a]:
Re[digitalforce]:
Кстати все в курсе что Лейка ку2 по факту 24мм и программно в камере правится под 28мм?
"Leica Q2 is a 24mm with 51MP, not just 47MP and 28mm
I keep referring to the Leica Q2 as a 47MP and a 51MP sensor camera, and it is. The Leica Q2 is a 28mm camera with a 47MP sensor on the paper, but in the real world it has a 24mm frame and 51MP when you import the photo into Capture One Pro. "
Re[digitalforce]:
А еще Лейка ку2 лишена практически любых разьемов для подключения
Так как в 2030 году Лейка ку2 все еще будет использоваться, а вот всякие HDMI уже нет. Так зачем внедрять их в лейку сейчас? :D
The decisive moment for Leica: Simplicity
There’s a detail in the Leica Q2 that makes me smile, and that is that Leica Camera AG simply has decided to omit HDMI, Micro-USB and all other external connections.
This is very brave, and very sane in this day and age where camera manufacturers seem to think consumers just can’t get enough features and connections.
The only thing you might need connections for, is video. And once you go video, you need a lot of connections. More than a soulful, well-designed camera as the Leica Q2 should have. If you want to do video, get a real camera like the Leica SL (Leica SL2) that you can put real microphones, bigger screens, hard drives and all that onto it. Or get a Panasonic Lumix S1H video camera, or a Canon C300.
There’s also another detail, and that is that the Leica Q2 will still be around and be used by many in the year 2030, and who needs a micro-HDMI or any other connections by then (when they’re all going to be obsolete cable connections anyways)?
Leica Camera AG found just the right balance of connections – which was simply to skip them.
It’s very brave, and it’s awesome!
Re[predator77mm]:
от: predator77mm
Тогда это лучшая 24 что я снимал ;)
Re[KOНCТАНTИН]:
от: KOНCТАНTИН
Re[digitalforce]:
Съездил с Кукушкой в Юрмалу. Снимал только в джипег, т к места джипег+РАВ занимают ну очень много. А поездка чисто семейная. Вчера просмотрел на компе результат - фантастика. Динамический диапазон очень хорош. Там где на экранчике казались проваленные тени или небо выбито - на компе все ок, никакой потерянной информации. Детализация вообще чума! Пару тройку лучших кадров сейчас попробую напечатать. Поставил пресет «живая». Цвет и контраст как по мне - все отлично. Често говоря, 80-90% кадров нечего и поправлять.
Жаба за потраченные деньги куда-то убежала....))
Re[Serge Mazyra]:
В парикмахерской акум лежит за 5 рублей,это на тот случай если один(не помешает в поездках 2ой)
Re[KOНCТАНTИН]:
от: KOНCТАНTИН
Купил вторую батарею сразу же. С фотиком. Батареи хватало на полный день. И даже со скачиванием на телефон.в день делал 400-500 кадров.
Re[Serge Mazyra]:
от: Serge Mazyra
Когда я брал,их еще не было в продаже ;)
Re[digitalforce]:
https://yadi.sk/i/ynluzduJH7EUbw
Камджипег.
Re[Serge Mazyra]:
Какие Настройки у жипега?
Re[kaven]:
от: kaven
Viv - живая. Замер экспозиции по всему кадру. Компенсация - 1/3.
Остальные настройки заводские.
Re[digitalforce]:
 [/url][url=https://flic.kr/p/2hg5TgZ]
Leica Q2
SF-XVII by Alexander Herter, auf Flickr
