Калибратор монитора.
Всего 2 сообщ.
Показаны 1 - 2
Помогите подобрать калибратор монитора, так чтобы недорого и со вкусом.
Re: Калибратор монитора.
Eye-One Display:
BUNDLED AS: An Eye-one Monitor puck + Eye-One Match 2.0 software.
GOOD NEWS: This is the lowest price profiling kit that meets our standards. It does a very good job on new monitors. It's easy to use, and you can move up to the EyeOne PRO puck for increased accuracy.
BAD NEWS: There is a substantial lack of profiling accuracy on our older monitors using this kit.
WHO SHOULD BUY THIS: Portrait / wedding / seniors photographers who on a tight budget and cannot afford to spend more, and folks who only want to profile their monitors – not cameras or scanners etc.
COMMENTS: This software barely makes our recommended list because of its weak performance on the older monitors. It's only for shooters who cannot afford better – it beats not profiling your monitors.
Monaco OPTIX XR:
BUNDLED AS: Monaco Optix XR puck + OPTIX software.
GOOD NEWS: This is the best value for the money. It does a very good job on new and older monitors. It's very easy to use.
BAD NEWS: None.
WHO SHOULD BUY THIS: Portrait / wedding / seniors photographers who want the new long term monitor profiling solution that works well on all monitors. This is the lowest cost system that really works well.
COMMENTS: The original OPTIX kit used a totally different puck and would not have made our recommended list. Since the new puck was added, and the software tweaked, this is really "the" entry level product in our opinion. It's powerful, easy, and you will use it for years.
Monaco OPTIX XR Pro:
BUNDLED AS: Monaco Optix XR puck + Optix Pro software.
GOOD NEWS: This is a lot of profiling power for the money. It does a very good job on new and older monitors. It's very easy to use.
BAD NEWS: Some features, like the dual monitor balancing feature is confusing and difficult to use.
WHO SHOULD BUY THIS: Portrait / wedding / seniors photographers who want a high performance monitor profiling system that works well on all monitors, and commercial shooters looking for a solid profiling system for multiple monitors.
COMMENTS: In addition to the comments above in the OPTIX XR segment, this software allows you to do things the basic XR package does not like checking the accuracy of the profile you just built and allowing you to adjust the luminance of 2 monitors connected to one computer. This software also seems a bit more accurate on older monitor profiling.
Monaco OPTIX XR:
BAD NEWS: None.
