Цитата:от: Ктулху Фхтагн
Гы, вот она у мну таки запустилась :)
Но глююючная... Вылетает при зуме на превьюшке. А при попытке сконвертить вылазит ошибка. В общем, труп.
Known issues
In this beta there are several known workflow issues due features not being fully implemented.
Below is a non-exhaustive list of known issues for this beta 2.
Windows:
- Windows cannot be shut down while Capture One is running
- Dragging images to an album can course a crash or a lock up. Make sure that when you create an album you select the album at least once before adding images to it.
- If the hard drive being processed to runs out of disk space, Capture One will crash.
- If you have created an Album, Capture One will crash when using the Importer if the destination is set as a user defined folder.
- This beta will not run on AMD XP processors (but it will run on other AMD processors)
У вас не такой случаем?
