Fuji S5 ФАКТ!
Всего 164 сообщ. | Показаны 1 - 20
Fuji S5 ФАКТ!
Ну теперь это факт.
http://www.dpreview.com/news/0609/06092502fujifilms5pro.asp
Какие соображения по цене?
Re[murovei]:
Body material Magnesium alloy
Sensor • Fujifilm SuperCCD SR II
• 23.0 x 15.5 mm
• 2 photodiodes per photosite (one S and one R)
• RGB color filter array
• 14 bit A/D converter
Effective pixels • 12.34 million
• S-pixel: 6.17 million
• R-pixel: 6.17 million
Image sizes * • 4256 x 2848 (12.1 million)
• 3024 x 2016 (6.1 million)
• 2304 x 1536 (3.5 million)
Image formats • JPEG (EXIF 2.2) - 2 levels (Fine, Normal)
• CCD-RAW (14 bit) - S only mode
• CCD-RAW (14 bit x2) - S+R mode
Lens mount Nikon F mount (with AF coupling & AF contacts)
Usable lenses • Type DX AF Nikkor: All functions supported
• Type G or D AF Nikkor (IX Nikkor lenses can not be used): All functions supported
• Micro Nikkor 85 mm f/2.8D:All functions supported except autofocus and some exposure modes
• Other AF Nikkor (excluding lenses for F3AF): All functions supported expect 3D color matrix metering II and 3D multi-sensor balanced fill-flash for digital SLR
• AI-P Nikkor: All functions supported except 3D color matrix metering II,3D multi-sensor balanced fill-flash for digital SLR, and autofocus
• Non-CPU: Can be used in exposure modes A and M; electronic range finder can be used if maximum aperture is f/5.6 or faster; colour matrix metering, multi-sensor balanced fill-flash for digital SLR, and aperture value display supported if user provides lens data
FOV crop 1.5x
Focusing * • 11/7-area AF
• TTL phase detection
• Nikon Multi-CAM 1000 autofocus module
• Detection range: EV -1 to EV 19 (ISO 100, 20°C/68°F)
• Single / Dynamic Area AF (inc. Closest Subject Priority)
Lens servo * • Single Servo AF
• Continuous Servo AF [C]
• Manual focus [M]
Focus Tracking automatically activated by subject's status in or [C] AF
AF area mode * • Single Area AF
• Dynamic AF with Focus Tracking and Lock-on
• Group Dynamic AF
• Closest Subject Priority Dynamic AF
AF assist Yes, white lamp
Shooting modes • Programmed AE Mode (with program shift)
• Shutter-Priority AE
• Aperture-Priority AE
• Metered Manual
Metering system / range • 1,005-pixel CCD
• Matrix: 0 - 21 EV
• Center-Weighted Average: 0 - 21 EV
• Spot: 3 - 21 EV
(Normal temperature with F1.4 lens)
Metering modes • 3D Color Matrix Metering II
• Center-Weighted
• Spot (3 mm circle)
Meter Coupling CPU and AI
AE Lock • Dedicated button
• Half-press shutter release
Exposure compensation * • +/- 5 EV
• 1/3, 1/2 or 1 EV steps
Exposure steps 0.5 EV
AE Bracketing • 2 or 3 frames
• 0.5, 1.0, 1.5 or 2.0 EV steps
Sensitivity • ISO 100
• ISO 160
• ISO 200
• ISO 400
• ISO 800
• ISO 1600
Shutter Electronically controlled vertical-travel focal-plane shutter
Shutter speed * • 30 sec - 1/8000 sec
• Bulb
Flash X-sync * 1/250 sec
Aperture values Depends on lens (1/3, 1/2 or 1 EV steps)
DOF preview Button, stops-down lens aperture
Exposure moes • Program Auto
- flexible program possible
• Shutter-Priority Auto
• Aperture-Priority Auto [A]
• Manual [M]
Drive modes • Single frame
• Continuous shooting
• Self-timer mode (2, 5, 10 or 20 sec)
Continuous shooting
Yes, details unknown
Built-in flash • Pop-up (manual)
• Guide no. 12 (ISO 100)
• Max shutter speed: 1/250 sec
Flash control • TTL: TTL flash control by 1,005-pixel RGB sensor.
• Built-in Speedlight: i-TTL balanced fill-flash or standard i-TTL flash (spot metering or mode dial set to [M])
• SB-800 or 600: i-TTL balanced fill-flash for digital SLR and standard i-TTL flash for digital SLR.
• Auto aperture: Available with SB-800 with CPU lens
• Non-TTL Auto: Available with Speedlights such as SB-800, 80DX, 28DX, 28, 27, and 22s
• Range-priority manual; available with SB-800
External flash • X-contact hot-shoe (with i-TTL support)
• PC sync terminal
Viewfinder * • Fixed eye-level pentaprism
• Built-in diopter adjustment
• Coverage: Approx. 95%
• Magnification: 0.94x
White balance * • Auto
• Fine
• Shade
• Fluorescent
• Incandescent
• Flash
• Preset
• Color temperature
Film simulation * • F1
• F1a
• F1b
• F1c
• F2
Color space • sRGB
• Adobe RGB
Dynamic range * • Auto
• 100% (Std)
• 130%
• 170%
• 230% (W1)
• 300%
• 400% (W2)
Storage * Compact Flash Type I/II
LCD monitor * • 2.5" TFT LCD
• 235,000 pixels
Connectivity * • USB 2.0 (Hi-Speed)
• Video out
• Wired remote
• DC in
• PC Sync terminal
Power * • Lithium-Ion battery
• Optional AC adapter
Dimensions * 170 x 113 x 74 mm (6.7 x 4.4 x 2.9 in)
Weight (no batt / lens) Unknown
Re[murovei]:
старые потроха в новой тушке, может хоть скорость повыше будет... Ожидал бОльшего :(
Re[Уэф]:
от: Уэф
Может оно стоить подешевле будет. без вертикальной то ручки. Типа компактная версия S3.
Re[murovei]:
от: murovei
Ну теперь это факт.
Цены уже обсуждали и не раз - от 1800 до 4000. А раз продукт уже представлен, то можно с бОльшей лёгкостью эти предположения вместить в более реальные рамки.
А насчёт больших ожиданий (для ожидающих) можно только сожалеть, что эти скачки с опережением сказываются не лучшим образом на качестве, так как конкуренция помимо положительных результатов, даёт ещё и не очень положительные. В виде сырых или около того продуктов...
Однако это лучше, чем ничего ;)
Re[Artyom Suvorov]:
от: Artyom Suvorov
Помечтайте
Re[murovei]:
Чуда не произошло? Типа, опять кроп
Re[Snap]:
от: Snap
а что кроп, дело не в нём.. пусть будет кроп. Я чёто не вижу пер секондов Если она будет такая же медленная как и с3 то нуеёнафиг за такую цену.
Re[murovei]:
d200 с очень хорошей матрицей...
и без серийной съёмки.. впринцепи очень даже привлекательно...
ребят а вы чего хотели фул фрейма?
думаю цена 2500)
Re[murovei]:
честно скажу я бы поменял свою 200ку на s5.
s3 был ж очень тормознутый и неудобный тут совсем другое дело эргономука нкона;)
без всякой там оптимизации ...
интересен вопрос вертикальной ручки будет ли от 200ки подходить и формат акамуляторов...
слушал что будут уникальные.
Re[murovei]:
от: murovei
думаю цена 2500)
Да не, просто помечталось :) С такими тормозами и фф был бы супер.
А если честно, то может и действительно - реальная альтернатива Д200
Re[Snap]:
от: Snap
Более чем альтернатива, при отсутствии тормозов я бы назвал фуджик полной заменой
Re[Уэф]:
+1 за полную альтернативу.
осталось дождаться d2x с такой же матрицей или уже ASP-H
Re[murovei]:
от: murovei
Это будет уже не Д2х ;) И не за такие деньги
Тем не менее, я увидел (предварительно, конечно), на что можно менять через год Д70 :D
Re[murovei]:
А вот расскажите...
1. Какими дровами конвертить ихние RAW-ы?
2. Как пользоваться немеряной разрядностью для жипега ? (Насколько мне не изменяет, жипеги в шопе обрабатываются тока 8-битные...). Правильно-ли я понима, что нада конвертить в tiff, там обрабатывать и потом фигачить в жыпег для сдачи в печать ???
3. "Замечательная картинка" Фужика видна только при правильной обработке с использованием Умудренности, или вопщемта при простом конвертировании в Жыпег будет уже ничё таг ?
*** Спасибо!
Re[Snap]:
от: Snap
+1 (но еще в сомнениях)
Re[Snap]:
елки-палки, как на Д200 то похож
Re[Snap]:
думаю, не тот бюджет чтобы менять камеру за 700у.е на камеру от 2000 у.е.
Re[Едкий Натр]:
с фуджи обрабатывать нечего ненадо там всё сразу хорошо.
Re[murovei]:
от: murovei
Моему Д70 2 с лишним года...
Через годик на что-то менять нада полюбому.
Если ФФ не будет, или будет за 5000, то кроме Фужика пока вариантов не видно: 80 мне непонра, а 200 хорош по ергономике, но я не репортер, чтоб мне так уж всё было это важно.
Вот и задумался о Фужике...
