Все помнят, как 135 плёнка на свет появилась?
Напоминалка для слабопомнющих и тугодумающих.
Earliest 35 mm still cameras
The 35 mm film standard for motion picture film was established in Thomas Edison's lab by William Kennedy Laurie Dickson. Mr. Dickson took 70 mm film stock supplied by George Eastman's Eastman Kodak Company. The 70 mm film was cut lengthwise into two equal width (35 mm) strips, spliced together end to end, and then perforated along both edges. The original picture size was 18 x 24 mm, which in modern times is considered to be a "half-frame" format for still photography. There were four perforations on each side of a motion picture frame.
There were a number of 35 mm still cameras using perforated movie film prior to the Leica. The first patent for one was issued to Leo, Audobard and Baradat in England in 1908. The first full scale production camera was the Homeos, a stereo camera, produced by Jules Richard in 1913. It took stereo pairs, 18x24 mm, with two Tessar lenses, and was sold until 1920.
The first big-selling 35 mm still camera was the American Tourist Multiple, which also appeared in 1913, at a cost of $175 (at today's prices, the same cost as a modern $3000 Leica.) The first camera to take full frame 24x36 mm exposures seems to be the Simplex, introduced in the U.S. in 1914. It took either 800 half frame or 400 full frame shots on 50 ft (15.2 m) rolls.
The Minigraph, by Levy-Roth of Berlin, another half frame small camera was sold in Germany in 1915. The patent for the Debrie Sept camera, a combination 35 mm still and movie camera was issued in 1918, but was not marketed until 1922.
Finally, the Furet camera (made and sold in France in 1923) took full frame 24x36 mm negatives and was the first cheap small 35 mm camera to look vaguely like today's models.
Так что прекращаем онанировать, прекращаем называть формат кадр 36*24 - полным кадром и начинаем честно называть всех обладателей камер с матрицей такого формата - полуобрезаными и вечнокропнутыми. А термин - полный кадр употребляем лишь к действительно полнокадровым среднеформатным цифровым камерам.
ФФ. Почему оно полное аццтой и предназначено для легковерных лузеров.
Всего 48 сообщ.
Re[Hellsau]:
полный кадр это 9*12см. средний формат называется половинный (6*9) ну а 6*4.5 это ваще огрызок
Re[Hellsau]:
от:Hellsau
Так что прекращаем онанировать, прекращаем называть формат кадр 36*24 - полным кадром и начинаем честно называть всех обладателей камер с матрицей такого формата - полуобрезаными и вечнокропнутыми. А термин - полный кадр употребляем лишь к действительно полнокадровым среднеформатным цифровым камерам.Подробнее
Полный кадр, он всегда относителен - есть полный кадр Олимпуса, есть полный кадр Канон, Никон, и т.п. Он полный, т.к. работает на 100%, которые позволяет система! А когда система позволяет 150% от того, что имеем, то это кроп, а кроп он для лохов это все знают
Re[Hellsau]:
Круто
До такого даже в песочнице ещё вроде не доходили
Вы Ъ ещё расскажите, что он "полуобрезанный" с питагом
Re[VoVan]:
от:VoVanНу да, ну да, давай отмазывацца.
Полный кадр, он всегда относителен - есть полный кадр Олимпуса, есть полный кадр Канон, Никон, и т.п. Он полный, т.к. работает на 100%, которые позволяет система! А когда система позволяет 150% от того, что имеем, то это кроп, а кроп он для лохов это все знаютПодробнее
Выбрали себе трижды кропнутую и обрезаную систему и давай ею прикрываться, изредка попукивая и пудря мозг незнающим гражданам - мол у нас в системе есть ФФ, у нас полный кадр, ура, слава кванончегу!.
Какой полный кадр, ВоВан? Где ты его нашёл? А?
Владельцы прочих систем сидят и не возмущаются, просто снимают и не комплексуют по поводу врождённой неполноценности их систем. А вот сапонюги... Ха!
Re[L4m3r]:
от: L4m3rВот. Как же жалко выглядят эти четырежды кропнутые канонюжки с жалобными воплями про свой ФФ. Лилипутики обрезаные!
Re[Hellsau]:
Насколько мне не изменяет память, полный кадр - это пластинка 8х10". Соответственно 4х5" - "четверть пластинки" называлось в начале века. Было вроде еще полпластинки. Но я боюсь ошибиться.
Re[L4m3r]:
от: L4m3r
ГМ... похоже что с переходом на полный кадр маркетоиды начнут гонку гигапукселей....
ЗЫ... до пятницо истчо 3 часа.....
Re[Gapey]:
от: Gapey
ГМ... похоже что с переходом на полный кадр маркетоиды наянут гонку гигапукселей....
Если маркетологи правильные, то ваши правнуки, покупая Кванон системы НаконецтанеЭОС56анастоящийполнокадровыйЭОС57, про это и не подумают даже.
Мои же правнуки будут просто снимать на камеру Никон Д100000 с кропом 1.5 от 9*12 кадра и не жужжать. Всё равно у никона функционал и эргономика будет лучше. Ну и что, что на исо 400 000 и выше кваноновская поделка будет шуметь на ступень выше? ;)
от: Gapey
Re[Hellsau]:
только размер первого ньепсовского кадра может всерьез рассматриваться, как полный кадр.
16.2 x 20.2 см.
16.2 x 20.2 см.
Re[Hellsau]:
от:Hellsau
Сам то понял, что написал!
В таком случае полный кадр это 130х90, средний формат - это средний формат, а 36х24 полу-средний формат или кропнутый средний формат, а то что меньше - обрезки кропнутого среднего формата!
Re[Шевченко А И]:
от:Шевченко А И
В таком случае полный кадр это 130х90, средний формат - это средний формат, а 36х24 полу-средний формат или кропнутый средний формат, а то что меньше - обрезки кропнутого среднего формата!Подробнее
Неважно. Гении тоже могут допускать неточности в формулировках, на это и существуют критики, которые поправят за гением неточности оборота.
Самое главное, что идея моя верна. Отныне, предлагаю сказать нет проискам безумных комплексующих фанатиков и начать называть то, что они святотатствую называют сейчас ФФ, так, как и положено - кропом. Или обрезками. Или обрезаным форматом.
Скажет нет ФФ безумию!!!
Re[Hellsau]:
А никто из пятачкистов своим и не гордится.
Какой уж есть. А вот над остальными оунерами обмылков и обрезков грех не приколоться.
Предлагаю проще обходиться. Всё что имеет матрицу меньше 24х36 называть кропфопарат. Тогда понятнее будет, а то сгрудили в одну кучу Самсунги и прочие 400-ки, и по названию не отличить их от пятаков и роллеев.
Re[Алексей В. В.]:
от:Алексей В. В.
Предлагаю проще обходиться. Всё что имеет матрицу меньше 24х36 называть кропфопарат. Тогда понятнее будет, а то сгрудили в одну кучу Самсунги и прочие 400-ки, и по названию не отличить их от пятаков и роллеев.Подробнее
Никон сделал D3 с возможностью снимать стёклами для DX-формата.
А ынжынеры с Canon сделали урезок без возможности цеплять EF-S.
Re[Алексей В. В.]:
от:Алексей В. В.Ку! Вы читать умеете? Ещё лет за 100 до вашего рождения уже всё назвали своими именами. 9*12 см - это полный кадр. Всё что меньше - кропы чиповые.
Учимся называть вещи своими именами. :)
Re[Hellsau]:
Hellsau, не подскажите, а ваши фотки на какой формат сняты?
Re[Hellsau]:
Вы прям не в себе от такого безобразия!!!
Кроп, ФФ, СФ, БФ... Ну что вы тявкаете ?
Знаете что такое неологизм? Можете теперешние термины "кроп", "ФФ" считать неологизмом, а можете просто современным фотосленгом.
У вас мягко говоря комплекс неполноценности. Вероятно по отношению к матрицам 24*36мм. А может вы полупрофессионал?
Уверяю вас, и на "кропах" делают хорошие снимки.
Прошу извинить за резкость тона, но оно так.
Re[Михаил Понедельник]:
от: Михаил Понедельник
Ему вообще технику не доверяют. Он о ней только мечтает.
Re[Влад Т]:
от: Влад ТCкажи спасибо что не в тебе.
от: Влад ТШава, тебя на помойке вырастили? Общаться где училась? Или программер чёль?
от: Влад ТУ меня? Откуда? У меня вообще ничего нет, я призрак.
от: Влад Т
Я - нет. Хозяин - да. Ещё вопросы?
от: Влад ТПокажь.
от: Влад ТЭто не резкость тона, тупка. За такое тебе на улице уже бы давно подрихтовали. Сразу видно - программер домашне-парниковый. С ещё не исправленной геометрией клюва.
Re[Hellsau]:
от: Hellsau
http://club.foto.ru/self_portrait/50359.jpg
Что ж тычите мне, добрый молодец? Сам то ты кто на улице?
