Epson stylus PRO 4800 - вопрос?
Доброго утра!
У кого есть опыт общения с данным агрегатом, поделитесь основными моментами, которые непишут в тех.характеристиках. Как по расходу и стоимости обслуживания.
Re[Николай Юрьевич]:
По расходу и стоимости, да и все contras обычно пишут в обзорах: http://www.google.com/search?q=Review+Epson+Stylus+Pro+4800
Например:
http://www.luminous-landscape.com/reviews/printers/4800-1st.shtml
http://www.outbackphoto.com/printinginsights/pi037/Epson_R4800.html
Масса деталей, о которых Е. не напишет:
Firstly, the act of changing cartridges can take from 10-30 minutes. Part of the problem is that manual intervention is needed every few minutes. One has to stand by the computer the whole time waiting for the top-panel LCD to inform you to raise and lower the two levers next to each side's cartridge grouping. This can be required anywhere, in my experience, from 6 -12 times. (I'm thinking of suing Epson for physiotherapy costs due to carpal tunnel syndrome). On a more serious note, it means that since the printer often sits for periods of time without making noise, and then starts and stops as it pumps ink in and out of the lines, you can't just sit at your desk and listen for when manual attention is needed. You actually have to stand there, sometime for close to half an hour.
But the kicker is that ALL of the inks are depleted every time you change the black cartridge. I estimate that about 10% of the printer's total ink capacity is lost each time the black cartridge is exchanged. This means about a US $75 hit. Not a good thing!
Guess what happens every time you turn the printer off and on, even to clear the above jam? You got it, another cleaning cycle...
Насчет стоимости вот тут http://www.inkjetart.com/3800/index.html есть табличка:
Here's a comparison of costs per milliliter of ink, at Manufacturer Suggested Retail Prices (MSRP):
$1.35 / ml with HP B9180 ink cartridges (27 ml carts)
$0.95 / ml with Epson R2400 ink cartridges (15 ml carts)
$0.75 / ml with Epson 3800 ink cartridges (80 ml carts)
$0.65 / ml with Epson 110 ml ink cartridges used in 4800/7800/9800
$0.58 / ml with Canon iPF5000 ink cartridges (130 ml carts)
$0.51 / ml with Epson 220 ml ink cartridges used in 4800/7800/9800
короче, если Вы на гугле не забанены - все легко находится.
