DPP 1.5 Update
Re: DPP 1.5 Update
Чего-то у меня не открывается. Ни из IE, ни из Firefox.
Re: Re: Re: DPP 1.5 Update
от:delx
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=dc
Спасибо большое... качаемс... ;)
Re: DPP 1.5 Update
А что улучшили/добавили?
Re: DPP 1.5 Update
Сам спросил, сам ответил:
"1. An image trimming function has been added.
2. A simulation function has been added for CMYK printing. Selecting the profile to be used for printing ensures that the colors displayed in the [Preferences] windows and used for printing conform to the selected profile. This allows you to check beforehand how the colors will look when the image is printed using CMYK.
However, the profile specified in this function is not applied when Easy-Photo Print is used for printing.
3. It has become possible to transfer multiple images to any retouching application with a single operation.
4. In the main window Tree View Area, folders can be copied, moved, and deleted.
5. The tone curve in the [RAW images adjustment tool palette] has changed to a log display.
6. Printer profiles can be specified in the [Color management] tab of the [Preferences] dialog box.
7. When saving an image file, the image size can be set in the [Save as] dialog box.
8. If you select the [Help] menu, and then click the [Digital Photo Professional Help], Digital Photo Professional Instruction Manual will be displayed in PDF format.
9. When saving an image in JPEG format, an ICC profile can be embedded in the image using the [Save as] dialog box.
10. When saving an image in TIFF format, sharpness settings for the image can be changed in the [Save as] dialog box."
вот прямой линк на него:
http://beta00.c-wss.com/wsss/servlet/wwux.wwuc.filedownload.servlet.WWUCDownloadFromAkamaiServlet?absolutePath=/downloadFiles/00092188EN0100/DPP150udEN.exe
кстати, написано что это только Апдейт, и что нужен DPP 1.0 ...
если скачанный архив распаковать, то увидим что в папке Digilal Photo Professional лежит Setup.exe.
интересно, а если запускать именно его, а не "Update Installer.exe", может и старая версия программы не понадобится ?
P.S. щас просто проверить самому нет возможности ...
Re: DPP 1.5 Update
Спасибо за ссылочку!
Скачал, установил и сравнил с Capture One. По удобству интерфейса, детализации, диапазону резкости и цветовой достоверности кэноновский продукт отчаянно недотягивает до C1. Для меня вопроса что выбрать более не существует.
от:Владимир Никитин
По детализации DPP, я бы сказал, не уступает и, возможно, даже превосходит C1. По цветовой достоверности трудно сказать, Color Target не фотографировал.
Интерфейс своеобразный, да, но ко всему привыкнуть можно и при выделении группы RAW файлов и нажатии Ctrl+Right превращается в некое подобие C1.
