Dental turbine
Всего 2 сообщ.
Показаны 1 - 2
Dental turbine
High Speed Dental Turbine / Dental Turbines that operate at speeds from 100,000 to 800,000 RPM. Features such as attachment type, head size, light source, dental turbine weight and motor noise further distinguish high speed turbines. The high speed or ultra-fast tip operates on the basis of a water jet and may be equipped with a fiber optic light to facilitate better visibility. The water jet is necessary to reduce the temperature in the contra-angle and the surgical field. It is important to ensure that the selected dental contra-angle handpiece for high speed operation has high quality bearings to ensure its longevity. If you need, you can click: https://www.dentalzz.pl/category-79-b0-Turbina-stomatologiczna.html
