DAZZNE Flash Light китайская вспышка с поддержкой HSS
Всего 1 сообщ. | Показаны 1 - 1
DAZZNE Flash Light
www.dazzne.com
Новая вспышка из Китая с поддержкой HSS
Страница продукта в интернете: http://www.kondc.com/proshow.aspx?id=63
Оригинальное описание с сайта производителя:
Large Size LCD Display for easy viewing and setting flash functions.
Support Multi Flash, the First from China to support Multi-mode Manual Flash.
Electrical Zoom Function, through the operation of zoom and adjust the button on the flash, let the head of the lamp cover
the focal length movements between 24 ~ 105mm.
Voice Prompts, Turn on Voice Prompts function and different voice to point out different work status of flash, allowing you
to concentrate on shooting.
Equipped with an external power outlet to meet your higher demand for the power return.
With standard PC Sync Port, using a PC Sync Cord to let the Flashgun flash synchronously.
Speedy Power Return System, you can also use an external charging box to once again, accelerate the recycling time.
Power Saving Mode, under the Power Saving Mode, the Flash will be dormant and automatic shutdown quickly; will not sleep in
Non-saving Mode, the Flash will idle longer time before automatic shutdown.
Can automatically save your current operating settings, convenient for you to use next time.
Improved Panel Button design, sensitive operation, better hand-feel.
Metal texture for Hot Shoe Interface.
Support Dazzne Wireless Flash System
Support TTL High Speed Sync Flash
Flash Index 58%
Пока это единственная фотография вспышки, спереди она, видимо, тоже близняшка Canon 600EXII :)
Если прочитать описание то складывается мнение, что начинка у нее от YN-568EX, только добавлен разъем внешнего питания :)
Будем ждать более полной информации :)
Очень интересно :)
