Specifications:
1. System Type: On-Camera wirlelss transceiver
2. Frequency: 2405-2475MHz
3. Distance: Approx 80m
4. Channel: 7 Channel
5. Flash Mode: E-TTL(II),Manual flash, Multi flash
6. Sync Mode: 1st curtain, 2nd curtain, Hi-speed sync
7. Groups: 3 Groups(A/B/C)
8. Sync Speed: 1/8000s
9. Input: Hot-shoe(TTL,main contact)
10. Output: Hot shoe, 3.5mm Flash/PS Sync jack(300v no polarity)
11. Applicable Battery: AAA*2 (support 1.2V rechargeable battery)
12. Stand-by Time: 40h
13. Dimensions: 72*55*36.5mm
14. Weight: 52g(excluding batteries)
Supported Functions List:
Compatible flash mode: E-TTL(II), Manual,Multi
Compatible Shutter sync: 1st curtain, 2nd curtain, high speed sync (HSS/FP), the highest sync speed is 1/8000s
Control remot flash using camear's flash control menu scren (Remote Control Mode)
Support E-TTL/Manual/Multi flash mode mix using(Mix Control Mode)
Flash on hot-shoe of transmitter supports ETTL
Support Flash Exposure Compensation (FEC)
Support Flash Bracketing (FEB)
Support Flash Exposure Lock (FEL)
Support modeling flash and red-eye reduction flash
Support flash zooming (auto,manual)
Built-in AF assist beam emitter (AF Lamp)
Settings saved automatically
Support PC port triggering strobe flashes
PC port support 1st, 2nd curtain sync and high-speed sync(Super Sync)function
Support LCD Live view triggering
Support high-spped continuos shooting trigger
Compatible with ALL Canon EXII series flashes
Support single-contact of camera & flash triggering (max sync speed is 1/250s)
Compatibility List:
Functions supported by the product depend on the camera and flash used. According to different types of cameras, in this user manual, the EOS DSLR camera without extermal flash (speedlite) control menu is called type A camera, while EOS DSLR camera without exteral flash control menu is called type B camera; other camera brands with standard hot-shoe is called type C camera.
List of Type A cameras
Canon EOS 5D Mark II /5D Mark III, 1Ds Mark III, 1D Marl IV / 1D Mark III, 7D,60D,50D,40D/650D/600D/550D/500D/450D/1100D/100D/EOSM.
List of Type B cameras
Canon EOS 5D, 10D, 20D, 30D,300D,350D,1D,1D Mark II
Compatible ETTL flash list (support wireless remote control through camera menu)
Canon 600EX (RT)/580EXII/430EXII/320EX/270EXII
Package Included:
2 х transceivers
1 х studio light sync cord
1 х studio light sync cord 3.5mm adapter
1 х Instruction in English and Chinese
Цена за пару транссиверов в сети $75 (включая доставку без трекинга)
Обнаружил сегодня этот клон YN-622C с дизайном напоминающим мутировавший Pocket Wizard Mini-TT1
Все полностью снято с транссивера Yongnuo
Поменялись местами только кнопки CH и TEST и индикатор состояния переехал налево от башмака
На фотографиях я не нашел излучателя подсветки автофокуса , возможно потому что английскую спецификацию тупо списали с YN-622C :))
Эргономика улучшена - кнопки утоплены (плюс) и уменьшены габариты (плюс), видимо за счет применения более слабых AAA батарей (минус) но имеется режим энергосбережения для забывчивых (плюс).
Разъем синхронизации не PC а JACK (плюс)
В комплекте есть проводок (небольшой плюсик)
Как эти устройства работают неизвестно, но если не накосячили все должно работать как оригинал YN-622C
Еще картинки:
