С месяц назад на этом форуме выдвигалась идея приставки для просмотра цифровых изображений прямо с флэш-карты. На западе уже реализовано, стоит в магазине порядка 400 USD. Эх, раньше патентовать надо было!
http://www.photographic.com/showarchives.cgi?138:8
81 Digi-Frames allow digital photographers to display photos without using a computer. These sleek, high-tech frames are available in several decorative finishes and sizes. Their technology enables you to transfer and view images directly from your digital camera by removing the camera's memory card and inserting it directly into the Digi-Frame. The frames are compatible with both standard CompactFlash and SmartMedia memory cards, and operate with most of today's digital cameras. Digi-Frames offer an easy-to-use on-screen menu, which allows you to view thumbnails of memory card contents, edit your slide shows, select the time between image changes, add transition and display effects, and more. Digi-Frame; www.digi-frame.com.
