Чем отличается Let Printer Determine colors от No Color Management ?
Что то запутался, чем отличается Let Printer Determine colors от No Color Management ?
Re[OYGEN]:
Безусловно, они часто похожи, но в хелпе четко расписано когда и для чего их применять:
Let Printer Determine Colors:
In this workflow, the application does no color conversion, but sends all necessary conversion information to the output device. This method is especially convenient when printing to inkjet photo printers, because each combination of paper type, printing resolution, and additional printing parameters (such as high speed printing) requires a different profile. Most new inkjet photo printers come with fairly accurate profiles built into the driver, so letting the printer select the right profile saves time and alleviates mistakes. This method is also recommended if you are not familiar with color management.
To print targets for creating custom profiles
A target is a document you use when creating a custom profile. Generally, a target document with swatches is supplied as part of a third-party color management software package. You print this document with all color management turned off in both Photoshop and the printer driver. The third-party measuring instrument reads or scans the printed target to create the custom profile.
1.2.3.4. blah-blah-blah....
5. In the Options area, from the Color Handling popup menu, choose No Color Management. When this option is selected, Photoshop sends the RGB numbers in the file to the printer without conversion.
6. blah....
For inkjet printer drivers, color management options are usually labeled ColorSync (Mac OS) or ICM (Windows).
7. Turn off color management for the printer so that the printer profile settings don’t override your profile settings.
Т.е. 1й применять для печати (картинок с встроенным профилем) с принтерными профилями, а 2й - при печати тестовых картинок (часто без встроенного профиля) as-is.
Re[vga50]:
На сколько знаю, No Color Management выбирают, когда печатают уже с внедрённым профилем
Re[OYGEN]:
от: OYGEN
Только не "с внедренным", а сконвертированным в выходной профайл.
Re[Андрей Якубовский]:
да,да согласен, не так выразился
Re[OYGEN]:
В этом и есть разница. :)
Embedded профиль и RGB картинка - это все что надо, чтобы сварить суп. (ну, и принтеру предоставляется сварить этот суп)
В тестовых (или сконвертированных в выходной профиль) картинках суп уже сварен, RGB пересчитаны как надо, поэтому embedded профиль и не нужен. Все что нужно - чтобы остальные повара не вмешивались. :)
кстати, в 7п. наверное и имеется в виду этот отсутствующий профиль?
Re[vga50]:
Значит если я уже переконвертировал изображение в нужное цветовое пространство ( выбрал какой-нибудь родной эпсоновский профиль).
Затем ставлю No Color Management и печатаю? Интересно эта опция убирает цветокоррекцию в драйвере или её также нужно предварительно отключать?
Re[OYGEN]:
Конечно, надо убрать самому. (о чем 7й пункт инструкции и говорит) А то драйвер подумает, что ему sRGB на вход подали и начнет конвертить со своими профилями.
Re[vga50]:
А что в драйвере есть свои профили и он конвертировать умеет?? Выбор профиля происходит когда в драйвере тип бумаги выбираешь?
Re[OYGEN]:
от: OYGEN
Конечно есть. Они меняются, когда Вы выбираете разные типы бумаги. Матовая, глянцевая и т.д. Именно эти профили отключаются, когда выбирается off для ColorManagement, и используются в режиме Let Printer Determine colors. Посмотреть эти профили можно с настройках принтера на закладке "Управление цветом".
Re[OYGEN]:
от:OYGEN
1. Let Printer Determine colors - фотошоп преобразует картинку в цветовое пространство sRGB и отправляет на принтер. Принтер принимает данные, как и от любой другого приложения не работающего с системой управления цветом (стандарт sRGB), и печатает с возможностью коррекции цвета, встроенной в драйвер.
2. Let Photoshop Determine colors - фотошоп преобразует RGB картинки в соответствии с профайлом принтера: RGB картинки -> Lab (используя цветовое пространство картинки) - RGB (используя профайл принтера) и оправляет на принтер. Настройки в драйвере принтера должны точно соответствовать настройкам, с которыми был построен профайл - очень частая ошибка, вызывающая неудовлетворительное качество печати.
3. No Color Management - фотошоп не делает никаких преобразований и отправляет данные RGB как они есть.
Это относится к RGB принтерам, в случае с RIP (CMYK)несколько иначе.
Re[BlackRed]:
1.Let Printer Determine colors - фотошоп преобразует картинку в цветовое пространство sRGB и отправляет на принтер. Принтер принимает данные, как и от любой другого приложения не работающего с системой управления цветом (стандарт sRGB), и печатает с возможностью коррекции цвета, встроенной в драйвер.
Значит, любое цветовое пространство отличное от sRGB фотошоп конвертирует в sRGB?
Возможность коррекции цвета, предусматривает то, что драйвер принтера переконвертирут цветовое пространство в другое, согласно выбранному типу бумаги??? Или коррекция в данном случаи означает, только возможность подкрутить в драйвере яркость, контрастность и цвета?
Основное отличие между этими методами , как я понимаю, состоит в том, что при No Color Management фотографию нужно заранее готовить к печати, т.е. конвертировать цвета непосредственно в фотошопе. А при Let Photoshop Determine colors , конвертация происходит без нашего участия, необходимо выбрать лишь нужный профиль в окне печати.
Я прав???
Re[OYGEN]:
от:OYGEN
Драйвер принтера производит цветоделение RGB в CMYK (или соответствующий набор цветов по чернильницам). Естественно для этого надо знать в каком цветовом пространстве ему выданы RGB. Если не включена галочка No Color Management, он считает, что это sRGB. Как влияют на это цветоделение (конвертирование в пространство CMYK или CcMmYK или еще какое-то другое) параметры драйвера: меняются профайлы или в одном профайле регулируются некие параметры - кто его знает. Мне кажется, что последнее более вероятно.Цитата:
Я прав???
Да.
