Вместе с выходом D300 и D3, Nikon выпустил свежую версию Capture NX ( версия 1.3). Если интересно иструкцию на англ. и Trial version можно скачать вот здесь:
http://nikonimglib.com/ncnx/index_en_nsa.html
изменения:
Content Description / Modifications:
Support for RAW NEF images taken with the D3 and D300 has been added.
Support for Picture Control has been added.
A Picture Control item has been added to Camera Adjustments in the Base Adjustments. The Color Mode, Tone Compensation, Saturation and Sharpening items have been moved to the new Picture Control item.
An Active D-Lighting item has been added to RAW adjustments in the Base Adjustments,and Sodium Vapor Lamps and High Temperature Mercury Vapor (7200K) settings have been added.
RAW images can now be saved with lossless compression. Images captured in lossless-compressed RAW format can now be saved in lossless-compressed RAW format, regardless of camera model. (Limited to use with images captured with Nikon digital-SLR cameras).
The Vignette Control function, which was previously for use only with RAW images, is now supported with JPEG and TIFF images. (Limited to use with images captured by Nikon digital -SLR cameras).
The function for modifying images captured with a fisheye lens, available in Lens Adjustments in the Base Adjustments, is now compatible with images captured with the AF Fisheye-Nikkor 16mm f/2.8D.
Features for editing RAW images, previously available in the Camera Settings palette, have been eliminated.
Capture NX 1.3
Всего 24 сообщ.
Capture NX 1.3
Re[NikZ]:
Picture Control - наконец-то вернули возможность загрузки кривых +сохранение своих пресетов.
Re[NikZ]:
Можно загружать
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=14428&p_sid=pbj2NsRi&p_lva=61
Re[artcool"]:
http://nikoneurope-ru.custhelp.com/cgi-bin/nikoneurope_ru.cfg/php/enduser/std_adp.php?p_faqid=23510
Re[Димитрий Донской]:
от: Димитрий Донской
Ага! :D Весело!!!Еслиб только не надо регистрироваться было б
NC 1.3
Ключ подходит от 1.2
Re[lerasv]:
Подскажите, возможно ли сделать так, чтобы ACDSee Pro2 при открытии NEF файлов, редактированных до этого c помощью Capture NX, видел результат этого редактирования, а не оригинальный NEF.
Я бы подумал, что это в принципе невозможно и не задавал бы мой вопрос, если бы не одно но: фотка на какой то момент открывается измененная, но затем "превращается" в оригинал.
Re[NikZ]:
А эта проблема решена:
В Nikon Capture NX кликаю на картинку-миниатюру открывается фотка для редактирования. Как сделать, если кликнуть на другую картинку-миниатюру что бы фотка не открывалась в новом окне, а всегда оставалась в одном, оставляя правку редактирования первой фотки. В общем так как это Nikon Capture 4
Если нет то пока вообще рано переходить NX ИМХО
Re[NikZ]:
Почему в NX 1.3 в разделе Сamera Setting параметры камеры (D80) не меняются?
В предыдущих версиях это работало.
Потому,что они теперь находятся в другом месте :D(Если вы имеете ввиду RAW-файлы,ведь только тогда можно менять настройки в программе) И путь у нее такой;палетта Edit List->
Base Adjustments->Camera Adjustments->Picture Control
Появится окно Settings и вот в самом верху выбираете Non-Picture Control и ваши камерные настройки перед вами
Re[artcool"]:
от:artcool"
Появится окно Settings и вот в самом верху выбираете Non-Picture Control и ваши камерные настройки перед вамиПодробнее
Спасибо, нашел.
А насчет отображения изменений в ACDSee так никто ничего не подскажет? (см. мой пост чуть выше).
Re[NikZ]:
На русском языке есть описание как работать с Capture NX 1.3 ? Интерес к этой теме большой. Может кто возьмется переведет на общественных началах ???
Re[Ramil]:
от: Ramil
На здоровье: http://www.olegoleg.ru/papka1/
Там, правда, не все уроки, но ПДФ, да и сам перевод - отличного качества.
Re[Онищенко Александр]:
от:Онищенко Александр
Там, правда, не все уроки, но ПДФ, да и сам перевод - отличного качества.Подробнее
Есть у меня этот перевод.
Re[Ramil]:
Рамиль,ты бы мене лучше подогнал инструкцию на русском языке
для Nikon D80,
у меня только японская версия
для Nikon D80,
Re[sascha56]:
от: sascha56
для Nikon D80,
http://nikoneurope-ru.custhelp.com/cgi-bin/nikoneurope_ru.cfg/php/enduser/std_adp.php?p_faqid=19033&p_created=1157595162&p_sid=brO6pTYi&p_accessibility=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjUmcF9wcm9kcz0xOSZwX2NhdHM9NjUwJnBfcHY9MS4xOSZwX2N2PTEuNjUwJnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Re[NikZ]:
CadetRnd
но это же, опять английский версион :-(
ребята,где же русская версия,
хотя и не смертельно,уверен в этой камере есть ещё много функций,мне неизведанных ,но увы ...
