Canon PowerShot S120
Всего 62 сообщ. | Показаны 1 - 20
Imaging
Pixels Actual: 12.8 Megapixel
Effective: 12.1 Megapixel
Sensor 1/1.7" CMOS
Bit Depth 12-bit
File Formats Still Images: JPEG, RAW
Movies: MOV, MPEG-4
Audio: Linear PCM (Stereo)
Max Resolution 4000 x 3000 @ 4:3
Aspect Ratio 1:1, 3:2, 4:3, 4:5, 16:9
Image Stabilization Optical
Optics
Lens EFL: 5.2-26 mm (35 mm equivalent: 24-120 mm)
Aperture: f/1.8 (W) - 5.7 (T)
Zoom Optical: 5x
Digital: 4x
Focus Range Wide: 1.97" (5 cm) - Infinity
Telephoto: 11.81" (30 cm) - Infinity
Manual: 1.18" (3 cm) - Infinity
Wide Macro: 1.18" (3 cm) - 1.64' (50 cm)
Tele Macro: 11.81" (30 cm) - 1.64' (50 cm)
Exposure Control
ISO Sensitivity Auto, 80-12800
Shutter 1 - 1/2500 sec
15 - 1/2500 sec in Aperture Priority Mode
250 - 1/2500 sec in Manual Mode
Exposure Metering Center-weighted, Evaluative, Spot
Exposure Modes Modes: Aperture Priority, Auto, Manual, Movie, Programmed
Auto, Shutter Priority
Compensation: -3 EV to +3 EV (in .3 EV steps)
Shooting Modes Fireworks
Fish-Eye Effect
HDR
Miniature Effect
Portrait
Poster Effect
Smile
Snow
Soft Focus
Toy Camera Effect
Underwater
White Balance Modes Auto, Cloudy, Custom, Daylight, Flash, Fluorescent,
Fluorescent H, Tungsten, Underwater
Burst Rate Up to 12.1 fps for up to 6 frames
Up to 9.4 fps for up to 635 frames
Up to 5.6 fps
Up to 5.5 fps
Self Timer 10 Sec, 2 Sec
Flash
Flash Modes Modes: Auto
Flash On
Off
Slow Sync
Compensation: -2 EV to +2 EV (in .3 EV steps)
Built-in Flash Yes
Effective Flash Range Wide: 1.64 - 22.97' (0.5 - 7 m)
Telephoto: 1.64 - 7.55' (0.5 - 2.3 m)
Memory
Memory Card Type SD
SDHC
SDXC
Recording
Video Recording Yes, NTSC/PAL
Resolution 1920 x 1080: 60 fps, 30 fps, 15 fps
1280 x 720: 30 fps, 6 fps, 3 fps, 1.5 fps
640 x 480: 120 fps, 30 fps, 6 fps, 3 fps, 1.5 fps
320 x 240: 240 fps
Video
Video Clip Length Up to 29 Min 59 Sec
Audio Recording Built-in Mic: With Video, Stereo,
Viewfinder/Display
Screen 3.0" LCD Rear Screen (922,000 pixels)
Screen Coverage 100%
Connectivity/System Requirements
Connectivity HDMI C (Mini)
USB 2.0
Wi-Fi Yes
Environmental
Operating/Storage Temperature Operating
32 to 104°F (0 to 40°C)
Humidity: 10 - 90%
Power
Battery 1x NB-6LH Rechargeable Lithium-Ion Battery Pack, 3.7VDC, 1000mAh
AC Power Adapter ACK-DC40 (Optional)
Physical
Dimensions (WxHxD) 3.9 x 2.3 x 1.1" / 100.2 x 59.0 x 29.0 mm
Weight 7.65 oz / 217 g CIPA standard
MSRP: $450
Availability: 10/2013
Re:
Несколько фоток, в помощь определяющимся. Джипег, ресайз.
Re[elvis57]:
ужас
Re]:
Шо, опять?!:)
Re:
О ужас
Re[elvis57]:
а что там при съемке в помещении? или вечерком....как ведет себя камера?
Re[Photoграф]:
Да плохо себя ведёт, на трёхсотых кадрах жрать просит.
Фотки будут как только так сразу.
Re[elvis57]:
от: elvis57
Поэтому нужно носить с собой запасной аккумулятор. У меня был s100 - на природе фото очень даже приличные, а в помещении при плохой освещенности вспышку просит. По-моему, s100-s120 как карманный аппарат вполне подходящая модель.
Re[MihPuch]:
есть еще nikon p340 , похожий по характеристикам, так кто же фаворит ? Он и панораму лепит...., а кэнон что может? Может у канона качество снимков выше, чем у никона? Покажите нам всю мощь кэнона!!!!! или не годится он на роль лидера?
Re[MihPuch]:
от:MihPuch
Вполне нормальный аппарат!
300 кадров -это отлично, А510-540 (2хАА) по 200-250 выдавали днем, А60-А75 (4хАА) 400-450.
Начальная зеркалка конечно получше - с экраном 800-1200, по видоискателю за 1600, только видоискатель нужен на ней чтобы гистограмму контролировать - гораздо больше ошибается по сравнению с компактами Кэнон, так что даже из рава пересветы не убрать.
Интересно есть рав у s100-s120?
Re[Порядочная Сволочь]:
от: Порядочная Сволочь
Есть. Можно снимать в raw, jpg и raw+jpg. В 120 процессор как в G16, а в 100 и 110 как в G15.
Re[Photoграф]:
Скандалы, интриги, расследования... :D Панорамы не слеплю, фотки выложу.
Сдаётся мне, я один отдуваюсь за 120-й. Канон должен будет! :D
У Никона специфический жёлтый, кенон камерный.
Re:
Кадры с Патриаршего моста, ФР 24-26. RAW, Lightroom.
Re[MihPuch]:
Зачастую стоит вопрос: получить кадр на 4+ или не получить совсем. Андроид на Гелекси с лучшими камерами - не устраивает, всё на автомате.
Беззеркалка EOS M в сумке не спасает- не достать (молния сумки-липучка чехла-крышка объектива).
Карманный компромисс S100-120 устраивает. Может Никон 340 - так на фаната.
Re[MihPuch]:
от: MihPuch
Если DPP видит этот RAW - то тогда камера вообще супер, и за неочень дорого! 8)
Re[elvis57]:
от:elvis57
ИМХО - лучше чем DPP Цвет ничто не передает (LR также)!
Можете выложить рав(ы) - на яндекcе например?
Re[elvis57]:
от: elvis57
Мне по цветам никон не нравится!
Нет, конечно были Никоны отличные по некоторым цветам, и в некоторых условиях съемки (рассвет, закат) - здесь D40 D50 D60 D70 D80 вне конекуренции - чистый цвет рассвета и заката солнца - я на кэнонах так и не смог такой чистоты цвета добиться в этих условиях съемки, да вообще ЦЗ кэнон в таких условиях давал гразный цвет на уровне мывльниц самых дешевых, никак его невозможно было скорректировать, но эти никоны уже не выпускают.
И у Никонов недостатков с Авто ББ был в раз 5 больше чем у начальных Кэнононов тех времен (300D 350D 400D) при обычной съемке - никоны синили сильно часто (60% левый автоББ), там где кэнон отрабатывал автоББ на отлично на 99% кадров.
