http://web.canon.jp/imaging/eosd/firm-e/eos5dmk2/firmware.html
Firmware Version 2.0.3 incorporates five enhancements to the movie function and a fix to the manual sensor cleaning function of the EOS 5D Mark II camera.
1. Adds or changes the following movie frame rates.
NTSC:
* 1920×1080 : 30 fps (changed - actual 29.97 fps)
* 1920×1080 : 24 fps (added - actual 23.976 fps)
* 640×480 : 30 fps (changed - actual 29.97 fps)
PAL:
* 1920×1080 : 25 fps (added - actual 25.0 fps)
* 640×480 : 25 fps (added - actual 25.0 fps)
2. Adds a function for manually adjusting the sound recording level (64 levels).
3. Adds a histogram display (brightness or RGB) for shooting movies in manual exposure.
4. Adds shutter-priority AE mode (Tv) and aperture-priority AE (Av) mode to the exposure modes for shooting movies.
5. Changes the audio sampling frequency from 44.1 KHz to 48 KHz.
6. Fixes a phenomenon where communication between the camera and the attached lens is sometimes interrupted after manual sensor cleaning. (This phenomenon only affects units with Firmware Version 1.2.4.)
Firmware Version 2.0.3 is for cameras with firmware up to version 1.2.4. If the camera's firmware is already version 2.0.3, it is not necessary to update the firmware.
Movies captured using EOS 5D Mark II cameras with Firmware Version 1.1.0 to 1.2.4 can be played back on cameras updated with Firmware Version 2.0.3. However, if you try to play back movies captured with a camera with the new firmare on a camera with a previous firmare version, a message, Cannot play back image, appears on the camera's LCD monitor.
It is recommended that you use the latest Canon applications*1 to edit movies captured with EOS 5D Mark II cameras that have the latest firmare because some previous versions do not support movie-editing functions and the frame rates that are added or changed by the latest firmware. You can download the latest Canon applications from our Web site.
*1 ZoomBrowser EX Version 6.5.0 or later (compatible operating systems : Windows XP/Vista/7)
ImageBrowser Version 6.5.0 or later (compatible operating systems : Mac OS X v10.4/10.5/10.6)
In addition to the enhancements to the movie function, the accompanying instruction manual has also been revised. Users are asked to download both the latest firmware and the latest instruction manual. You can proceed to download the instruction manual by clicking the [I Agree] button from the bottom of this page.
Canon как и обещал к середине марта прошивку! 2.0.3 Canon 5D Mark II
Всего 36 сообщ.
Re[Tynda]:
Поставил качать, параллельно почитаю мануалы, что да как :)
Смущает то что "Firmware Version 2.0.3 is for cameras with firmware up to version 1.2.4" - нужно ли предварительно прошивать 1.2.4 если стоит 1.1.0?
Re[SunnyPanth]:
Да, я сегодня поставил. Если что - update прошел без проблем, в меню наблюдаю новые видео-режимы. А детальнее не знаю - чукча не писатель, видео пока пробовал только однажды из любопытства ;-)
Re[Yurko]:
от: Yurko
В смысле поставили 2.0.3 это понятно, а до этого какая версия была? :) Вообще на официальном сайте написано, что 2.0.3 включает все прежние "улучшения", так что буду накатывать на 1.1.0 :)
Re[SunnyPanth]:
от: SunnyPanth
...буду накатывать на 1.1.0
И правильно. Только что обновил от 1.1.0 - всё в норме.
Re[SunnyPanth]:
от: SunnyPanth
Что-бы не смущаться, надо подучить язык! ;)
Re[Tynda]:
жаль тока 60 фпс так и не сделали... ну да ладно, будем довольствоваться тем что есть,.. посмотрим на их новую гистограмму.
Re[foto-boss]:
Угу, как раз от знания то смущение и возникло
Вам незнающим проще, воткнул в розетку, поюзал, а потом уже книжкечку с инструкцией спокойненько почитал сидя в маленькой укромной комнатке :P
Re[Tynda]:
Есть вопрос студии, задавал в одной из веток но ответа так и не получил.
Сейчас на стандартной прошивке 1.1.0, что конкретно измениться на 1.2.4 или 2.0.3 в меню ?
То-е какие дополнительные пункты появятся, это только для видео или ещё какие отличия от 1.1.0 в меню будут (или доп. настройки) ?
Интересует кроме разницы в прошивках такой момент. Насколько слышал у 5d-2 есть режим тихой фотосъёмки при котором камера существенно тише шлёпает зеркалом. Поковырялся в меню и этого пункта настройки пока не обнаружил.
Что скажут знатоки, существует такой режим работы у 5д-2 ?
Re[Чатланин]:
Вкладка "Настройка ЖКД-видоиск/Видеозаписи" третья сверху позиция - Тихая съемка
Ковыряться хорошо в дупе, а тут нужно инструкцию читать
Re[Sergey Taran]:
и на что влияет этот режим - на фоторежим или на видео режим?
лан не поленился нашел на компе инструкцию и прочитал - один фиг не удобная фича
Re[uspehov]:
А я нею и не пользуюсь, поэтому не могу ничего сказать об удобстве.
Re[Yurko]:
от: Yurko
Скажите, пожалуйста, а что именно новое Вам удалось понаблюдать с новой прошивкой?
Re[Sergey Taran]:
от: Sergey Taran
Читалось и ковырялось, :) то что вы описали видел, работает только в режиме лав-ю.
Да и там толку нуль от этих настроек (попробовал и убрал нафиг).
Речь идёт об тихом режиме съёмки без использования лав-ю, на некоторых камерах знаю такое есть когда механика работает в другом алгоритме (несколько медленнее) при котором звук срабатывания существенно тише.
Возможен такой на 5д-2 в стандартной или кокой-то другой прошивке ?
Re[Tynda]:
Надо же было выпустить прошивку без единого нужно изменения!
Re[foto-boss]:
от: foto-boss
+100
Так это уже 3-я по счёту.
Нет чтоб нормальный автоисо или ещё чего.
Поставил для проформы :( .
Re[Arik25]:
И я поставил, ведь в глубине души теплится надежда, а вдруг чего улучшили? :D
Re[foto-boss]:
от: foto-boss
Дык все этим и занимаются,ставят,а вдруг :D чудо,ан нет,тютю..
Буду ждать теперь,когда хладоген для матриц в следующую поршивку зальют,чтоб не грелась
Re[foto-boss]:
от: foto-boss
нужно уточнять, что для вас конкретно ни единого нужного...
Re[foto-boss]:
от: foto-boss
Все форумы владельцев переполнены нытьём по поводу отсутствия 25к/с в пядваке. СержСмарт не даст соврать. Так что баальшое спасибо кэнону!
