Canon 24-85 vs. 28-135
Хотелось бы услышать отзывы тех, кто имел возможность сравнить в работе эти два объектива. Прежде всего интересует жесткость рисунка. По тестам вроде как лидирует 28-135. Заметно ли это на глаз на отпечатках, скажем 18х27 и 20х30?
http://photozone.de/bindex2.html => Detailed User Reviews => Canon EF 28-135mm f/3.5-5.6 USM IS :
The 28-135mm is, for sure, a consumer lens as well but does it fit into the same category as the EF 28-105/3.5-4.5 or EF 24-85/3.5-4.5 ?
Overall I would rate the optical performance one step higher than the EF 28-105/3.5-4.5 USM and slightly inferior than the old EF 28-70/3.5-4.5. Obviously it is no competition for fix-focals - as most zooms.
Compared to competing products from different original manufacturers like e.g. the same-priced Nikkor 24-120/3.5-5.6 or Minolta 24-105/3.5-4.5 you can only come to the conclusion that despite its relatively high price tag this is indeed a very cheap lens because you basically get the same performance PLUS image stabilization!
All in all the Canon EF 28-135mm f/3.5-5.6 USM IS is an interesting travel lens.
