Уже поставил :D
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4234
наконец новая пятерка заработала...
Adobe выложил новый лайтрум 2,2
Всего 15 сообщ.
Показаны 1 - 15
Наконец новый лайтрум 2,2
Re[Фесенко Константин]:
Что ж он так распух опять? В два раза.
Re[Mad_Hatter]:
да и ладно, а то как без рук..
отвык от ДПП, а больше толком и нечем.
А теперь все как давеча.
А плагин для фотошопа половину этого весит..
вот на плагин и утяжелили
Он не распух. Просто там инсталлятор 32 и 64 бит
А что в нём нового?
Re[Sebastiano Pereira]:
от: Sebastiano Pereira
А что в нём нового?
The Adobe® Photoshop® Lightroom® 2.2 update includes these enhancements:
Additional camera support for the Canon EOS 5D Mark II, Canon PowerShot G10, Panasonic DMC-LX3 and more**
Includes several corrections for issues introduced by the Lightroom 2.0:
• Images rendered from the Slideshow export process produced a jagged effect on hard edges relative to the quality of normal JPEG export
• Increased the number of characters allowed in Web gallery labels beyond 150 characters
• Catalogs with hundreds of root (top level) folders caused very slow launch times
• Drag and drop to move a subfolder to a different folder showed the incorrect photos in the grid
• Print Sharpening produced edge artifacts in certain conditions
• Density defaulted to 100 percent for initial stroke regardless of position of slider
• The Adjustment brush created blocky, straight edges to brush strokes under certain conditions
• Lightroom could become unresponsive when using the graduated filter under certain conditions
• It was possible to lose the ability to edit an adjustment brush setting after applying a graduated filter with hidden pins
• Turning auto-mask on produced a lag in Lightroom performance in when applying the adjustment brush
• Print to JPEG functionality produced a low resolution image when printing photos with panorama aspect ratios
• Extended characters in a folder name caused Edit in Photoshop functionality to fail
• Smart collection did not respond to changes in custom metadata
• Enabling auto-mask produced a lag in performance in when applying the local adjustment brush
Lightroom 2 Enhancements
• Camera profiles are now available in the Calibration panel in the Develop module. These profiles are designed to provide different interpretations of raw capture.
Re[Criminally Insane]:
у меня с новой версией стал жутко глючить комп - как откатить назад к 2,1 ? кто знает - караул - часть конвертируется и стопорит. да и вообще тормозить стал и это на q9450
жесть, чего делать, вся работа встала :!: :!: :!:
Re[Покровский Николай]:
откат системы к ближайшей контрольной точке
от:Покровский Николай
у меня с новой версией стал жутко глючить комп - как откатить назад к 2,1 ? кто знает - караул - часть конвертируется и стопорит. да и вообще тормозить стал и это на q9450жесть, чего делать, вся работа встала :!: :!: :!:
Ничего подобного не наблюдаю (Vista64 + лайтрум64 2.2)... Только первый раз при эксорте в PS CS4-64 немного подзавис последний, но после - всё ок.
и авакс тоже выложил :-)
Спасибо, проворонил выход свежачка, давно не обновлял :)
Установил на Висту32, 10 часов работы, полет нормальный, глюков не обнаружено (пока ;) )
Больше всего во всех этих изменениях интересует насколько лучше стало профилирование. Вроде как уже не бета.
Кто-нибудь заметил улудшение/ухудшение?
Re[Del_aqua]:
Там и раньше было 2 дистрибутива внутри, убедитесь сами. Распухло просто в 2 раза.
Re[Mad_Hatter]:
После оч. большого перерыва загрузил, поставил... при использовании профилей цвет стал хорош... вроде все работает как всегда... правда, недолго осталось...
Большая просьба... помогите, у кого есть!!!
vlminaev@yandex точка ru
Re[Владимир Минаев]:
Сидел, читал этот топик, всё было хорошо, радовался за Адоб и всех пльзователей нового лайтрума. Но вдруг ни с того ни с сего как скрутило меня, как заломало, а таблеток в доме не оказалось. Еле-еле дотянулся до клавы. Всё, умираю через пять минут.
