А новый ФШ,то оказывается называется CS...(release 24/10/03)
Всего 26 сообщ. | Показаны 1 - 20
[quote:f48d4ee548]From the Manufacturer
Get superior results faster with industry-standard Adobe Photoshop CS software and its integrated Web production application, Adobe ImageReady CS software. Graphic and Web designers, photographers, and video professionals can take advantage of indispensable features that include improved file management, new design possibilities, a more intuitive way to create for the Web, and support for 16-bit images, digital camera raw data, and non-square pixels. Now you can create the highest quality images more efficiently than ever before.
Features:
Professional toolset: create original images or modify photos using a full assortment of painting, drawing, and retouching tools.
Color correction: improve the color, contrast, and dynamic range of any image with a comprehensive set of professional color-correction tools.
Enhanced layer control: composite images, text, and effects on hundreds of layers that you can organize with up to five levels of nesting and save in different combinations as Layer Comps.
Improved File Browser: quickly preview, tag, and sort images; search and edit metadata and keywords; and automatically share batches of files from the improved File Browser.
Advanced Web capabilities: create sophisticated Web page elements, such as rollovers and animations, using ImageReady--the only Web application that's completely integrated with Photoshop.
Healing Brush: effortlessly remove dust, scratches, blemishes, wrinkles, and other flaws with the Healing Brush.
Special effects filters: Easily experiment and achieve amazing results by accessing more than 95 special effects filters. Preview and apply more than one filter at a time with the new Filter Gallery.
Advanced type control: add vector-based text that you can edit at any time, format, warp, convert to outlines, and use for masks or other special effects.
Customized workspace: work the way that's best for you by saving personalized workspace and tool settings, and creating customized keyboard shortcuts.
Unparalleled efficiency: automate production tasks with built-in or customized scripts and the Actions palette which lets you record editing steps to quickly process batches of files.
Top Features for Graphic Designers:
Layers: achieve sophisticated results by compositing images, text, and effects on hundreds of layers that you control by grouping into sets, color coding, and locking.
Layer Comps: create design variations for clients more efficiently by saving different combinations of layers within the same file as Layer Comps.
Text on a path: Create eye-catching typography by placing text on paths or within shapes. Edit the text at any time, even in Adobe Illustrator software.
Customizable keyboard shortcuts: customize, save, and print a summary of your ideal set of keyboard shortcuts, so the functions you use most are always at your fingertips.
Artistic brushes: Simulate traditional fine-art techniques with dry and wet brush effects, pastel, charcoal, and more. Even use brushes to add special effects such as grass and leaves.
History palette: experiment freely knowing you can instantly undo or redo multiple steps with the History palette.
Color management guidance: easily access the new color management guide to take full advantage of powerful controls that ensure more consistent color on any device.
Support for extremely large images: create for billboards, bus wraps, technical imaging, and more by working with images up to 300,000x300,000 pixels and up to 56 channels per file.
Top Features for Photographers:
Comprehensive 16-bit support: perform more precise editing and retouching with expanded support for 16-bit images in core features, including layers, brushes, text, shapes, and more.
Integrated digital camera raw file support: get truer, higher-quality output by working with the complete raw data files from most major digital camera models.
Match Color command: achieve a consistent look between package shots, fashion photos, and more by instantly matching the color scheme of one image to another.
Histogram palette: monitor changes to your image in the Histogram palette, which dynamically updates as you make adjustments.
Shadow/Highlight correction: quickly improve the contrast of over- or under-exposed areas of an image while preserving the overall balance of the photo.
Crop and Straighten command: Scan multiple images at once and let Photoshop automatically straighten and save each image as an individual file.
Top Features for Web Designers:
Enhanced ImageReady user interface: create and modify Web designs faster with multiple object selection, object grouping, and smart guides.
Improved Photoshop integration: enjoy quicker, more seamless integration between Photoshop and ImageReady, plus automated file saving and common commands, tools, and shortcuts.
Image slicing: slice complex, layered images and apply appropriate format and compression settings to each area before exporting as an HTML table.
Variable data support: easily import database and spreadsheet information to automate the production of Web graphics.
Macromedia Flash (SWF) file export: use ImageReady CS to create Macromedia Flash (SWF) animations, complete with vector artwork and variable text.
Animated GIF creation: turn layered Photoshop or Illustrator files into compact GIF animations in a few short steps.
Web Content palette: create and edit rollovers and other interactive Web elements more easily using the new Web Content palette.
Layers-as-files export: optimize and export individual layers as separate files for use in Macromedia Flash (SWF) animations and dynamic HTML.
Weighted optimization: smoothly vary compression settings using channels to display higher-quality results in critical image areas.
Streamlined HTML output: create leaner, more easily edited HTML with new controls for nested tables, XHTML, and more.
Top Features for Video Producers:
Non-square pixel support: create and work with different aspect ratios to accommodate non-square pixels without distortion.
Enhanced 16-bit compositing: perform more precise matte painting, 3D rendering, and other advanced film compositing with expanded support for 16-bit images in core features, including layers, brushes, and more.
Guide presets: easily design using video-specific presets that show action-safe and title-safe areas of the screen.
Layers-to-files export: quickly integrate layered Photoshop artwork with a variety of video editing and compositing systems using the built-in Export Layers to Files command.
History palette: experiment freely knowing you can instantly undo or redo multiple steps with the History palette. [/quote:f48d4ee548]
Кто -нибудь знает , что там будет самого интересного?
Блин! Вы быстро печатаете... :)))
... правда brush в ФШ - это кисть ;)
А с нашей-то фотографической точки зрения что , интересно там нового?
Ну вот 16 битный цвет вроде будет лучше поддерживать,
фильтры как-то там одновременно можно будет применять,
А ещё что?
Re: Блин! Вы быстро печатаете... :)))
[quote:fc8bca45fc="Alexander Ye"]... правда brush в ФШ - это кисть ;)
А ещё что?[/quote:fc8bca45fc]
Будет расширена поддержка RAW (интересно, что D2H в списке не будет).
Да и все. И будет какая-то схема активации, однако.
[quote:4a99156b61="Практик"][quote:4a99156b61="Saturn"]
Да и все. И будет какая-то схема активации, однако.[/quote:4a99156b61]
Обращение к экспертам по распространению софта:
Господа Пираты!
Займитесь пожалуйста. Здесь полный форум ваших будующих покупателей. А активация нам не нужна.
Как-то ни к чему. До сих пор обходились.[/quote:4a99156b61]
Хе-хе... :) :)
Почитал на варезнике разговоры вокруг этой активации....
Господа хакеры уже во всеоружии, ждут не дождутся пока он живьем появится. Адобе пока принимает заказы, поставки начнутся в ноябре.
Я думаю меньше чем за день сломают, только появился бы :) :)
Слышал, что в 8 версии можно будет эффекты применять в виде корректирующих слоев.
Так держать!
[quote:a7a1a0e5f2="BlackRed"]
Господа хакеры уже во всеоружии, ждут не дождутся пока он живьем появится. [/quote:a7a1a0e5f2]
Молодцы! :)
Кстати...
... Scott Kelby уже подсуетился и книжку по нему свою выпустил
О как!
http://www.amazon.com/exec/obidos/ASIN/0735713537/ref%3Dpe%5Fsnp537/104-4595809-4923952
Ну вот...дождались
Adobe_Photoshop_CS_v8.0.PARADOX
[quote:3093add86a="GetUp"]Ну вот...дождались
Adobe_Photoshop_CS_v8.0.PARADOX[/quote:3093add86a]
Пока кривоватенький, народ попробовал, часть функций отрубилась, шоркаты, например.
Видимо кроме двух DDL и одного DAT-файла еще что то есть...
Подождем еще.....
Нет проблем, не горит :)
[quote:8912ffc2ea="GetUp"]Нет проблем, не горит :)[/quote:8912ffc2ea]
информация с варезника:
[i:8912ffc2ea]Насчет кряка от paradox. Библиотека AdobeLM.dll в оригинале весит 1.177 мб, крякнутая же версия - 3 кб. Вырезали чего-то лишнего. Вот и пропали шоткаты. Прошу заметить, не пашут шоткаты с комбинацией двух и более клавишь с Ctrl и Alt.[/i:8912ffc2ea]
А где бы его взять, от Парадокса?
Это решило бы мою проблему с большими файлами (см. пост ниже).
[quote:b46c3b9c99="Pampa"]А где бы его взять, от Парадокса?
Это решило бы мою проблему с большими файлами (см. пост ниже).[/quote:b46c3b9c99]
Сам кряк могу кинуть, но пока проблема стянуть сам ФШ.
Попробуйте на фарезнике (форумы http://forum.ru-board.com),
осликом народ вроде уже тянет, а по FTP я пока не могу пробиться.
А можно кряк сюда, плиз?
igor-a-pSobakaYandexTochkaRu
Re:
от:"BlackRed"
И снова дождались...
Adobe_PhotoShop_CS_v8.0_CRACKFiX-PARADOX.rar
Посмотрел CS (+)
ломать пока не стал - два дня в запасе на активацию ;)
В целом впечатление - разумная эволюция (хватит революций, да и пользователи не поняли бы скорее всего).
Поддержка 16 бит добавлена именно туда где она нужна для обработки фото - слои, набор необходимых для этого фильтров (для преобразования фото в картину маслом 16 бит не нужны ИМХО), выделения Color Range и прочие вкусности, может еще пару фильтров и добавят (по пожеланиям трудящихся :) ) но все фильтры ИМХО сомневаюсь...
Другое, что заметил:
Варианты интерполяции Bicubic (Smooth) и Bicubic (Sharp) не тестировал...
Photo Filter - аналоги обычных стеклянных 81, 85, 80, 82 (только эти четыре!) и всех остальных цветов с регулировкой по плотности - удобно для коррекции цветовой температуры, и для иммитации съемки в чб с фильтрами...
Shadow/Highlite - работает очень похоже на Curves, но результат получается быстрее, на алгоритм надо бы внимательней посмотреть... возможно для регулировки теней/светов лучше и не надо...
Добавился фильтр Blur Average - у меня работать отказался... :)
Режим наложения слоев Hard Mix - не разбирался...
Когда в Patch-е выбираешь кусок для замены - показывается превью того что получится - удобно...
Color Match - забавно, но ИМХО, результат несколько искуственный получается, впрочем тестировал довольно условно и не факт, что на изображениях для этого подходящих - хотя признаю, цветовая гамма становилась весьма схожей...
Индикатор выполнения длиннее раза в 3 - сначала поразился - как выросла скорость - потом понял, что 30% и 100% немного отличаются :D
Browser - поприятнее и остается в окне даже при открытых файла, а вот сможет ли он заменить ACDSee, не вообще а при работе паралельно с PS пока не ясно...
Вот вроде, что заметил за минут 40 судорожного тыканья в кнопки...
В целом - я за, для меня то, что нужно и добавилось то, чего в 7 иногда не хватало...
Всем удачи, :)
Re: Посмотрел CS (+)
GG,
Еще должно быть окно с гистограммой, меняющейся в реальном времени.
Браусер в 7-ом тоже можно держать в обьычном окне (это так, к слову).
C ломкой - осторожнее, от нее, говорят, горячие клавиши дохнут.
Re: Re: Посмотрел CS (+)
от:"control-z"
GG,
Byl vypushen CrackFix, ispravljajushij etu problemu.
от: "control-z"
GG,
Есть такое окно, очень удобно!
от: "control-z"
Уже исправили...
Re: Re: Re: Посмотрел CS (+)
А как можно реанимировать быстрые клавиши? А то неуютно без них.
