а есть ли 180* на кропе ?
задался вопросом а есть ли фишайчик на кропе .....
или чтоб снимать с 180* нада брать пятачек и и фишайный обьектив ....
при поиске оного не выявил на кроп ... =(((
Re[Gramatycks]:
от: Gramatycks
На 4/3 есть диагональный фишай.
П.С. картинка злостно сперта с olympus.ourlife.ru, автор - Андрей Судьбин
Re[Gramatycks]:
от: Gramatycks
AF DX Fisheye-NIKKOR 10.5mm f/2.8G ED - Ultra wide picture angle of 180 degrees on DX sensor - выпускается с 2003 года... обзор тут - http://www.photozone.de/8Reviews/lenses/nikkor_10_28_fish/index.htm
Re[Gramatycks]:
180 на кропе невыйдет. макс - диагон фишаи 8мм, есть пеленг, сигма, к\н...
Re[artemapei]:
от: artemapei
[quot]The second problem is that the Nikon D1 image sensor is smaller than a standard 35 mm still frame by a factor of 1.5 so part of the circular image would be cropped off.
One solution is to optically convert the 6 mm fisheye lens image into a smaller image that correctly fits within the active area of the Nikon D1 image sensor. I built a simple adapter that reduces the focal length by a factor of 1.7 to 3.5 mm efl (a reduction factor of 1.5 would be preferred but was not as convenient to implement). The optical adapter consists of a 50 mm f1.4 Nikon AFD lens attached to the D1. This is attached directly to a reversed 85 mm f2 Nikkor lens by a dual 52 mm macro ring coupler. These two lenses form a high quality relay lens with a magnification of 0.588 (reciprocal of 1.7).
[/quot]
[quot]The above fisheye image was produced by a Nikon 6 mm f5.6 fisheye lens coupled to a Nikon D1 digital camera via an optical relay. This image has a diagonal field of view of 220 degrees including everything from straight up to 20 degrees below the horizon.[/quot] - http://www.nearfield.com/~dan/photo/wide/fish/index.htm]Using the 6 mm Nikon fisheye lens with the Nikon D1 camera
Re[artemapei]:
от: artemapei
Tokina 10-17, которая на коротком фокусе - честный диагональный фишай.
Re[Gramatycks]:
от: Gramatycks
диагональные фиш-аи для кропа (угол зрения 180 град. по диагонали кадра):
для Никона - Nikkor 10.5/2.8 DX
для Олимпуса - Olympus ED 8 mm f3.5
есть еще нечто для Sony - Sony 16mm f/2.8 a (alpha) Mount Digital SLR Fisheye Lens, но что-то меня смущает насколько он реально полный "диагональный фиш-ай"... Фокусное больше похоже на "полнокадровый". Хотя всё может быть.
для других "кропнутых" систем штатных фиш-аев, вроде не делают.
но есть еще вот такая хрень: Tokina 10mm - 17mm F/3.5-4.5 DX Autofocus Fisheye Zoom Lens - бывает с байонетмо Кэнона и Никона.
Кроме того - вы можете взять "циркулярный фишай" для полного кадра (Сигму 8/3.5 или белорусский Пеленг-8) и поставить на кропнутую камеру (Пеленг - делают нынче с разными байонетами... ну или переходник поискать). Получите вполне честный фиш-ай кропе, да еще с запасом (с темными краями- углами).
вот таким примерно образом
есть еще в природе такая хрень:
Re[QUAsit]:
токина не даст 180* на кропе
Re[МБ]:
прикольно. представляю себе эту конструкцию...
Re[artemapei]:
от: artemapei
http://www.tokinalens.com/products/tokina/atx107afdx-b.html
Mount availability: Canon EOS, Nikon-D,
Focal length: 10 to 17mm
Maximum aperture: f/3.5-4.5
Minimum aperture: f/22
Optical construction: 10 elements in 8 groups
SD glass: One elements
Coatings: Multi-layer
Angle of view: 180° to 100°
Minimum focus distance: 5.5 in. (14 cm)
Reproduction ratio: 1:2.56
Zooming system: Rotary type
Number of diaphragm blades: 6
Filter size: N/A
Maximum outer diameter: 2.75 in. (70mm)
Dimensions: 2.75 in. (70mm) X L 2.79 in. (71.1mm)
Weight: 12.3 oz. (350g)
Lens Hood Built-in
Availability: October 2006
Re[artemapei]:
от: artemapei
ага...
Re[МБ]:
кашмэр, я думал что будет нечто, но не настолько.... у мя есть 85/1.4, представляю, если на нем собрать....
Re[Gramatycks]:
У Никона есть DX 10.5mm. А на сапог - разве что Сигма 8мм
Re[Одиссей]:
токина ... она и зум !!!
и фишай
да еще и на кроп с байонетом под сапог !!!!!!!!!!
все иду искать по москве !!!!!
всем спасибо за помощь !!!!!
Re[Gramatycks]:
Токина 10-17 - обалденная линза.
А 6-мм объектив Никкор из статьи - большая редкость. Там на снимке уши фотографа получаются.
Re[vashper]:
Вот про Токину
http://www.foto-video.ru/art/id/11779.html?phrase_id=19843
а кстати - ведь адаптер из статьи может и к такому объективу тоже подойти
