Then, select the record area of the screen recorder
Всего 1 сообщ.
Показаны 1 - 1
Then, select the record area of OSRS Gold the screen recorder. This will allow you to record the things you are interested in recording. In my instance I was walking. Next, save your file to a filetype that windows can open. Next, launch windows media player to load the video.
This is where it gets tedious. You will need to copy frame-by-frame every image in the sequence. Next, you'll need to save the frames in paint. Next save all the pictures as numbers in a sequence, for example, the first frame, save it as 1 and the second frame as 2. and the next frame as 2 and so on.
Open up Macromedia flash, and then import the first image of the frame, it will ask you if you would like to import the entire sequence, this is basically all the images that you have numbered and clicked yes. You can now export your flash as a.gif.
When I first started playing I first started playing, the gp in my bank account was low. As I levelled up in Woodcutting (level 21/31/41), I had to consider, "Do I spend the gp to upgrade to (mithril/adamant/rune) hatchet?" (Similar with mining level 21/31/41 - if I upgrade to (mithril/adamant/rune) pickaxe, it will use up valuable gp in my bank account, and with melee (upgrading to better armor would consume valuable scarce gp). Ha! The old days e.
In this phase of development, I came across a post from Sal's forum. The post asked "What is the most efficient way to Old School RS Gold buy F2P when I have 2.2M GBP on my account?" While there were many choices, my favourite was the one that said "Anything you want!" With my poor gp, the questioner sounded good.
