Sigma 135mm f/1.8 DG HSM Art
Всего 1088 сообщ.
Показаны 881 - 900
Re[Dialeg]:
Это вообще теоретические MTF (расчетные). Фактические пока никто не опубликовал ибо объектив не поступил еще в продажу (только-только цена появилась на одном из сайтов на предзаказ).
Re[Одиссей]:
Сигма публикует
Diffraction MTF
и
Geometrical MTF
и комментарий:
There are two types of MTF chart. One considers the diffraction quality of light, which is called “Diffraction MTF”, and the other, “Geometrical MTF” does not.
The quality of light appears in the diffracted light, and becomes more distinct as the F value gets bigger, resulting in lower image quality. Also, diffracted light exists at every aperture, which is why SIGMA has been releasing Diffraction MTF data from the beginning since it is very close to the actual image data.
The advantage of using “Geometric MTF” data is that it is easy to measure and calculate since it does not consider the diffraction quality of light, yet it tends to show higher values in the graph than actual images.
The readings at 10 lines per millimeter measure the lens’s contrast ability ( red lines), repeating fine parallel lines spaced at 30 lines per millimeter measure the lens’s sharpness ability (green lines), when the aperture is wide open.
Fine repeating line sets are created parallel to a diagonal line running from corner to corner of the frame, are called Sagittal lines (S) and sets of repeating lines vertical to these lines are drawn, called Moridional (M) line sets.
Diffraction MTF
и
Geometrical MTF
и комментарий:
Re[OlAf]:
Купили? :D
Re[Юрий Эр]:
Царь сказал - покупай!
Re[OlAf]:
Резко - до безобразия ... Только стрит и технику ИМ.
Re[GUNIK]:
Да фик его знает, то ли стрит, то ли пиззаж, или в бане поснимать крупнячок
Re[OlAf]:
135 mm + + 200
Re[OlAf]:
Судя по этим графикам, единственное проявление дифракции - снижение контраста в центральной зоне... "не маловато будет"?
Re[Одиссей]:
Для пейзажа будет шикарна.
Re[OlAf]:
Зато для портретов 135/2 л интереснее 8)
Re[Lonely Boy]:
Неужели?
Re[OlAf]:
Резкость конечно убойная. :D
Re[S3T]:
50 мегапикселей разрешает на открытой.
Re[OlAf]:
от: OlAf
Угу. Да и предметку не слишком мелкую недурственно подснимет!
Re[OlAf]:
от: OlAf
Неужели?
Не, ну я тоже себя так "утешаю"...ввиду отсутствия свободной "капусты" на апгрейд!
Еще говорю:"ТЯЖЕЛАЯ БАНДУРИНА!"
Re[OlAf]:
OlAf, как ощущения в сравнении с Кенон?
Re[Editorrr]:
... не поверите... тот же самый вопрос к уважаемому! :) ;) :!:
особенно интересует работа АФ. Как с точность... так как кто чего пишет...
