Canon EOS 77D/80D
Всего 10782 сообщ. | Показаны 1 - 20
Canon EOS 80D (+ new 18-135 NANO USM)
Кому новый кропъ? :) http://cweb.canon.jp/newsrelease/2016-02/pr-80d.html
Поступит в продажу 25 марта 2016 года по цене $1199.00 (body).
Официальная страница на Canon.ru
Официальная страница на Canon.jp
Canon EF-S 18-135mm f/3.5-5.6 IS USM Lens NANO USM Autofocus System
Canon PZ-E1 Power Zoom Adapter
Видеообзоры
[object width="560" height="315"][param name="movie" value="http://www.youtube.com/v/wC5tUSm3rhk&hl=en_US&feature=player_embedded&version=3"][/param][param name="wmode" value="opaque"][/param][embed AllowScriptAccess="never" src="http://www.youtube.com/v/wC5tUSm3rhk&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" wmode="opaque" width="560" height="315"][/embed][/object]
[object width="560" height="315"][param name="movie" value="http://www.youtube.com/v/mFFVwtr-sLI&hl=en_US&feature=player_embedded&version=3"][/param][param name="wmode" value="opaque"][/param][embed AllowScriptAccess="never" src="http://www.youtube.com/v/mFFVwtr-sLI&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" wmode="opaque" width="560" height="315"][/embed][/object]
[object width="560" height="315"][param name="movie" value="http://www.youtube.com/v/Fj2O7ZUS_Xk&hl=en_US&feature=player_embedded&version=3"][/param][param name="wmode" value="opaque"][/param][embed AllowScriptAccess="never" src="http://www.youtube.com/v/Fj2O7ZUS_Xk&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" wmode="opaque" width="560" height="315"][/embed][/object]
[object width="560" height="315"][param name="movie" value="http://www.youtube.com/v/PhdQLL-v6Sc&hl=en_US&feature=player_embedded&version=3"][/param][param name="wmode" value="opaque"][/param][embed AllowScriptAccess="never" src="http://www.youtube.com/v/PhdQLL-v6Sc&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" wmode="opaque" width="560" height="315"][/embed][/object]
Re[dimanes]:
АА фильтр есть?
Re[dimanes]:
Чет не оч информативный первый пост...
Re[OlAf]:
от: OlAf
АА фильтр есть?
Похоже, что да (под номером 1):
Re[dimanes]:
Вот тут на более понятном языке)
http://thenewcamera.com/tag/canon-80d/
Практически - немного урезанный 7ДМ2. Легче, чем 7ДМ2.
Ну и наверное?!)) дешевле.
Detailed specification of the Canon 80D tossed over the web, take a look at the details below…
– New 24.2MP APS-C CMOS sensor. Adopt a new miniaturization process
– Dual Pixel CMOS AF
– Image processing engine DIGIC6
– Regular sensitivity ISO100-16000 (extension 25600)
– 7560 pixel RGB + IR photometry sensor
– AF 45 points (all points cross type). AF distance measuring point of maximum 27 points F8 correspondence. -3EV Correspondence
– Four of the AF area selection modes, including a new “L zone AF”
– Continuous shooting 7 frames / sec. 3 frames / second at the silent continuous shooting mode
– The number of pictures 77 copies in JPEG. 20 sheets in RAW
– Continuous shooting in live view mode 5 frames / sec. (AF tracking)
– New mirror vibration control system to keep the mirror shock (MVCS)
– Finder is 100% field of view, magnification 0.95 times
– Shutter 30 seconds -1/8000 seconds. Synchro 1/250 sec
– 3 inches 1.04 million dot Vari-angle LCD monitor
– Built-in flash (guide number 12)
– Electronic Level
– A new Picture Style “fine detail”
– 10 kinds of scene mode
– Anti-flicker
– Video is full HD 60fps. AF tracking
– HDR movie
– Time-lapse movie
– Five types of movies Creative Filters
– Wi-Fi, NFC. Remote shooting
– Media SD / SDHC / SDXC (UHS-I compatible)
– Durability of the shutter is 100,000 times
– USB terminal, HDMI terminal, microphone jack, headphone jack, remote control terminal
– Improved dust and water
– The battery LP-E6N / LP-E6
– Start-up time is 0.16 seconds
– EF-S18-135mm F3.5-5.6 enables remote shooting using the power zoom function in combination with IS USM and the power zoom adapter PZ-E1
– The size of 139.0 x 105.2 x 78.5mm
– Weight 730g (650g body only)
Re[dimanes]:
автофокус 45 крестов
и если я правильно понял перевод, 27 точек работают при f/8
матрица 24 мп. дуалпиксель.
пишут что-то про новую технологию в изготовлении датчиков cmos сенсора, улучшение соотношения сигнал/шум и пошире дд
iso 100-16000, расширяется 25000
iso при видеозаписи 100-12000
7 кадров/сек (5 кадров лайввью)
выдержка 1/8000, x-sync 1/250
процессор digic 6
какой-то датчик замера на 7560 пикселей RGB + ИК
100% видоискатель
в лайв вью экран
есть возможность кадрирования, в т.ч. для видео в соотношениях "3: 2" , "1: 1","4: 3", "16: 9"
видеозапись
в формате MOV
MP4
плюс добавили фильтры для видеосъемки, есть таймлапс
добавили разъем для наушников!!!!!
размеры 139,0 (ширина) × 105.2 (высота) × 78,5 (глубина) мм
плюс выпускают до кучи базу nfc, направленный микрофон, новый объектив и приблуду для зуммирования в видео
1200$ за коробку на старте.
1800 - в ките с этим новым темно/кинозумом.
Re[dimanes]:
давайте уже 6D Mark II выкатывайте на рынок зачем с кропами играться? Если играть то по взрослому, только полный кадр Ну а если по теме ещё, то камера вроде ничего, если за 7d mark II не хочеться переплачивать то очень даже неплохой вариант.
Re[dimanes]:
от: dimanes
Похоже, что да
Значит опять мимо кассы.
Re[dimanes]:
а в чем разница между 7d m2 и этим 80D ? цена явно разная, угробить продажи 7ки решили?
Re[Максим Миронов]:
7dmkII это быстрая репортажная камера и для птичек практически в профессиональном исполнении
а 80D сбалансированный любительский топовый кроп без фанатизма, но в общем все имеется
процессор один и тот же самый DIGIC 6 что в 70D но
матрица с большим разрешением и меньшим шумом, значительно лучше автофокус причем и "двойной пиксель" тоже улучшен, новая система замера с антифликером, увеличенный буфер и 100 процентный видоискатель
для видео
таймлапсы, Full HD 60 кадров, HDR видео, выход на наушники
вполне годный аппарат для любителей и начинающих профи, беда только с курсом
Re[dimanes]:
Любая камера этой серии у Кэнона будет отличной. По-моему даже обсуждать нечего. Единственное, что сегодня добивает- это наш курс рубля.
Re[FYII]:
Не для фокусировки, я для зуммирования плавного. Для "видеографов" штука, которые не знают, что для съемки видео давно видеокамеры придуманы.
Re[dimanes]:
если говорят о камере и упоминают о том что она делается для птичек у меня это всегда визывает улыбку на лице :)
Re[iTuner]:
Я бы даже сказал, что не совсем любительский. Портреты на ура получаются на этой серии.
Re[andriy1988]:
для кого то фото охота страсть и ничего не поделаешь :)
а купить очень дорогие телелинзы может позволить себе далеко не каждый и не таскать их не каждый готов, вот и берут быстрый кроп и линзу попроще
7DmkII выручает
Re[mock]:
от: mock
точно, очепятка вышла, поправил.
ну, некоторые вещи удобнее на фотокамеры снимать, т.к. у них большая матрица, да еще и высокая светочувствительность. от задач зависит.
Re[dimanes]:
Насколько станет дешевле 70D после старта продаж 80-ки - вот в чем вопрос?
Re[Pоман]:
Уже снижают цены до 800 за бугром
Все от дилера зависит в общем то
