Полный кадр Pentax K-1 - официально
Всего 924 сообщ. | Показаны 1 - 20
http://us.ricoh-imaging.com/product/k-series/k1/
The K-1 takes greatness to the next level. As the first full frame DSLR engineered under the PENTAX brand, the K-1 brings outstanding performance, operability and affordability to photographers. With its large 36.4 megapixel CMOS image sensor, the K-1 incorporates all of the performance of a high-resolution full frame 35mm digital camera as well as all of the unique PENTAX-original features and technologies that photographers have become accustomed to, in a compact, rugged, weather-resistant body.
High-resolution, fine-gradation images supported by approximately 36.4 effective megapixels
The K-1 features an AA filterless design that prioritizes image resolution. Coupled with the new PRIME IV imaging engine, capable of 14-bit RAW-format image recording. The K-1’s unique full frame sensor and imaging engine design also allows for super-high-sensitivity shooting up to ISO 204800, producing beautiful, high-resolution images.
overview
specs
in the box
support
media
In-body SR mechanism assures optimal shake reduction performance
The SR II five-axis mechanism enables accurate control of the large full-frame image sensor with all compatible PENTAX interchangeable lenses.* In addition to camera shake caused by pitch and yaw, it effectively compensates for camera shake caused by horizontal and vertical shift, as well as camera shake caused by roll, which is difficult to deal with by lens-installed shake reduction mechanisms. Even when taking a panning shot, this system automatically detects the direction of the camera’s movement, and efficiently controls the SR unit to always produce the best image possible.
Pixel Shift Resolution System with a new motion correction function
The K-1 uses the latest super-resolution technology, which captures four images of the same scene by shifting the image sensor by a single pixel for each image, and then synthesizes them into a single composite image. Since the K-1’s SR unit has a flexible design that tilts the image sensor unit in all directions, it provides a host of handy shooting functions, including auto level compensation, image-composition fine-adjustment, and ASTRO TRACER, which simplifies advanced astronomical photography using a built-in GPS module.
Re[Nik79]:
overview
specs
in the box
support
media
Flexible tilt-type LCD monitor to accommodate various shooting angles
The K-1 features a newly designed, flexible tilt-type LCD monitor, which tilts horizontally, vertically or diagonally with a single action, without deviating from the lens’s optical axis. 35 degrees of horizontal and 44 degrees of vertical adjustment can be achieved, the LCD panel can even be laid flat up or down. The 3.2-inch LCD monitor features a tempered-glass front panel for added durability and a unique air-gapless construction effectively reduces reflection.
Newly developed SAFOX 12 with 33 sensor points and full-frame-proportioned AF frame
The SAFOX 12 AF sensor module features 33 AF sensors (25 cross-type sensors positioned in the middle). The center sensor and the two sensors located just above and below it are designed to detect the light flux of an F2.8 lens, making it easy to obtain pinpoint focus on a subject when using a large-aperture lens.
Highlights
36.4 MP AA-Filter-less CMOS Sensor
SAFOX 12 33 Point AF System
SRII 5-Axis In-camera Shake Reduction
Pixel Shift Resolution System w/ Motion Correction
15 MP APS-C Crop Mode
Cross-tilt LCD Display
GPS/Electronic Compass/ASTRO TRACER
Weather-Resistant Body
Operation Assist LED Illumination
MSRP $1,799.95
Re[Nik79]:
Expected availability: April 05 2016
Continuous Shooting Up to 4.5 fps at 36 MP
Video Format 1920 x 1080p / 29.97 fps
Dimensions (WxHxD) 5.4 x 4.3 x 3.4" / 136.5 x 110.0 x 85.5 mm
Weight 32.6 oz / 924 g body only
Re[Nik79]:
УДАЛЕНО
автором в знак протеста против предвзятого и несправедливого модератора
писал в лс ему, всё впустую...
Re[Mишенька]:
а если еще учесть что пентакс делает кучи разных спешалов, то реально цена будет наверно 1300-1400 уже к ноябрю. ИМХО.
Re[Nik79]:
УДАЛЕНО
Re[Nik79]:
на первый взгляд
перед нами ФФ с пыле-влаго защитой, с встроенным 5-осевым стабом, с соневской 36Мп матрицей без АА. недорого.
без нормального видео. с невысокой скорострельностью. с только механическим затвором (проблемы с Д800(е) никого ничему не научили?)
насчет АФ пока говорить рано, нужны реальные тесты.
Re[Nik79]:
Так долго его и с такими трудами рожали, что прелагаю его назвать:
"Кесарь Первый"!
А может "Косарь"?
Ибо неплохо покосит цены на рынке Фулл-Фреймов?
Аппарат не идеальный, но весьма вкусный.
Допилят его "Вторым Кесарем" и будет совсем приятно через год-два
Re:
Это всё же случилось, рад за Пентаксистов!
Теперь точно попрёт
Re[Nik79]:
Дождались! :)
Re[N90125]:
Я не скажу, что это достойный ответ зажравшимся фирмам, но что то в этом есть ;)
http://dphotoworld.net/news/anons_pentax_k_1/2016-02-18-3992
Re[Nik79]:
...к нему бы еще оптики, может быть и поперло бы
Re[vorobev_sheryshev]:
от: vorobev_sheryshev
здрасте приехали. оптики у Пентакса предостаточно, а мануалы да со стабом в тушке это ваще фарева
Re[PHANTOM1956]:
от: PHANTOM1956
На вторичном рынке цены на оптику поднимут в лёт, переходники, хвосты там всякие затаривайтесь пока есть возможность ;)
Лимы давно есть.
Re[Alchan]:
от: Alchan
Новой? В магазинах горками? А мануалы со стабом - это поиграться. И тут пентакс не самая интересная камера.
Пс: не стоит преувеличивать ценность стаба в камере.
Re[OlAf]:
от: OlAf
Лимы давно есть.
Для понятия "система" это не густо
А вам обязательно ну вот просто новая нужна . А куча старой А, FA, К оптики не подойдет . Там много чего интересного есть и думаю что уж точно процентов 70-80 должны встаить и работать без проблем. Так что проблема вами надуманна
Так же как его и преуменьшать . Со стабом в камере вы платите один раз , со стабом в обьективе каждый раз за то что он стабнутый.
Кому-то в самый раз.
