Характеристики:
35/1,8
Focal Length: 35mm (Full Frame); 54mm (APS-C)
Maximum Aperture: F/1.8
Angle of View (diagonal): 63°26′ (Full Frame); 43°29′ (APS-C)
Optical Construction: 10 elements in 9 groups
Minimum Object Distance: 7.9 in
Maximum Magnification Ratio: 1:2.5
Filter Size: Ø 67mm
Maximum Diameter: Ø 80.4mm
Length: 3.2 in (Canon); 3.1 in (Nikon)
Weight: 16.9 oz (Canon); 15.9 oz (Nikon)
Aperture Blades: 9 (circular diaphragm)
Minimum Aperture: F/16
Standard Accessories: Flower-shaped lens hood, Lens caps
Compatible Mounts: Canon & Nikon, Sony.
45/1,8
Focal Length: 45mm (Full Frame); 70mm (APS-C)
Angle of View (diagonal): 51°21′ (for full-frame format); 34°28′ (for APS-C format)
Optical Construction: 10 elements in 8 groups
Minimum Object Distance : 11.4 in
Maximum Magnification Ratio: 1:3.4
Filter Size: Ø 67mm
Length: for Canon 3.6 in (Canon); 3.5 in (Nikon)
Weight: 19 oz (Canon); 18.3 oz (Nikon)
Compatible Mounts: Canon, Nikon, Sony
Цена каждого $599
Картинка с 45/1,8 на полностью открытой - автор Майкл Палмер.
