Здравствуйте.
Прошу подсказать, какой купить радиосинхронизатор для связки Sigma DP3M + YongNuo YN-560 III. Например, есть синхронизаторы Yongnuo RF-603N и Yongnuo RF-603С - для Никона и Кэнона, соответственно.
Вопрос: На Sigma DP3M без разницы, какой брать, т.е. можно любой ? Будет работать ?
Спасибо заранее
PS: есть инфа, что с SD14 не работает Yongnuo RF-603, поэтому вопрос очень актуален
UPD из сети:
As far as the 5D mkI and II, I've only ever been able to reliably get 1/160 with any trigger. With bodies supporting 1/250 sync speed, the 603 limitations come in, reducing it to 1/200.
However, with the Ricoh GR and Sigma DP3 Merrill which have leaf shutters, I can get to about 1/800 with the 603 mkII (triggers regardless of brand) before things go south
другой товарищ:
For a test I've used once a RF603 II (Nikon) on a DP3 but without TTL support. The YN560 II had an internal receiver, so I didn't need the second RF.
Однако, не без очумелых ручек:
fwiw.....I have a set of yongnuo 622c transceivers that I use with a canon flash system, and the only way I can get them to work on the sigma is to slide them back 1 or 2 mm in the hot shoe, or put a piece of tape over all the pins except the center pin. The result is the same, stopping any of the 4 "communication pins" from making contact while allowing the center pin to make contact.
I can get my 580EX II to work the same way (manual mode only, of course), slide it back in the hot shoe on the DP2M so only the center pin makes contact, or tape the pins on the flash.
gotta use a very thin tape like rubylith, or sign vinyl, as mentioned the hot shoe on the sigma is very tight.
I'm actually thinking about putting a little rubber cement in the little recesses over the outer contacts on the DP2M so using it with a non OEM flash will be easier. Should be able to dig it out with a toothpick if I change my mind later.
The other solution is to use a remote trigger with only a center pin. My Paul Buff trigger has that and it works.
only Sigma knows why, but at least the above is a work around (have I seen that word used in this forum before ?)
hope this helps.
так что все ок
Sigma DP3M + YongNuo YN-560 III+ радиосинхронизатор
Всего 5 сообщ.
Показаны 1 - 5
Re[Fudo]:
Я брал DSLRKIT PT-08XT из-за того, что он работает со старыми вспышками с высоким напряжением синхронизации. Ничего так, с СД14 работал.
Если вспышка будет современная, а не дающая 500 вольт на контакты, то, думается мне, любой который по центральному контакту может поджигать - подойдет.
Re[Fudo]:
А зачем покупать RF603, если за совсем небольшие деньги можно взять YN560-TX, который умеет выставлять удаленно мощность, зум и режим съемки для шести разных групп вспышек?
Re[barmalini]:
он здоровый и для меня избыточен. Вспышка будет одна, для дома, для семьи)
Re[Fudo]:
Конечно, вам решать, но для дома, для семьи и для всех других применений одной вспышки категорически недостаточно. Нужно две, лучше три и вы обязательно запаритесь у каждой настройки устанавливать вручную. Сам синхронизатор, конечно покрупнее чем RF603, но в абсолютных размерах - как два коробка спичек, а уж на фоне Yongnuo, с ее конским размером и слоновьим весом, этот синхронизатор не кажется чрезмерно большим.
