Наткнулся в сети на очень интересный проект фонаря. Он отличается достаточной мощностью, компактными размерами, большим количеством предлагаемых аксессуаров и дополнительных возможностей.
Возможность крепления на фотоаппарати штатив.
Теплый и холодный свет.
Ссылка на проект: http://www.indiegogo.com/proje...lumen/x/3962821
Я сделал предзаказ. думаю многим будет интересен данный фонарь.
Небольшая выдержка из описания:
Infinitely Adjustable Output - Pressing down on the switch turns the light on and off. Rotating the control knob allows the user to adjust the output from less than 1 lumen to 1600 lumens.
3 x LED emitters - Cree XPG2 for maximum lumens or Nichia 219 Hi CRI for a neutral white beam with perfect color rendition
Copper LED Star Board - The emitters will be installed on a copper "pillar" star board which has no dieletric layer like the typical LED star boards. The custom board allows the LEDs to run cooler for a longer life. Also, it allows us to drive the LED harder without sacrificing too much efficiency.
Aluminum Unibody - The body is intricately CNC machined from a solid block of 6061 aluminum.
Size - 3.31" x 1" x 1.85" (84mm x 25.4mm x 47mm)
Weight - 5.5oz (156g)
HAIII Hard anodized - All aluminum parts on the light are anodized in matte black. The HAIII anodizing provides a scratch resistant coating with a 0.001" thickness.
Strobe - Strobe mode offers variable strobe flash rate and variable strobe brightness.
Battery Compatibility - The Function light can be used a single Lithium Ion 18650, two Primary CR123A, or two Lithium Ion 18350 batteries.
Battery Life (on Max)
Lithium Ion 18650 - 1 hr 40 min
CR123A Lithium - 1 hr
IMR18350 - 40min
Reverse Polarity Protection - The light's driver circuitry is designed to protect itself if the battery is ever installed backwards.
1/4-20 Tripod Mounting Threads - Two 1/4-20 tripod threads on the top and back of the light allows fo easy mounting with commonly available camera mounts.
Anti-Reflective Coated Glass - The mineral glass lens has an anti-reflective coating on both surfaces to maximize the light output.
Water Resistant - The Function light is designed with O-rings and gaskets so that it can function in any weather condition.
Battery lockout - A half turn counter-clockwise on the battery cap will lock out the light to prevent accidental activation
Thermal Protection - An on board temperature chip allows the microcontroller to manage the heat generated by the LED's.
Microcontroller Powered - The functionality of the light is all programmed via an ATTINY microcontroller. With a 8-SOIC clip, the Function flashlight can be reprogrammed such that it meets your specific needs.
Operation
Mode 0 - The light will be OFF in Mode 0.
Mode 1 - The light will be On in Mode 1 and adjusting the knob will change the output brightness of the light.
Mode 2 - Rate control strobe mode allows the user to change the strobe rate via the control knob. By default, the brightness is 100% but the brightness will be saved when adjusted in Mode 3.
Mode 3 - Brightness control strobe mode allows the user to change the strobe brightness via the control knob. The strobe rate is determined by the setting in Mode 2.
Soft Lockout - Soft lockout will prevent accidental activation of the light.
Mechanical Lockout - Mechanical lockout will prevent accidental activation of the light by physically disconnecting the battery. Using the mechanical lockout is recommended when the Function flashlight will be stored away for a long period of time.
What You Get
Cool White Cree XPG2 or Neutral White Nichia 219 High CRI emitter
CR123A battery tube to prevent rattling when using the smaller diameter batteries
Narrow (24°), Medium (30°) or Wide (40°) optic
Accessories
Check out the gallery for images of the different accessories.
Billet aluminum go pro mount - This mount will allow you to use the Function light with practically any GoPro mount.
Magnetic Ouput Modifier - A lantern dome, red or blue filter, or diffuser can be easily attached via the embedded magnet.
Magnet mount - The magnet screws into the rear 1/4-20 threaded hole and allows the attachment of the light to any ferrous surface.
Bike Helmet mount - Allows for mounting of the Function light onto any standard bike helmet. The mount attaches to the helmet via velco straps through the helmet's vent holes.
Bike Handlebar Mount - The handle bar mount allows for easy installation of the Function light onto any bike handlebar.
Backpack mount - A stainless steel clip which allows the Function light to be attached to the shoulder strap of a backpack. The clip is made from a ferrous grade of stainless to allow the clip to be used with the magnet mount for quick removal.
Suction Cup Mount - The suction cup mount will attach to any smooth flat surface. It will be great for attaching the light onto full faced helmets.
Hotshoe mount - The hotshoe mount with ball head is great for those that want to film video with the Function light.
Additional Optics - Different beam pattern optics will also be avialable for the user to go from Narrow (24°), Medium (30°) or Wide optics (40°).
Фонарь, который отлично подходит для видеосъемки function flashlight
Всего 1 сообщ.
Показаны 1 - 1
