Всего 79779 сообщ. | Показаны 53921 - 53940
Re[arie]:
от: arie
вот именно это и хочется получить !.. к сожалению не виден exif
Как вариант, основной объект морозить выносной пыхой на малой мощности, остальные размажутся сами за счет длинной выдержки.
Че сказал? :D
Re[arie]:
от: arie
К счастью exif виден :)
FileDateTime = 1367958498
FileSize = 234726
FileType = 2
MimeType = image/jpeg
SectionsFound = ANY_TAG, IFD0, THUMBNAIL, EXIF
[COMPUTED] html = width="830" height="586"
[COMPUTED] Height = 586
[COMPUTED] Width = 830
[COMPUTED] IsColor = 1
[COMPUTED] CCDWidth = 3mm
[COMPUTED] ApertureFNumber = f/8.0
[COMPUTED] FocusDistance = 1.41m
[COMPUTED] Thumbnail.FileType = 2
[COMPUTED] Thumbnail.MimeType = image/jpeg
ImageWidth = 3966
ImageLength = 2802
BitsPerSample = 16
Compression = 1
PhotometricInterpretation = 1
ImageDescription = Moscow Subway, Apr'2013
Make = OLYMPUS IMAGING CORP.
Model = E-M5
Orientation = 1
SamplesPerPixel = 1
XResolution = 720000/10000
YResolution = 720000/10000
ResolutionUnit = 2
Software = Adobe Photoshop CS5 Windows
DateTime = 2013:05:08 00:22:14
Artist = Dima Zverev www.dimazverev.ru
Exif_IFD_Pointer = 364
[THUMBNAIL] Compression = 6
[THUMBNAIL] XResolution = 72/1
[THUMBNAIL] YResolution = 72/1
[THUMBNAIL] ResolutionUnit = 2
[THUMBNAIL] JPEGInterchangeFormat = 1146
[THUMBNAIL] JPEGInterchangeFormatLength = 6424
ExposureTime = 13/10
FNumber = 8/1
ExposureProgram = 4
ISOSpeedRatings = 200
UndefinedTag:0x8830 = 1
ExifVersion = 0230
DateTimeOriginal = 2013:04:26 20:26:03
DateTimeDigitized = 2013:04:26 20:26:03
ShutterSpeedValue = -378512/1000000
ApertureValue = 6/1
ExposureBiasValue = -3/10
MaxApertureValue = 1024/256
SubjectDistance = 141/100
MeteringMode = 5
Flash = 8
FocalLength = 11/1
ColorSpace = 1
ExifImageWidth = 830
ExifImageLength = 586
FocalPlaneXResolution = 8719635/32768
FocalPlaneYResolution = 8719635/32768
FocalPlaneResolutionUnit = 4
FileSource =
CFAPattern =
ExposureMode = 1
DigitalZoomRatio = 100/100
FocalLengthIn35mmFilm = 22
UndefinedTag:0xA431 = BF4501789
[UndefinedTag:0xA432] 0 = 9/1
[UndefinedTag:0xA432] 1 = 18/1
[UndefinedTag:0xA432] 2 = 40/10
[UndefinedTag:0xA432] 3 = 56/10
UndefinedTag:0xA434 = OLYMPUS M.9-18mm F4.0-5.6
UndefinedTag:0xA435 = AAJ210412
Re[MekloN]:
от:MekloN
FileSize = 234726
FileType = 2
ImageWidth = 3966
ImageLength = 2802
BitsPerSample = 16
Compression = 1
Model = E-M5
Orientation = 1
SamplesPerPixel = 1
ResolutionUnit = 2
FNumber = 8/1
ExposureProgram = 4
ExifVersion = 0230
ApertureValue = 6/1
MeteringMode = 5
Flash = 8
FocalLength = 11/1
ColorSpace = 1
FileSource =
CFAPattern =
ExposureMode = 1
че я и говорил, он стоял в 1.5м от модели...
чем ближе, тем сильнее все сторонее смазывается...
ну и далее по тексту...
Re[MekloN]:
от: MekloN
FNumber = 8/1
ApertureValue = 6/1
Flash = 8
FocalLength = 11/1
из всего этого многообразия я уловил , что
ISO - 200
F8
выдержка 1,3 сек...
снято с 11 метров и таки со вспышкой...
Re[учусь]:
от: учусь
Полтора метра это дистанция фокусировки :)
Re[arie]:
от: arie
нет )))
это 11мм фокусное (в ЭФР 22мм)
а дистанция 1.4м
Re[arie]:
пардон за аглицкий...чего то я не понял..так 1,4 метра до объекта или 11 ?
Re[arie]:
от: arie
Ни то ни другое. :)
На 1,4 метра был сфокусирован зум-объектив 9-18 стоящий на 11мм фокусного (22мм в ФФ эквиваленте).
Re[MekloN]:
от: MekloN
ну и что не так?
дистанция фокусировки = расстояние до модели )))
уйди на 15 метров и такого смаза на той-же выдержке по карям уже не получишь....
если совсем не понятно о чем я, то посмотри в боковое окно во время движения авто/буса/трамвая/позда.... где смаз больше, рядышком или вдали ))))))))
ПыСы: но если кто-то фокусируется не на модель, тогда дистанция будет иная, да
Re[учусь]:
от: учусь
ну и что не так?
Очнись. :)
Дистанция фокусировки - это на сколько был сфокусирован объектив по шкале. В данном случае на ~1,5м, что на таком фокусном и дырке 8 дает грип от ботинок до горизонта.
А сколько было до модели хз... несколько метров судя по фото :)
Re[MekloN]:
от: MekloN
у меня тока превьюхи показываются, само фото не видно ((
Re[arie]:
от:arie
вчера пробовал этим способом. К сожалению он хорош только на бумаге.
выдержки были от 2 до 8 секунд...если люди проходили слишком быстро - от них никаких следов, в лучшем случае получились полупрозрачные силуэты вроде зомби. вспышку установил на камеру, поскольку синхронизаторы работали только дома, а в реальной съемке (как обычно) отказали... насчет поставить вспышку прямо напротив модели я не очень понимаю, во 1х зачем мне штатив во фрэйме ?..во вторых его люди просто уронят вместе с пыхой. в общем нереально это. Один из выводов со вчерашней съёмки...пыха совсем не нужна
Ну почему же только на бумаге, этот метод как раз таки и работает. Вы же вчера , делали все также, с точностью наоборот ( вспышку установил на камеру,) Вы тем самым подсвечивали весь кадр, а я вам советую подсветить только модель. Тем более у вас есть все для этого. Ну а перед штативом со вспышкой , можно что нибудь поставить яркое, что бы его было заметно и его не уронили.
Re[учусь]:
чего то я не догоняю...за 1,3 секунды в коридоре шириной 1,4 метра между камерой и объектом съёмки прошел целый взвод ??? :D сдается мне тут фотошопом пахнет ))
Re[BELG]:
:D
Re[arie]:
от: arie
он снимал на суперширеГ!!!
т.е. все выгладит как издалека, а на само деле все ОЧЕНЬ близко!
и мажутся они на такой дистанции только в путь!
плюс к смазу - размахивание руками и ногами у прохожих, оно создает доп. мешанину
Re[BELG]:
от:BELG
и пыху по второй шторке ?
Re[учусь]:
от:учусь
сколько прохожих может пройти за 1,3 секунды ???? там только ног штук 20 !! :D
Re[arie]:
возьми у кого-нибудь 16-35
встань в толпе и сними на 1/2 на 16мм прямо перед собой, когда толпа на тебя идет и обтекает, сам увидишь
кто совсем близко - смажутся сильно, кто вдали - меньше, т.е. их смешение относительно кадра при той-же линейной скорости меньше, это тупо геометрия
можешь потренироваться на светофоре, когда толпа с той стороны попрет...
а девочку свою под светофором поставь, пусть неподвижно стоит
Re[arie]:
от: arie
дофигища!!!!
нужно просто момент правильный выбрать, когда поток пошел...
выброс с поезда, например
Re[Justin]:
Ребят, вы чего курили? Отсыпьте и мне немного! :cannabis:
Никакого коридора шириной 1,4 метра там в помине нет! Вы на фото посмотрите хоть! :D
FocusDistance = 1.41m - это не расстояние до объекта, это дистанция фокусировки! :)
Дистанция фокусировки не равно расстоянию до объекта!
Если в поле FocusDistance будет стоять Infinity то че, расстояние до объекта было бесконечным?
