Всего 58781 сообщ. | Показаны 11081 - 11100
Re[www user]:
от:www user
One of the more significant external changes with the D3 (and the D300) is a new large, high resolution LCD monitor. It has four times the number of dots than the 230,000 unit used on the D2X and other such cameras. For clarity, the words pixels and dots are interchanged almost randomly in specification sheets but strictly speaking we should talk of dots (these being red, green or blue sub-pixels) when referring to the figures quoted by manufacturers. The D3's LCD has 921,600 dots, 1920 columns by 480 rows, the dots are a third thinner than they are high and so each group of three dots (sub-pixels) make up one full color pixel.
This high resolution screen really has to be seen to be appreciated, it's beautifully detailed and extremely smooth in appearance because the tiny gaps between dots are too small to be seen with the eye. This extra detail is obvious in Live view and playback modes where you really can see much 'more' of the image in one glance. Another difference comes when you magnify in playback as you find you don't need to magnify the image as much before you can clearly see sharpness, focus accuracy and even noise.
One other difference between the D3/D300's screen and that used previously is the layout of the dots (sub-pixels), this new screen has the same layout as your computer LCD, a simple RGB layout with all rows the same ('stripe array'). The other layout used on small LCD screens is the 'delta array' which uses an RGB pattern on one row then a BRG pattern on the row below, offset by half a pixel.
http://www.dpreview.com/reviews/nikond3/page3.asp
侬会得讲吴语弗?吴语是汉语族里向个一种闲话,也是历史交关悠久个一种闲话。讲吴语个人分布来江苏南部、浙江大部分,整个上海,安徽南部搭福建、江西少部分场许。通行吴语个县市有110个横里,人口8000万(2004年光景,来拉汉语族语言里向排名第二,来拉世界浪排名第十。大家来帮衬帮衬,一淘编写吴语维基百科,积累吴语文本资料。市,安徽南部同埋福建、江西嘅小部份地第二大方言,世界第十大语种。如果你
Re[BeS]:
от:BeS
Бамбарбия... Киргуду :D
Re[Gosha_K]:
от: Gosha_K
Да юзер написал фигню какую-то не понятную... ну я и ответил ему тем же.
Re[BeS]:
[УДАЛЕНО]
Re[www user]:
С 300ки можно фотки показать? А то там ветка полумертвая, а я как бывший владелец 90го внимательно слежу за темой. Скучно мне без Беса
Re[nevit]:
[УДАЛЕНО]
Re[www user]:
Только сегодня приехал от родителей. Все кости болят после посадки картошки :D. В общем, мои опасения по поводу промахов фокуса у 85 1.8 оправдались... на ближних дистанциях попадает точно, а чуть подальше и писец... мажет только в путь. Причём, независимо от выбранной точки фокусировки. Хоть по центральной, хоть по крайним - всё время мимо. Теперь весь расстроенный такой неприятностью. Ребят, чего с ним можно сделать, подскажите? Только об стенку? Вроде читал, что юстировки для AF объективов не делают?..
Re[Garmych]:
Юстировке отвёрточные объективы действительно не подлежат.
Единственное, что можно посоветовать в Вашем случае - только фокусироваться по Live Wiew. Ну, и ручную фокусировку пока не отменили.
Re[Канонир Никанор]:
А при ручной подтверждение фокусировки будет неверно? То есть, только на глаз наводиться? С моим зрением это очень проблематично... Live View тоже не выход - долго слишком :(. Может сдать его обратно пока время есть?.. Или это геморрой ещё тот?
Re[Garmych]:
А при покупке не мазал? Или на дальних дистанциях не проверяли?
Re[www user]:
Re[Garmych]:
от:Garmych
А вы пробовали использовать широкую центральную зону?
Re[www user]:
chosone первый песик, сильно перешарп, + глаза провалены в тенях, советую D-Lighting HS потянуть ползунок.
Re[BeS]:
Да тяму не хватило проверить на дальних :(. Когда читал про тесты при покупке, нигде не увидел, что нужно тестить на разных дистанциях... А в офисе, куда привезли, была возможность посмотреть фокусировку только вблизи. Теперь что делать - ума не приложу.
Алексей2000, да, и при широкой и при узкой мажет. Сначала перекадрировал и думал, что фокус уходит при этом. Потом попробовал уже без перекомпоновки - результат плачевный :)).
chosone, красивые фото, понравились!
UPD: ага, перешарп сильный. Аж глаз режет.
Несколько фото с 85 1.8
Re[Garmych]:
от:Garmych
Сдать обратно - имхо самый правильный вариант.
По ЛВ можно наводиться и вручную, это быстрее и точнее чем по точке и цифровому дальномеру (специальному режиму, когда камера шкалой экспозамера показывает куда и насколько крутить).
На некоторых расстояниях у меня по точке вообще навестись не получалось, из-за крайне небольшого хода кольца.
Re[PanteleeV]:
Спасибо! критика и дельные советы -нужны!
Re[Garmych]:
от:Garmych
Конечно, сдавайте взад, если есть такая возможность. Только слышал я, что в стране России любой мало-мальский вопрос - неразрешимая проблема. Даже если по всем законам Вы правы...
P.s. наводиться по Live View - не проблема. Можно сделать 100% увеличение и контролировать резкость практически попиксельно. Оперативность, конечно, не высокая.
Re[Garmych]:
от:Garmych
Прикол в том, что официальная методика юстировки предполагает дистанцию только 1,5 м.
А самое смешное, что когда я предположил (здесь на форуме :) ), что юстировать надо на несколько расстояний, причем каждую точку, на меня некоторые коллеги обрушились с критикой
Непонятно, почему у никона не предусмотрена юстировка AF стекол, ведь технически это возможно.
Вобщем, в этом вопросе никон маркетоложит по полной. Думаю, что в некоторых ситуациях более правильным решением была бы вообще покупку самьянга 85/1.4.
Re[Garmych]:
Вроде на ваших фото нет промаха АФ?
от:Канонир Никанор
А почему Вы решили споросить фото с 300-ки здесь ?! Почему бы не разместить просьбу в той ветке ? Вам мало того, что там есть ? Или, по-Вашему, владельцы 90-го просто ОБЯЗАНЫ иметь фото с 300-го ? Да и БЕС никогда их не выкладывал по причине отсутствия у него таковых.
Ветка D300 не полумёртвая. Просто там значительно меньше истеричных субъектов и формуных клоунов, а фотографий, кстати, больше, чем пустопорожней болтовни и срача. И ТОПИК-СТАРТЕР трёхсоточной ветки регулярно выкладывает великолепные фото.
Если Вам интересно, отмотайте полсотни-сотню страниц назад в этой теме. В частности я выкладывал много фотографий с 300-ки.
Ну, в ТОЙ я бы и не спрашивал... Просто вся дискуссия сводится к обсуждению скинтонов и шумов Никона. И здесь есть сомневающиеся, стоит ли менять Д90 на Д300(s)... И матрицы у них одинаковые, а значит и картинка должна быть идентичная при равных условиях... И фоток меньше чем флуда... Вот те причины, по которым я бы выложил здесь фоты с 300ки, спросив разрешения у топикастера. А Бес просто хороший и не глупый парень, который в отличии от многих, и меня в том числе, снимает. И не важно чем...
