Проблема с Olympus OM2
Камера яростно засвечивает пленку. С чем это может быть связанно и во сколько может обойтись ремонт?
Re[McGee]:
Здравствулте от Техас. Световые лучи входят в вашу камеру на шарнир. Можете вы прочитать английскую язык? Пожалуйста см. мои инструкции: http://www.kyphoto.com/classics/sealreplacement.html
Jon Goodman
Re[Jon Goodman]:
Если вы желаете отремонтировать, то вам будет нужен материал. Пожалуйста напишите меня.
Jon
Re[McGee]:
Jon, thx for the instructions!
What part of foam rubber in my camera may be wrong?
Re[McGee]:
Hello, McGee. English is easy for me...thanks! The hinge seal is bad. You need 2 pieces of thin fabric (velvet) seal for the simple repair. Do you want me to mail to you?
Jon
umm..неполноценное уплотнение шарнира. Вы хотите меня передать части?
Re[McGee]:
Somebody here said that also thin strips of rubber of mouse pads are also ok for this. And people use them with success.
Cheers.
Re[Jon Goodman]:
The hinge between body and back is bad, isn`t it? Is this what you mean?
Re[Юра.]:
Yes, the hinge between the body and film door is bad. The best way to repair the OM-1, OM-2, etc is to use 2 thin (1mm) pieces of self-adhesive velvet. You can use one thicker piece of foam rubber, but in the early OM cameras, there was a seal on both the door and the body, so two pieces of foam rubbing together are not as good as the velvet. If you want, I can mail it to you...the stamp will only cost $1 and it is better than mouse pad...Please tell me if you want me to write in Russian. A long sentence like this will be very funny when I finish...
Jon
Re[Jon Goodman]:
Well, for me writing in english is ok.
At the moment all my OM-s seems to be ok (in terms of parasite exposure). But thanx for your care in any case.
Yuri.
