Две новых камеры Panasonic G2 и G10
Всего 73 сообщ. | Показаны 41 - 60
Re[Fishmann_Vic]:
Тамже появилось превью G2 http://www.dpreview.com/previews/PanasonicDMCG2/
Re[Boris Moscow]:
Вот страница на которой камеры сравниваются:
http://www.dpreview.com/previews/PanasonicDMCG2/page3.asp
(там очевидно ошибка в размере матрицы у G10, должно быть, как в другом месте, 13.1 Иначе можно подумать что у них разные матрицы)
И если новый (как пишут более быстрый) процессор принципиально камерный ДжейПег не улучшил, то можно задуматься о покупке более дешевой G1.
Re[Boris Moscow]:
Есть интересные и ободряющие слова на сайте Панасоник о новом процессоре:
http://www.panasonic.co.uk/html/en_GB/News/Test+Page+1/3570539/index.html#anker_3570541
"The new Venus Engine HD II features exceptionally advanced signal processing capabilities. This sophisticated LSI separates chromatic noise from luminance noise and applies the optimal noise reduction to each, so you capture clear and beautiful images even when shooting at high ISO sensitivity levels. The Venus Engine HD II also provides independent gradation control for each of the R, G and B colours, so even delicate colour nuances are reproduced faithfully. Linking smoothly with the Live MOS sensor, the Venus Engine HD II records stunning high-resolution 12.1-megapixel images with exceptional accuracy. Signals containing a large amount of image data are sent from the Live MOS sensor to the Live View Finder at 60 fps, resulting in clear, smooth live view."
"The high-speed, high-performance Venus Engine HD has been re-engineered to compile the new image processing technology "Intelligent Resolution". It enables the recording of beautiful photo and high-definition movie with higher quality signal processing. With the Intelligent Resolution technology, 3 areas — outlines, detailed texture areas and soft gradation areas are automatically detected. The outline parts are enhanced effectively to give edges more clearness while giving a moderate accentuation to the texture areas to look more finely detailed. To the soft gradation part, superior noise reduction system of the Venus Engine HD II is applied to make it smoother. Apart from the uniform enhancement of sharpness, the innovative technology Intelligent Resolution precisely performs signal processing pixel by pixel in the most effective way for it. As a result, images are naturally clear and crisp in both photo and movie recording."
То есть, может быть и камерная картинка изменится?
Хотя, я уже позже нашел что и про предыдущий процессор говорится что-то похожее:
"The Venus Engine HD has exceptionally advanced processing capabilities. This sophisticated LSI features effective noise reduction even at high ISO sensitivity levels. The Venus Engine HD also reproduces delicate colour nuances faithfully with independent gradation control for each of the R, G and B colours. Additionally, it supports the Live View function, resulting in the display of smooth images at 60 fps. HDMI output support is also a feature of the Venus Engine HD."
Так-что что тут нового, не совсем мне понятно. :(
Re[Boris Moscow]:
Про камеры не нашел, но про идущий с ними китовый зум сказано: "что будет в продаже с камерами и отдельно в июне".
Видели эту бомбу...
http://www.youtube.com/watch?v=UhP6oPU_iYc
Re[Veres]:
от: Veres
Да, со штатива удобно.
Два вопроса, жир от пальцев на экране и очевидно зашитные пленки уже на экран не приклеешь (да я этого и не делал, купил такую пленку и приклевать не стал).
Re[Boris Moscow]:
Вот еще видео про сенсорный экран
http://www.forum-fourthirds.de/lumix-g2video.html
Re[Veres]:
Суперски!!!
Панас рулит!!!
Когда в продаже?
О, уже есть здесь упоминание: http://www.dpreview.com/news/1003/10030703panasonicg2.asp
Уже радует вот это:
• AVCHD Lite:*
1280 x 720, 60p (from 30fps sensor output)*
1280 x 720, 50p (from 25 fps sensor output)*
Новая матрица
Вот ключевые моменты:
Panasonic have developed a 4K x 2K image sensor (approx. 12 megapixel) based on 'dual exposure technique' Panasonic разработала 4K X 2K датчика изображения (ок. 12 мегапикселов), основанных на "двойное техники в открытую"
The sensor is described as having new architecture that tries to improve sensitivity by a factor of 4 or more Датчик описывали как новую архитектуру, которая пытается улучшить чувствительность в 4 раза или больше
The architecture change is a new design which allows green pixels to be read independently of the blue and red ones on the sensor. Архитектура изменений является новый дизайн, который позволяют зеленых пикселей для чтения, независимо от синих и красных на датчике.
The green pixels are exposed 4 times longer than the red and blue, thus achieving the sensitivity gain Зеленых пикселей подвергаются 4 раза больше, чем красный и синий, обеспечив тем самым усиление чувствительности
Motion artifacts are introduced as a result, but clever signal processing of the red and blue channels corrects the motion artifacts introduced in the green channel by the long exposure Артефактов движения вводятся как результат, но умная обработка сигнала красного и синего каналов корректирует движение артефакты внес в зеленый канал длинной выдержкой
Red and blue channel gain achieved by pixel binning in 4x4 mode Красный и синий канал усиления достигнутых пиксель Binning в режиме 4x4
4 раза повышение чувствительности позволит камеры Micro 4/3rds превзойти полный кадр Canon 5DMkII.
http://www.eoshd.com/entry.php?29-Panasonic-engineer-reveals-workings-of-GH2-dual-exposure-sensor
Re[Veres]:
от:Veres
Это по поводу GH2 которая может появится только с Сентября в лучшем случае.
Re[Boris Moscow]:
Первые примеры полноразмерных фоток
G2 ИСО100
http://www.panasonic.net/avc/lumix/systemcamera/gms/gallery/img/sample/g2/P1000577.JPG
http://www.panasonic.net/avc/lumix/systemcamera/gms/gallery/img/sample/g2/P1010188.JPG
G10 ИСО100
http://www.panasonic.net/avc/lumix/systemcamera/gms/gallery/img/sample/g10/P1000577.JPG
http://www.panasonic.net/avc/lumix/systemcamera/gms/gallery/g2.html
Вот еще полноразмеры
http://www.nomobile.ru/reviews/65023.html
Re[Veres]:
от: Veres
G2 ИСО100
l
Вот за это большое спасибо.
Посмотрел, очень понравились.
А когда узнал что это камерные ДжейПеги, то на душе стало приятно!
В моем вкусе. Будем ждать еще снимков.
Re[Boris Moscow]:
Кстати, в своем хорошем преобзоре Алексей Гончаров перепутал разрешение дисплея (они одинаковы у этих двух камер) и ЭВИ у G10 :)
Re[Veres]:
от:Veres
G2 ИСО100
G10 ИСО100
Супер!
А новый кит 14-42 получше старого 14-45 будет!
Re[abonis]:
от: abonis
Супер!
Да, мне как раз Ваше мнение было интересно узнать.
Пишут что на высокиз ИСО (согласно приведенной картинки при разных ИСО) новая камера справляется лучше чем предыдущая. Вы заметили?
По поводу нового кита, мне интересно знать почему на приведенном фирмой графике он так отличается от преыдущего:
http://www.panasonic.net/avc/lumix/systemcamera/gms/lens/g_vario_14_42.html
http://www.panasonic.net/avc/lumix/systemcamera/gms/lens/g_vario_14_45.html
Посмотрите пожалуйста и прокомментируйте.
Re[Trubokur]:
от: Trubokur
Уже радует вот это:
• AVCHD Lite:*
А чего радует-то?
Не самый лучший для последующего монтажа формат AVCHD.
60 и 50 кадров в секунду, притом, что с сенсоре было 30 и 25 кадров в секунду, где недостающую информацию (каждый второй кадр) взяли?
Re[Boris Moscow]:
от:Boris Moscow
На мой взгляд, там приведены для этих объективов настолько разные жанры, что прямое сравнение не возможно.
Для нового 14-42 приведен снимок в "честном" для сравнения детализации и боке портретном жанре. Для старого 14-45 выбраны жанры, в которых скорее можно увидеть работу камеры, но не объектива.
Я просто смотрю на портрет, сделанный новым 14-42 и вижу, что такая детализация не доступна старому киту 14-45.
Re[abonis]:
от:abonis
Срасибо большое, я на самом деле спрашивал по поводу гоафиков (MFT Chart).
Но Вашему глазу знающему предыдущий объектив хорошо доверяю больше всего. Спасибо.
Будет в Июне в продаже!
Re[Veres]:
мелькала инфа, что это сенсор для видеокамер будет, не для фото.
Re[Veres]:
от:Veres
G2 ИСО100
1. Контраст на крепкую двойку.
2. ББ холодный.
3. Детали сожраны шумодавом (это на ИСО 100...).
Но в остальном - отличные кадры!
У ЦА будут иметь большой успех.
ЗЫ:
модель красивая.
а всё, что руками - ещё не очень.
