Nikon Remapping: Ремаппинг битых пикселей?
Всего 46 сообщ.
Показаны 41 - 46
Re[balbes2042]:
дел - прогу по ремапу нашёл на никонхакер
Re[Александр Лёгкий]:
Отбой - всё сделал в два клика мышкой
Re[PIT666]:
Добрый день!
Решил сделать ремаппинг для матрицы моей D200. Делал по инструкции, которая на Вашем сайте. В результате, камера разок щёлкнула затвором, и потом программа выдала Error Code = [18002] Defect Dark Count Over Error Я не совсем понял, что это за ошибка. Если можно, разъясните.
Re[Gesha]:
Вот полный лог, если нужно
Pixel defective compensation 2
Before Defect Count = 5
[5] (1695,6) = 34[LSB]
[6] (32,50) = 216[LSB]
[7] (3843,59) = 116[LSB]
[8] (2894,135) = 74[LSB]
[9] (3173,143) = 182[LSB]
[10] (1856,147) = 53[LSB]
[11] (472,153) = 318[LSB]
[12] (3023,224) = 287[LSB]
[13] (647,243) = 193[LSB]
[14] (218,268) = 226[LSB]
[15] (3032,276) = 324[LSB]
[16] (1929,302) = 177[LSB]
[17] (2860,339) = 269[LSB]
[18] (3201,342) = 45[LSB]
[19] (2645,346) = 108[LSB]
[20] (1384,371) = 84[LSB]
[21] (2414,396) = 418[LSB]
[22] (2453,413) = 72[LSB]
[23] (574,417) = 128[LSB]
[24] (3401,426) = 355[LSB]
[25] (598,429) = 39[LSB]
[26] (2526,457) = 319[LSB]
[27] (1191,465) = 52[LSB]
[28] (3505,467) = 1203[LSB]
[29] (1003,470) = 361[LSB]
[30] (758,483) = 70[LSB]
[31] (1454,495) = 180[LSB]
[32] (3660,499) = 150[LSB]
[33] (1710,519) = 52[LSB]
[34] (690,525) = 672[LSB]
[35] (493,530) = 87[LSB]
[36] (2925,531) = 222[LSB]
[37] (1692,541) = 300[LSB]
[38] (812,553) = 71[LSB]
[39] (1653,570) = 196[LSB]
[40] (109,599) = 38[LSB]
[41] (2884,602) = 789[LSB]
[42] (3036,610) = 48[LSB]
[43] (68,698) = 1080[LSB]
[44] (555,700) = 38[LSB]
[45] (2871,719) = 91[LSB]
[46] (521,726) = 77[LSB]
[47] (1599,727) = 63[LSB]
[48] (244,737) = 268[LSB]
[49] (1093,769) = 254[LSB]
[50] (2222,821) = 47[LSB]
[51] (718,823) = 70[LSB]
[52] (710,832) = 74[LSB]
[53] (668,835) = 64[LSB]
[54] (3225,903) = 507[LSB]
[55] (2038,905) = 70[LSB]
[56] (160,916) = 49[LSB]
[57] (3000,921) = 137[LSB]
[58] (2274,947) = 43[LSB]
[59] (459,949) = 93[LSB]
[60] (2618,961) = 64[LSB]
[61] (3514,1009) = 52[LSB]
[62] (1690,1059) = 108[LSB]
[63] (891,1097) = 172[LSB]
[64] (3362,1125) = 59[LSB]
[65] (528,1133) = 31[LSB]
[66] (2280,1181) = 39[LSB]
[67] (991,1274) = 90[LSB]
[68] (78,1299) = 54[LSB]
[69] (2744,1343) = 172[LSB]
[70] (1310,1346) = 101[LSB]
[71] (2522,1346) = 106[LSB]
[72] (509,1373) = 397[LSB]
[73] (384,1376) = 73[LSB]
[74] (2756,1409) = 197[LSB]
[75] (877,1432) = 543[LSB]
[76] (3619,1459) = 179[LSB]
[77] (3439,1471) = 53[LSB]
[78] (3213,1488) = 459[LSB]
[79] (1548,1509) = 40[LSB]
[80] (1386,1517) = 88[LSB]
[81] (3819,1595) = 525[LSB]
[82] (345,1614) = 73[LSB]
[83] (3448,1619) = 43[LSB]
[84] (2800,1642) = 457[LSB]
[85] (1562,1659) = 203[LSB]
[86] (1867,1672) = 259[LSB]
[87] (1020,1714) = 153[LSB]
[88] (3422,1716) = 115[LSB]
[89] (701,1722) = 706[LSB]
[90] (2020,1744) = 39[LSB]
[91] (3165,1768) = 51[LSB]
[92] (2977,1789) = 48[LSB]
[93] (754,1801) = 248[LSB]
[94] (2568,1810) = 40[LSB]
[95] (191,1819) = 80[LSB]
[96] (790,1832) = 89[LSB]
[97] (788,1857) = 524[LSB]
[98] (1029,1857) = 52[LSB]
[99] (2330,1867) = 38[LSB]
[100] (1309,1878) = 41[LSB]
*** Error Code = [18002] Defect Dark Count Over Error ***
Здравствуйте на Nikon D700 есть прога для устранения горячих пикселей?
кароче нажимал имидж-адж-5 и бинго !!!!!!!!!!!! около 100 красно-зелёно-белых битых пиксели исчезли !!!!!!!!!!!!
а ещё сделал бекап
и чет ещё там тыкал....
д7100фотик
а ещё сделал бекап
д7100фотик
