информация с DWF, возможно кому-то будет полезна,
на английском, может кто сделает перевод для неанглоговорящих
01. Shoot on Manual
Set your camera on manual (“M”). Your camera’s meter isn’t smart enough to get this right in any of the automatic modes. If you hate shooting in manual,
don’t worry, I’ll give you a place to start and a little experimenting will help you perfect it.
02. Set Shutter Speed
Set your shutter speed to the fastest your camera will allow without having to use high‐speed sync. For example, a Canon 5D should be set to 1/200th.
03. Set a Low ISO
Since you’re shooting right into the sunset, you will want your ISO at 100 or lower if your camera supports it.
04. Set Your Aperture
Start at f/5.6 and take a test shot of the sunset only. Because some sunsets are composed of colored clouds and others may include direct sun
you’ll probably need to check the imagepreview. If it looks too bright and you’re losing detail go with a smaller aperture, such as f/8.
If your image is too dark try a wider aperture, such as f/4. Go as small or as wide as you need to get the result you like best.
Now that your sunset is correctly exposed, it’s a great time to do your silhouettes!
05. Add Some Flash
Simply turn on your flash in ETTL mode! The camera can figure out the required flash settings for you.
If your subjects appear too bright or too dark, flash exposure compensation (FEC) is the ticket! For bright subjects, try a setting like ‐1
so your flash isn’t as bright. If your subjects are too dark, try a setting like +1 so your flash is brighter. Be sure to check your image preview
and go from there.
Комментируйте
© Mindy Sonshine
Съёмка молодых на рассвете солнца
Всего 9 сообщ.
Показаны 1 - 9
Re[SergeyNew]:
Гутентаг, ты уже запарил дурные темы плодить.
Или лучше поработай.
Re[SergeyNew]:
тут только :) СержеСмарт прокоментирует в английском только он рубит ):
Re[FreeSTYLE]:
Эмм... вроде закат, а не рассвет.
Да и к тому же - если я хочу силуэт молодоженов снять - зачем мне вспышка?
All
На этом форуме полно новичков... Причем некоторые еще не сняли ни одной свадьбы... Им эта информация очень полезна будет... Особенно если учесть то, что все их вопросы у низко и средне-продвинутых фотографов вызывают издевку и агрессию...
По поводу языка - Гугл и Мэйл.ру все могут перевести...
Re[Алексей_Поляков]:
Алексей, я совершенно без наездов - просто меня немного смутил перевод, ничего более.
К тому же сам из таких новичков...
Re[Андрей Шеклеин]:
он чё? НИК сменил?
упалподстол
упалподстол
Re[eugeon]:
да какая разница : закат, рассвет - условия идентичные :)
Re[Darvin]:
от: Darvin
В цитатнегЪ!
(шутка)
P.S.
Но перепутать в названии темы рассвет с закатом - это что-то!
Не припомню ни одной свадьбы (я не только о тех, что из личного опыта), где бы молодые пожелали сниматься на рассвете!
Это наверное только когда жених и невеста сами фотографы до мозга костей и только тогда на такое способны!
И только тогда, как если они пожизненные фанаты слайда! :cannabis:
P.S.2
Думаю, "съемка на рассвете" никоим образом не может относиться ко дню свадьбы.
По крайней мере в наших широтах (и с нашими традициями), когда рассвет приходится где-то до 7-ми утра в летний свадебный сезон.
А в Питере, с белыми ночами, ну сами понимаете! ;)
