Sigma DP series reinvented as DP1M and DP2M with 15MPx3 sensor from SD1
DP1 Merrill and DP2 Merrill now incorporate 46-megapixel, full-color image sensor
Sigma has totally reinvented its DP series of large sensor compacts with the DP1 Merrill and DP2 Merrill. The DP Merrill models are named after Dick Merrill, inventor of the Foveon sensor and include the most recent version of the technology - the 15x3MP APS-C sensor first seen in Sigma's SD1. Because the Merrill cameras feature full APS-C sensors, they also feature totally redesigned lenses, with the DP1M including a 19mm F2.8 lens to offer a 28mm equivalent field of view and the DP2M having a 30mm F2.8 lens to give a 45mm equivalent field-of-view.
Both camera's lenses include Sigma's Fluorite-like 'FLD' glass elements. They also both include substantially redesigned bodies that incorporate high-resolution 920k dot LCDs. The controls have also been updated and the cameras look smarter as a result. Having been first-to-market with a large sensor, prime lens compact, it must have been hard for Sigma to watch the success of Fujifilm's X100. We haven't had a chance to see the Merrills in-person yet but we hold out hope that the high-res sensor and updates will make the DP series competitive again. There is also no detail on pricing yet.
Ronkonkoma, NY, Feb. 8, 2012 – Sigma Corporation of America (www.sigmaphoto.com), a leading researcher, developer, manufacturer and service provider for some of the world's most impressive lines of lenses, cameras and flashes, today announced the new Merrill series of digital cameras with the introduction of the DP1 Merrill and DP2 Merrill. The Merrill series is named in honor of Richard “Dick” Merrill, the co-creator of the Foveon X3 Direct Image Sensor technology that powers Sigma’s unique lineup of cameras.
These upgraded, high resolution, fixed lens compact digital cameras now incorporate the same APS-C sized 46-megapixel X3 image sensor found in the company’s flagship SD1 SLR, now also known as the Sigma SD1 Merrill. This name change not only pays homage to Merrill, but it also reflects new production efficiencies that will result in a substantial reduction in the camera’s market price starting next month.
Merrill (1949-2008) was a brilliant engineer, talented photographer and Foveon co-founder. He tapped into his passion for electronics to build an innovative pixel structure that uniquely demonstrated the ability to capture RGB information in each pixel location. This revolutionary discovery led the Foveon team to the development of the X3 Direct Image Sensor and, ultimately, to the creation of some of the most vibrantly colored and detailed imagery the photography industry has ever seen. Sigma acquired Foveon in late 2008.
“This revolutionary image capture system reflects both the artistic and technological sides of Merrill’s personality,” said Kazuto Yamaki, CEO of Sigma Corporation. “As an expression of Sigma’s passion for photography and in honor of Dick Merrill’s genius, we have named the latest generation of the Foveon X3 Direct Image Sensor the Foveon Merrill.”
The Sigma DP1 Merrill and DP2 Merrill each boast exclusively-designed, high-performance telecentric fixed lenses. The DP1 Merrill features a wide, 19mm F2.8 lens, which is the equivalent to a 28mm lens on a 35mm SLR camera. The DP2 Merrill, however, offers a 30mm F2.8 lens, which is the equivalent to a 45mm lens on a 35mm camera. Both cameras are compact and lightweight, and feature Sigma’s own “F” Low Dispersion (FLD) glass, which performs like fluorite glass and significantly improves lens performance, as well as Super Multi Layer Coating to reduce flare and ghosting. With the 46-megapixel, full-color Foveon X3 Direct Image Sensor, the new DP cameras capture all primary RGB colors at each pixel location with three layers, which results in incredibly detailed images with a three-dimensional feel.
The Sigma DP Merrill cameras also include the following features:
A dual, three-layer responsive ultimate (TRUE II) engine now incorporates two TRUE II processors to improve the processing speed and overall quality of the final image. Sigma’s unique image-processing algorithm also provides high-resolution power and reproduces high-definition images with richly graduated tones that offer a three-dimensional feel.
RAW and JPEG format recording retains the full image detail of the utmost quality captured through the direct image sensor, as well as a JPEG recording format for convenience. The RAW data format provides pure data for high-resolution images, and uses lossless compression for more compact, yet uncompromised, data files. The RAW data format of the DP Merrill series keep brightness and color data in a 1:1 ratio without relying on interpolation. When the image is processed in Sigma Photo Pro, it will preserve the balance of the natural data for the best photos with the best image quality.
Sigma Photo Pro processing software converts RAW data quickly and easily. It incorporates functions such as a loupe, exposure picker, print, JPEG conversion, and batch white balance settings.
Manual focus is available for use when autofocus or focus-lock is not desired.
An advanced user interface is complete with a custom Quick Set (QS) menu and the metallic command dial to improve usability. The diaphragm, shutter speed and menu can be changed quickly using the command dial. The QS menu consists of the most commonly used functions and can be easily displayed by pressing the QS button, allowing photographers to change the menu content and the order depending on preferences.
A large, highly visible three-inch TFT color LCD monitor ensures great visibility even outdoors in the daytime. This approximately 920,000 pixel resolution LCD monitor benefits from a wide viewing angle, making it easy to capture details and check focusing and composition.
A hot shoe allows the use of the dedicated external flashgun EF-140 DG (optional) as well as Sigma electronic flashguns for SD series such as EF-610 DG Super (optional) and EF-610 DG ST (optional).
Movie mode enables movie recording with VGA (640×480) size, with 30 shooting frames per second.
Pricing and availability of the Sigma DP1 Merrill and DP2 Merrill are pending.
SIGMA DP1 Merrill --->
SIGMA DP2 Merrill --->
Sigma DP1M / DP2M
Всего 4695 сообщ.
Sigma DP1M / DP2M / DP3M
Re[ATAMAH]:
При первойже возможности сменю свою DP1 на DP1M Надеюсь ценник не будет слишком космическим! :cannabis:
Re[ATAMAH]:
Видимо ценник на разницу тушек SD1 и "пятнашки"
del
Re
цена "радует"
Re[Romanyk Olexandr]:
вспышки нету!
Re[all]:
Наконец-то хорошие новости.
Буду брать - однозначно!!!!!
Непонятно - объективы выезжают?
На объективах - кольцо ручной фокусировки?
Re[Lever]:
Поздравляю всех сигмоводов с дальнейшим/ожидаемым развитием системы! :D
Думается машинки будут что-надо. Правда с дизайном уж больно как то веселенько, но это на любителя.
Re[Lever]:
от: Lever
И я задался вопросами этими, но объективы всёж выезжают, ибо не вижу резьбы под фильтры-бленды, но вижу байонетное крепление под HOOD ADAPTER.
Re[ATAMAH]:
Нет шкалы фокусировки, а значит идиотский фокус бай ваер, где неизвестна точка бесконечности и точка мдф, а соответственно и гиперфокал.
Конечно, линза на 28 мм радует, но делать штатник с 2.8 это как-то уже позавчерашний день.
Вспышки нет - да она и раньше была бесполезна.
Меня больше интересует вопрос обработки снимка - будет та же проблема с пересветами как у серии Х в SPP 4.2 или все-таки лучше.
Re[Stjarna]:
"Поднимите мне веки" - не нашел, когда начало продаж! :)
Re[Димитриадис]:
Думаю, многие ждали подобного шага от сигмы. Получился удачный вариант –матрица от SD1 в чуть видоизмененном форм факторе DP с сохранением компактности.
Возьму обязательно. Не обнаружил информацию о примерной дате начала продаж. Надеюсь, речь все-таки идет о месяцах. Или я по срокам выдаю желаемое за действительное.
с открытой датой...
нет пока никаких данных о сроках доступа для смертных простых, а об покупке можно и подумать и мозгами пораскинуть...
DP-Merrill
DP-Merrill
Re[ATAMAH]:
Интересно, что за новый 19-мм объектив в новой единичке. В dp1x просто безумно нравится 16,6 который.
Re[macosXer]:
от: macosXer
dude - это просто несъемные варианты 2 обьективов от Сигмы = http://www.dpreview.com/news/2012/01/10/SigmaDigitalNeo
Re[deejjjaaaa]:
от: deejjjaaaa
О как, интересно, спасибо. Но как они оптически пока не ясно.
Re[Михаил Мосейко]:
от: Михаил Мосейко
ну так написали же, 1500$ DP 46 мегапиксельная будет стоить
Что за фантазии? Ни цены, ни сроки не объявлены.
Re[deejjjaaaa]:
от: deejjjaaaa
По этой ссылке пишут про семилепестковую диафрагму, а в спецификации на http://www.sigma-dp.com/DP-Merrill/#!/specifications пишут про девятилепестковую почему-то. Опечатались? Или прям вот специально переделали для ДП-шек?
Re[N6210]:
от:N6210
По этой ссылке пишут про семилепестковую диафрагму, а в спецификации на http://www.sigma-dp.com/DP-Merrill/#!/specifications пишут про девятилепестковую почему-то. Опечатались? Или прям вот специально переделали для ДП-шек?Подробнее
не переделывали, а просто поставили другую запчасть... тем более что в отличии от сменных обьективов для других систем тут сигме в плане цены особо конкурировать не надо - можно вместо семилепесткового модуля поставить девятилепестковый... тем более что это вещи все равно поставляет сторононний производитель типа Копала.
Re[deejjjaaaa]:
от:deejjjaaaa
не переделывали, а просто поставили другую запчасть... тем более что в отличии от сменных обьективов для других систем тут сигме в плане цены особо конкурировать не надо - можно вместо семилепесткового модуля поставить девятилепестковый... тем более что это вещи все равно поставляет сторононний производитель типа Копала.Подробнее
хотя - пожалуй возму свои слова назад - оптические схемы похоже другие, значит отличия более существенные
